Adafruit_LiquidCrystal no such file or directory
Arduino: 1.8.18 (Windows 10), Board: "Arduino Uno"
sketch_feb18a:2:10: fatal error: Adafruit_LiquidCrystal.h: No such file or directory
compilation terminated.
exit status 1
option enabled in File -> Preferences.
Hi @junzibilat. I'm going to ask you to provide the full verbose output from a compilation.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences...(or Arduino > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Check the box next to "Show verbose output during: ☐ compilation" in the "Preferences" dialog.
  3. Click the "OK" button.
    The "Preferences" dialog will close.
  4. Select Sketch > Verify/Compile from the Arduino IDE menus.
  5. After the compilation fails you'll see a button on the right side of the orange bar in Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  6. Open a forum reply here by clicking the "Reply" button.
  7. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  8. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  9. Move the cursor outside of the code block markup before you add any additional text to your reply.
  10. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Please do not hijack posts; question split to it's own topic.
Did you install the Adafruit_LiquidCrystal library?
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chris Angelo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chris Angelo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chris Angelo\OneDrive\文件\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10818 -build-path C:\Users\CHRISA~1\AppData\Local\Temp\arduino_build_443325 -warnings=none -build-cache C:\Users\CHRISA~1\AppData\Local\Temp\arduino_cache_583989 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Chris Angelo\OneDrive\文件\Arduino\sketch_feb19a\sketch_feb19a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chris Angelo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chris Angelo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chris Angelo\OneDrive\文件\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10818 -build-path C:\Users\CHRISA~1\AppData\Local\Temp\arduino_build_443325 -warnings=none -build-cache C:\Users\CHRISA~1\AppData\Local\Temp\arduino_cache_583989 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Chris Angelo\OneDrive\文件\Arduino\sketch_feb19a\sketch_feb19a.ino
Using board 'uno' from platform in folder: C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Chris Angelo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\Chris Angelo\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Chris Angelo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Chris Angelo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\CHRISA~1\\AppData\\Local\\Temp\\arduino_build_443325\\sketch\\sketch_feb19a.ino.cpp" -o nul
Alternatives for Adafruit_LiquidCrystal.h: [Adafruit_LiquidCrystal@2.0.4]
ResolveLibrary(Adafruit_LiquidCrystal.h)
  -> candidates: [Adafruit_LiquidCrystal@2.0.4]
"C:\\Users\\Chris Angelo\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Chris Angelo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Chris Angelo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\Chris Angelo\\OneDrive\\文件\\Arduino\\libraries\\Adafruit_LiquidCrystal" "C:\\Users\\CHRISA~1\\AppData\\Local\\Temp\\arduino_build_443325\\sketch\\sketch_feb19a.ino.cpp" -o nul
Alternatives for Adafruit_LiquidCrystal.h: [Adafruit_LiquidCrystal@2.0.4]sketch_feb19a:1:10: fatal error: Adafruit_LiquidCrystal.h: No such file or directory
Using library Adafruit_LiquidCrystal at version 2.0.4 in folder: C:\Users\Chris Angelo\OneDrive\文件\Arduino\libraries\Adafruit_LiquidCrystal
exit status 1
so what will happend now?
i did it all so what will happend now?
yes
please help me
Don't use non-ASCII characters in your path or it will lead to issues like this
As @blh64 mentioned, there is a bug in Arduino IDE that causes it to not recognize libraries when they are installed under a path that contains non-ASCII characters (e.g. 文档).
The workaround is to change the location where libraries are stored by Arduino IDE to one that is under a path without any non-ASCII characters. I'll provide instructions you can follow to do that:
  1. Select File > Preferences... from the Arduino IDE menus.
  2. Set the path in the "Sketchbook location" preference to a location that does not contain any non-ASCII characters in its path.
  4. Move the contents of the folder at the previous path of the "Sketchbook location" preference (C:\Users\Chris Angelo\OneDrive\文件\Arduino) to the new location.
