Adafruit_SSD1306.h: No such file or directory
Hi devs! i'm new here in this environment. i'm not a programmer, i'm just a mere DIY-ers and making a small project and i found some a nice ideas/project somewhere and i take a look and copy a project and edit etc. and, i just want to know how to fix this says " Adafruit_SSD1306.h: No such file or directory"
C:\Users\dell\Downloads\firmware_2.1\firmware_2.1.ino:9:10: fatal error: Adafruit_SSD1306.h: No such file or directory
9 | #include <Adafruit_SSD1306.h>
compilation terminated.
exit status 1
Compilation error: Adafruit_SSD1306.h: No such file or directory.
i just want to merge some ideas/code from arduino and raspberry pi to make a streaming player.
thanks for understanding even im not good with english...
please see attached photo below:
You should never post in the Uncategorised section.
It says so in the description of the section. Therefore I have moved your post here.
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
Also posting images of code is absolutely useless please don't do it.
Hi Grumpy_Mike! I'm so sorry for making such a mess with this forum, unfortunately, i am having a hard time to find and to know which thread should i post this and the other rules and instruction for posting.
Thanks,
Like I said "Read the description of the section you plan to post in" that is not too hard is it?
If it says "do not post here" then don't. Basically if you don't know then Software or project Guidance is a good place for most questions.
If you post your code, as described in the link I posted then we can see it and therefore try it. You should mention what sort of Arduino you are using as this makes a big difference to how things work.
Hi @kuyadrei_0502.
When you see a "No such file or directory" error like this, it almost always means you need to install the library that contains the missing file.
You can usually use the Arduino IDE Library Manager to install the library. I'll provide instructions you can follow to do that:
  1. Select Sketch > Include Library > Manage Libraries... from the Arduino IDE menus to open the "Library Manager" view in the left side panel.
  2. Type Adafruit SSD1306 in the "Filter your search..." field.
  3. Scroll down through the list of libraries until you see the "Adafruit_SSD1306" entry.
  4. You will see an "INSTALL" button at the bottom of the entry. Click the button.
    An "Install library dependencies" dialog will open.
  5. Click the "INSTALL ALL" button in the "Install library dependencies" dialog.
    The dialog will close.
  6. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    ⓘ Successfully installed library ...
After doing that, try compiling your sketch again. Hopefully it will work as expected this time.
Hi there! Thanks currently i am installing some of libraries. Appreciate your help ans sorry for being idiot here coz I'm trying to learn to this new environment. And i am more aware and careful to do action such as posting without fully reading some rules and regulation here.
Thanks,
Thank you grumpy_Mike. Currently working and installing some libraries to work with my project appreciate your help. Next time I'll more careful to post anything that coz messing with forum.
'some libraries'???? Just one,
Hi sonofcy! i mean some just written here; #include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include 'Adafruit_SSD1306.h'
#include 'Adafruit_GFX.h'
#include 'Fonts/FreeSansBold18pt7b.h'
#include 'Fonts/FreeSans9pt7b.h'
#include 'Fonts/FreeSansBold12pt7b.h'
#include <Wire.h/>
#include <RotaryEncoder.h/>
#include <Button.h/>
Ok, so it's working now?
Yeahh, unfortunately i couldn't install thr correct/right library for rotary encoder. I show something like this.
C:\Users\dell\Downloads\firmware_2.1\firmware_2.1.ino:531:3: error: 'encoder' was not declared in this scope
531 | encoder->tick();
exit status 1
Compilation error: 'RotaryEncoder' does not name a type; did you mean 'RotaryEncoder_h'?
And here's my full code down below i hope is it allowed here.
