Every time i want to compile normally this unknown error happens
Arduino: 1.8.19 (Windows 10), Board: "Arduin
In file included from C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:15:0:
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\DHT-sensor-library-master\DHT_U.h:36:10: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
And here is my code:
SOLAR SET OF SENSORS
Temperature sensor, humidity sensor, light sensor, soil moisture sensor
DHT11/22, LDR, FC-28-B
#include <DHT.h>
#include <Wire.h>
#include <LCD.h>
#include <RBD_LightSensor.h>
//Constants
#define DHTPIN 4 //DHT PIN ON ARDUINO PIN 4
#define DHTTYPE DHT11 //IF YOU HAVE DHT22 THEN RENAME DHT11 TO DHT22
DHT dht(DHTPIN, DHTTYPE);
#define I2C_ADDR 0x3F //0X3F IS THE ADDRESS OF LCD SCREEN
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
//Variables
int chk;
float hum; //HUMIDITY VALUE
float temp; //TEMPERATURE VALUE
int soil_sensor_pin = A1; //SOIL MOISTRURE SENSOR A0 PIN IS CONNECTED TO ARDUINO PIN A1
float soil_output; //SOIL MOISTURE VALUE
RBD::LightSensor light_sensor(A0); //PHOTORESISTOR IS CONNECTED TO ARDUINO PIN A0
Serial.begin(115200); //START SERIAL MONITOR
dht.begin(); //START DHT SENSOR
lcd.begin(16,2); //START LCD SCREEN
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH); //TURN ON THE LCD BACKLIGHT
//READING VALUES ONCE ON START OF THE LOOP BECAUSE TRANSFERING DATA DRAINS BATTERY MORE
hum = dht.readHumidity(); //READ HUMIDITY VALUE
temp = dht.readTemperature(); //READ TEMPERATURE VALUE
soil_output = analogRead(soil_sensor_pin); //READ SOIL MOISTURE VALUE
soil_output = map(soil_output,550,0,0,100); //CONVERT IT TO % VALUE
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius"); //PRINT VALUES ON SERIAL MONITOR
Serial.print("Light: ");
Serial.println(light_sensor.getPercentValue());
Serial.print("Soil moisture: ");
Serial.print(soil_output);
Serial.println("%");
//PRINT VALUES ON LCD SCREEN
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Temperature:");
lcd.setCursor(0,1);
lcd.print(temp);
lcd.print(" ");
lcd.print((char)223);
lcd.print("C");
delay(4000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Humidity:");
lcd.setCursor(0,1);
lcd.print(hum);
lcd.print("%");
delay(4000); //Delay 2 sec.
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Soil moisture:");
lcd.setCursor(0,1);
lcd.print(soil_output);
lcd.print("%");
delay(4000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Light:");
lcd.setCursor(0,1);
lcd.print(light_sensor.getPercentValue());
lcd.print("%");
delay(4000);
in the same directory:
C:\Users\Omar Sowwan\OneDrive\المستندات\Arduino\libraries\Adafruit_Sensor-master
and i got a very large error:Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
FET3S5PJHATN1NF:33:80: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
In file included from C:\Users\Omar Sowwan\Downloads\FET3S5PJHATN1NF\FET3S5PJHATN1NF.ino:16:0:
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:71:2: note: candidate: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t, uint8_t)
LiquidCrystal_I2C(uint8_t lcd_addr, uint8_t lcd_cols, uint8_t lcd_rows, uint8_t charsize = LCD_5x8DOTS);
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:71:2: note: candidate expects 4 arguments, 8 provided
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:60:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
class LiquidCrystal_I2C : public Print {
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:60:7: note: candidate expects 1 argument, 8 provided
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:60:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal_I2C&&)
C:\Users\Omar Sowwan\Downloads\FET3S5PJHATN1NF\FET3S5PJHATN1NF.ino: In function 'void setup()':
FET3S5PJHATN1NF:49:17: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate: void LiquidCrystal_I2C::begin()
void begin();
C:\Users\Omar Sowwan\OneDrive\���������\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate expects 0 arguments, 2 provided
FET3S5PJHATN1NF:50:7: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'; did you mean 'setBacklight'?
setBacklight
FET3S5PJHATN1NF:50:37: error: 'POSITIVE' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
It is not clear to me what procedure you have followed. I'll provide complete instructions for the procedure you should have followed to work around the bug mentioned by @van_der_decken. You'll have to adapt them according to whatever you have already done:
Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open.
Click the "BROWSE" button on the right side of the "Sketchbook location" field.
The "Select a new sketchbook location" dialog will open.
Select a folder in any location that contains only basic ASCII characters (the characters A-z, 0-9, _, -, . are safe). Make sure to pick a location that will be safe to store your files since, in addition to containing installed libraries, the sketchbook is a convenient location to save your sketches.
Click the "Choose" button in the "Select a new sketchbook location" dialog.
Click the "OK" button in the "Preferences" dialog.
Move all the files from the folder at the path of the old sketchbook location:
: Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:71:2: note: candidate: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t, uint8_t)
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:71:2: note: candidate expects 4 arguments, 8 provided
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:60:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:60:7: note: candidate expects 1 argument, 8 provided
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:60:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal_I2C&&)
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate: void LiquidCrystal_I2C::begin()
void begin();
C:\Users\Omar Sowwan\OneDrive\Desktop\EVERYTHINGarduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate expects 0 arguments, 2 provided
setBacklight
exit status 1
