I am trying to get the Adafruit MAX31865 running with the Nano RP2040 Connect.
However I get the same error as described here: https://forum.arduino.cc/t/nano-rp2040-connect-not-showing-as-a-device-under-ports/864686?page=2. As mentioned by @mrseriousguy there might be a problem with the library and the Nano:
Nano RP2040 Connect not showing as a device under ports - Nano Family / Nano RP2040 Connect - Arduino Forum
#include <Adafruit_MAX31865.h>
Adafruit_MAX31865 my_ada = Adafruit_MAX31865(5);//, 51, 50, 52); // mit Pins funktioniert es,
float temperature;
my_ada.enable50Hz(1);
delay(100);
my_ada.autoConvert(1);
my_ada.begin(MAX31865_2WIRE);
temperature = my_ada.temperature(100, 430);
Serial.print(temperature);
Is there a way to use Adafruit devices with the Nano RP2040?
Thanks in advance!