include <KY040rotary.h>
#include <KY040rotary.h>
#include <dummy.h>
#include <Wire.h>
#include "SSD1306Wire.h"
#include <Adafruit_GFX.h>
#include <Fonts/FreeSansBold18pt7b.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSansBold12pt7b.h>
#include <Wire.h>
#include <RotaryEncoder.h>
#include <Button.h>
PiCorePlayer volume control onkyo [http]
Nik Reitmann
04.11.2023
Version: 2.1
CHANGELOG 2.0
  • parse onkyo http get request to variable
  • send volume up/down to openhab via http rest
  • display volume
  • added rescheduling for display timeout
  • parse harmony activity http get request to variable
  • switch for show logo instead of blank screen
  • added start "Musik" rest when knoob pressed
  • added variable for flip display rotation
  • added http get for kitchentimer display
  • created a function for display splashscreen
  • added long press knoob funktion (harmony -> powerOff)
CHANGELOG 2.1
  • added http timeout
  • remove rotatation timeout
  • remove wl connected contidion in main loop
INFO
displaystate
0 = off
1 = onkyo volume
2 = kitchentimer
3 = splashscreen
//CONFIG_BEGIN__________
/// pin definitions
//rotary encoder
#define PIN_IN1 D5
#define PIN_IN2 D6
Button knoob_button (D7);
const int KNOOB_BUTTON_PIN = D7;
// long press time [ms]
const int KNOOB_LONG_PRESS_TIME = 1200;
// set WiFi credentials
#define ssid "YOUR-SSID"
#define password "YOUR-WIFI-PW"
// WiFi connect timeout [ms]
const uint32_t connectTimeoutMs = 5000;
// HTTP timeout [ms]
unsigned long http_timeout = 500;
/// URLs FOR HTTP CLIENT
String serverName = "http://192.168.1.10:8080/";
//HTTP GET
String http_vol_get = "rest/items/onkyo_Volume/state";
String http_activity_get = "rest/items/harmony_wohnzimmer_activity/state";
String http_kitchentimer_get = "rest/items/timer_remain/state";
// HTTP POST
String http_activity_control_musik = "basicui/CMD?harmony_wohnzimmer_activity=Musik";
String http_activity_control_poweroff = "basicui/CMD?harmony_wohnzimmer_activity=PowerOff";
String http_vol_plus = "basicui/CMD?picore_onkyo_vol_plus=ON";
String http_vol_minus = "basicui/CMD?picore_onkyo_vol_minus=ON";
// ROTARY ENCODER DELAY
unsigned long knoob_delay = 0; //ROTATION DELAY
///DISPLAY
// set screen resolution
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
// display rotation 0=0° / 1=90° / 2=180° / 3=270°
int display_rotation = 2;
// display power timeout [ms]
unsigned long display_timeout = 4000;
// kitchen timer threshold < [min]
int kitchen_timer_threshold = 3;
//CONFIG_END____________
//STRINGS
String onkyo_volume_current_http;
String harmony_activity;
String kitchentimer_remain_http;
//STATES
int kitchentimer_previous = 0;
int kitchentimer_remain = 0;
int harmony_music = 0;
int displaystate = 0;
int onkyo_volume_previous;
int onkyo_volume_current;
//TIMER
unsigned long lastTime_knoob_left = 0;
unsigned long lastTime_knoob_right = 0;
unsigned long lastTime_knoob_encoder = 0;
long display_timer = 0;
//LONG PRESS KNOOB
int knoob_lastState = LOW;
int knoob_currentState;
unsigned long knoob_pressedTime = 0;
bool knoob_isPressing = false;
bool knoob_isLongDetected = false;
RotaryEncoder *encoder = nullptr;
//WIFI
ESP8266WiFiMulti WiFiMulti;
//DISPLAY
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// splashscreen data [EDJE logo]
static const uint8_t EDJE_logo[1024] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8,
0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8,
0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc,
0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe,
0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe,
0x7e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7e,
0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e,
0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e,
0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e,
0x78, 0x07, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x18, 0x03, 0x87, 0x0f, 0x03, 0xc0, 0x1e,
0x78, 0x07, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x1c, 0x03, 0x87, 0x0f, 0x07, 0x80, 0x1e,
