Adafruit MPU-6050 and adafruit I2C Multiplexer
I have 3 adafruit MPUs hooked up to adafruit I2c Multiplexer. All of which is hooked up to a Arduino uno.
Attached is also my code.
/* Assign a unique ID to this sensor at the same time */
/*Adafruit_HMC5883_Unified mpu1 = Adafruit_HMC5883_Unified(1);
Adafruit_HMC5883_Unified mpu2 = Adafruit_HMC5883_Unified(2);*/
#define TCAADDR 0x70
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu1 = Adafruit_MPU6050();
Adafruit_MPU6050 mpu2 = Adafruit_MPU6050();
Adafruit_MPU6050 mpu3 = Adafruit_MPU6050();
void displaySensorDetails(Adafruit_MPU6050 *mpu)
sensor_t sensor;
mpu->getGyroSensor();
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
void setUpMPU(Adafruit_MPU6050 *mpu)
  mpu->setAccelerometerRange(MPU6050_RANGE_8_G);
  Serial.print("Accelerometer range set to: ");
  switch (mpu->getAccelerometerRange()) {
  case MPU6050_RANGE_2_G:
    Serial.println("+-2G");
  case MPU6050_RANGE_4_G:
    Serial.println("+-4G");
  case MPU6050_RANGE_8_G:
    Serial.println("+-8G");
  case MPU6050_RANGE_16_G:
    Serial.println("+-16G");
  mpu->setGyroRange(MPU6050_RANGE_500_DEG);
  Serial.print("Gyro range set to: ");
  switch (mpu->getGyroRange()) {
  case MPU6050_RANGE_250_DEG:
    Serial.println("+- 250 deg/s");
  case MPU6050_RANGE_500_DEG:
    Serial.println("+- 500 deg/s");
  case MPU6050_RANGE_1000_DEG:
    Serial.println("+- 1000 deg/s");
  case MPU6050_RANGE_2000_DEG:
    Serial.println("+- 2000 deg/s");
  mpu->setFilterBandwidth(MPU6050_BAND_21_HZ);
  Serial.print("Filter bandwidth set to: ");
  switch (mpu->getFilterBandwidth()) {
  case MPU6050_BAND_260_HZ:
    Serial.println("260 Hz");
  case MPU6050_BAND_184_HZ:
    Serial.println("184 Hz");
  case MPU6050_BAND_94_HZ:
    Serial.println("94 Hz");
  case MPU6050_BAND_44_HZ:
    Serial.println("44 Hz");
  case MPU6050_BAND_21_HZ:
    Serial.println("21 Hz");
  case MPU6050_BAND_10_HZ:
    Serial.println("10 Hz");
  case MPU6050_BAND_5_HZ:
    Serial.println("5 Hz");
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
void setup(void)
while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("HMC5883 Magnetometer Test"); Serial.println("");
/* Initialise the 1st sensor */
tcaselect(0);
mpu1.setAccelerometerRange(MPU6050_RANGE_8_G);
switch(mpu1.getAccelerometerRange()) {
mpu1.setGyroRange(MPU6050_RANGE_500_DEG);
switch (mpu1.getGyroRange()) {
mpu1.setFilterBandwidth(MPU6050_BAND_21_HZ);
switch (mpu1.getFilterBandwidth()) {
/* Initialise the 2 sensor */
tcaselect(1);
mpu2.setAccelerometerRange(MPU6050_RANGE_8_G);
mpu2.setGyroRange(MPU6050_RANGE_500_DEG);
mpu2.setFilterBandwidth(MPU6050_BAND_21_HZ);
/* Initialise the 3rd sensor */
tcaselect(2);
mpu3.setAccelerometerRange(MPU6050_RANGE_8_G);
mpu3.setGyroRange(MPU6050_RANGE_500_DEG);
mpu3.setFilterBandwidth(MPU6050_BAND_21_HZ);
/* Display some basic information on this sensor */
tcaselect(0);
displaySensorDetails(&mpu1);
tcaselect(1);
displaySensorDetails(&mpu2);
tcaselect(2);
void loop(void)
/* Get a new sensor event */
sensors_event_t a, g, temp;
tcaselect(0);
mpu1.getEvent(&a, &g, &temp);
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print("Sensor #1 - ");
//Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" ");
//Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" ");
//Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" ");Serial.println("uT");
Serial.print("Acceleration X: ");
Serial.print(a.acceleration.x);
Serial.print(", Y: ");
Serial.print(a.acceleration.y);
Serial.print(", Z: ");
Serial.print(a.acceleration.z);
Serial.println(" m/s^2");
tcaselect(2);
mpu2.getEvent(&a, &g, &temp);
Serial.print("Sensor #2 - ");
In this configuration All of my mpu sensors are sending back unreasonable numbers for acceleration and temperature. Am I initializing my mpus correctly in my code?
@cchpackers1, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
