About ESP32CAM image too dark, how to fix
Hi everyone.
The Arduino ESP32CAM token pictures and saved into TF card, but the images too dark too see well, and there is no improve happened when the set_brightness(s, 0); changes from (-2) to 2, why and how to fix please.
Thanks
Adam
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-cam-ov2640-camera-settings/
#include "esp_camera.h"
#include "FS.h"                // SD Card ESP32
#include "SD_MMC.h"            // SD Card ESP32
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
// Pin definition for CAMERA_MODEL_AI_THINKER
// Change pin definition if you're using another ESP32 with camera module
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
// Keep track of number of pictures
unsigned int pictureNumber = 0;
//Stores the camera configuration parameters
camera_config_t config;
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  //Initialize the camera
  Serial.print("Initializing the camera module...");
  configInitCamera();
  Serial.println("Ok!");
  //Initialize MicroSD
  Serial.print("Initializing the MicroSD card module... ");
  initMicroSDCard();
  //Path where new picture will be saved in SD Card
  String path = "/picture" + String(pictureNumber) +".jpg";
  Serial.printf("Picture file name: %s\n", path.c_str());
  //Take and Save Photo
  takeSavePhoto(path);
  pictureNumber++;
  delay(10000);
void configInitCamera(){
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; //YUV422,GRAYSCALE,RGB565,JPEG
  // Select lower framesize if the camera doesn't support PSRAM
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10; //10-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  s->set_brightness(s, 0);     // -2 to 2
  s->set_contrast(s, 0);       // -2 to 2
  s->set_saturation(s, 0);     // -2 to 2
  s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, 1);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, 1);       // 0 = disable , 1 = enable
  s->set_wb_mode(s, 0);        // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_exposure_ctrl(s, 1);  // 0 = disable , 1 = enable
  s->set_aec2(s, 0);           // 0 = disable , 1 = enable
  s->set_ae_level(s, 0);       // -2 to 2
  s->set_aec_value(s, 300);    // 0 to 1200
  s->set_gain_ctrl(s, 1);      // 0 = disable , 1 = enable
  s->set_agc_gain(s, 0);       // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
  s->set_bpc(s, 0);            // 0 = disable , 1 = enable
  s->set_wpc(s, 1);            // 0 = disable , 1 = enable
  s->set_raw_gma(s, 1);        // 0 = disable , 1 = enable
  s->set_lenc(s, 1);           // 0 = disable , 1 = enable
  s->set_hmirror(s, 0);        // 0 = disable , 1 = enable
  s->set_vflip(s, 0);          // 0 = disable , 1 = enable
  s->set_dcw(s, 1);            // 0 = disable , 1 = enable
  s->set_colorbar(s, 0);       // 0 = disable , 1 = enable
void initMicroSDCard(){
  // Start Micro SD card
  Serial.println("Starting SD Card");
  if(!SD_MMC.begin()){
    Serial.println("SD Card Mount Failed");
    return;
  uint8_t cardType = SD_MMC.cardType();
  if(cardType == CARD_NONE){
    Serial.println("No SD Card attached");
    return;
void takeSavePhoto(String path){
  // Take Picture with Camera
  camera_fb_t  * fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    return;
  // Save picture to microSD card
  fs::FS &fs = SD_MMC;
  File file = fs.open(path.c_str(), FILE_WRITE);
  if(!file){
    Serial.println("Failed to open file in writing mode");
  else {
    file.write(fb->buf, fb->len); // payload (image), payload length
    Serial.printf("Saved file to path: %s\n", path.c_str());
  file.close();
  //return the frame buffer back to the driver for reuse
  esp_camera_fb_return(fb);
what if you properly light up your scene ?
have you tried set_contrast() ?
Thank you J-M-L.
changed: brightness: -2 / 0 / 2; contrast: -2 / 0 / 2; got little changes, is this the ESP32 camera‘s normal effect?
and the flashing seems no much affection?
below pictures taken at indoor cloudy day time:
brightness: 2; contrast: 0 :
brightness: 2; contrast: 2 :
It’s not a great camera - very small « eye » so you need lots of light and it does better close up than in a distance (long time I did not play with it )
I have experimented a lot with the esp32cam and find they are pretty disappointing in low light conditions. They have an IR filter in the camera which you can remove by unscrewing the lens (you may need to warm the lens to soften the glue) and I have even removed the lens and fitted a larger replacement instead but even then they are not great.
The main settings I find useful are:
for auto adjust:
       s->set_gain_ctrl(s, 1);                       // auto gain on
       s->set_exposure_ctrl(s, 1);                   // auto exposure on
       s->set_awb_gain(s, 1);                        // Auto White Balance enable (0 or 1)
       s->set_brightness(s, 1);                     // (-2 to 2) - set brightness
or manual adjustments:
       s->set_gain_ctrl(s, 0);                       // auto gain off
       s->set_exposure_ctrl(s, 0);                   // auto exposure off
       s->set_brightness(s, x);                     // (-2 to 2) - set brightness
       s->set_agc_gain(s, y);          // set gain manually (0 - 30)
       s->set_aec_value(s, z);     // set exposure manually  (0-1200)
BTW - I have a sketch I use for experimenting with the settings etc. which may be of use/interest: https://github.com/alanesq/esp32cam-demo
Thanks.
you are right. the camera is't that good.
Thank you for the settings.
I'll try the link.
BTW. does ESP32CAM be able to connected with TFT by SPI?