0x78, 0x07, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x1e, 0x03, 0x87, 0x0f, 0x0f, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x1f, 0x03, 0x87, 0x0f, 0x0f, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x1f, 0x03, 0x87, 0x0f, 0x1e, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0x1e, 0x00, 0x3e, 0x1e, 0xf8, 0x1f, 0x83, 0x87, 0x0f, 0x3c, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0x7f, 0x80, 0xff, 0x9f, 0xfc, 0x1f, 0xc3, 0x87, 0x0f, 0x3c, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0xff, 0xc1, 0xff, 0x9f, 0xfe, 0x1f, 0xc3, 0x87, 0x0f, 0x78, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x01, 0xf3, 0xe3, 0xe3, 0x1f, 0x9e, 0x1f, 0xe3, 0x87, 0x0f, 0xf0, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x01, 0xe1, 0xe3, 0xc0, 0x1e, 0x0f, 0x1f, 0xf3, 0x87, 0x0f, 0xf0, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x03, 0xff, 0xf7, 0x80, 0x1e, 0x0f, 0x1e, 0x7f, 0x87, 0x0f, 0xfc, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x03, 0xff, 0xf7, 0x80, 0x1e, 0x0f, 0x1e, 0x3f, 0x87, 0x0f, 0xfc, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x03, 0xff, 0xe7, 0x80, 0x1e, 0x0f, 0x1e, 0x1f, 0x87, 0x0f, 0x9e, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x03, 0xc0, 0x07, 0x80, 0x1e, 0x0f, 0x1e, 0x1f, 0x87, 0x0f, 0x1e, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x03, 0xc0, 0x07, 0x80, 0x1e, 0x0f, 0x1e, 0x0f, 0x87, 0x0f, 0x0f, 0x00, 0x1e,
0x78, 0x00, 0x1e, 0x01, 0xe0, 0x03, 0xc0, 0x1e, 0x0f, 0x1e, 0x07, 0x87, 0x0f, 0x0f, 0x80, 0x1e,
0x78, 0x00, 0x1e, 0x01, 0xf1, 0x83, 0xe3, 0x1e, 0x0f, 0x1e, 0x07, 0x87, 0x0f, 0x07, 0x80, 0x1e,
0x78, 0x00, 0x1e, 0x01, 0xff, 0xc3, 0xff, 0x9e, 0x0f, 0x1e, 0x03, 0x87, 0x0f, 0x07, 0xc0, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0x7f, 0xc0, 0xff, 0x9e, 0x0f, 0x1e, 0x01, 0x87, 0x0f, 0x03, 0xc0, 0x1e,
0x78, 0x00, 0x1e, 0x00, 0x3f, 0x00, 0x7e, 0x0e, 0x07, 0x1e, 0x01, 0x87, 0x0f, 0x01, 0xe0, 0x1e,
0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xfe,
0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc,
0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0,
IRAM_ATTR void checkPosition()
encoder->tick();
//SETUP_LOOP_______
// setup the rotary encoder functionality
encoder = new RotaryEncoder(PIN_IN1, PIN_IN2, RotaryEncoder::LatchMode::FOUR3);
//knoob button begin
knoob_button.begin();
// register interrupt routine
attachInterrupt(digitalPinToInterrupt(PIN_IN1), checkPosition, CHANGE);
attachInterrupt(digitalPinToInterrupt(PIN_IN2), checkPosition, CHANGE);
// open serial connection
Serial.println("");
Serial.println("serial connection is ready");
// check if display is connected
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
// clear display
display.clearDisplay();
display.setRotation(display_rotation);
// draw splashscreen on the screen
Serial.println("display: splashscreen");
display.drawBitmap(0, 0, EDJE_logo, 128, 64, 1);
display.display();
displaystate = 3;
// wifi setup
WiFi.mode(WIFI_STA);
WiFiMulti.addAP(ssid, password);
if ((WiFiMulti.run() == WL_CONNECTED)) {
Serial.print("wifi connected to: ");
Serial.println(WiFi.SSID());
Serial.print("IP address is: ");
//HTTP_POST_FUNCTIONS_______
// POWER OFF
void http_post_power_off(){
WiFiClient client;
HTTPClient http;
// do http POST
String poweroff_harmony_string = serverName + http_activity_control_poweroff;
http.setTimeout(http_timeout);
http.begin(client, poweroff_harmony_string);
http.addHeader("Content-Type", "application/json");
int httpCode = http.GET();
http.end();
// MUSIC ON
void http_post_music_on(){
WiFiClient client;
HTTPClient http;
// do http POST
String start_music_string = serverName + http_activity_control_musik;
http.begin(client, start_music_string);
http.end();
// VOLUME UP
void http_post_vol_up(){
WiFiClient client;
HTTPClient http;
// do http POST
String vol_plus_string = serverName + http_vol_plus;
http.begin(client, vol_plus_string);
http.end();
// VOLUME DOWN
void http_post_vol_down(){
WiFiClient client;
HTTPClient http;
// do http POST
String vol_minus_string = serverName + http_vol_minus;
http.begin(client, vol_minus_string);
http.end();
//HTTP_GET_FUNCTIONS________
// ONKYO VOLUME
void http_get_onkyo_volume(){ // --> RESULT = onkyo_volume_current value
WiFiClient client;
HTTPClient http;
if (http.begin(client, serverName + http_vol_get)) {  // HTTP
  // start connection and send HTTP header
  // httpCode will be negative on error
  if (httpCode > 0) {
    // HTTP header has been send and Server response header has been handled
    String onkyo_volume_current_http = http.getString();
    onkyo_volume_current_http.trim();
    onkyo_volume_current = onkyo_volume_current_http.toInt();
  }else{
    Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
  http.end();
}else{
  Serial.println("[HTTP] Unable to connect");
// HARMONY ACTIVITY
void http_get_harmony_activity(){ // --> RESULT = harmony_music = 1 or 0
WiFiClient client;
HTTPClient http;
if (http.begin(client, serverName + http_activity_get)) {  // HTTP
  if (httpCode > 0) {
    String harmony_activity = http.getString();
    harmony_activity.trim();
    // string to int variable
    if (harmony_activity == "Musik"){
      harmony_music = 1;
      harmony_music = 0;
  }else{
  http.end();
}else{
// KITCHENTIMER
void http_get_kitchentimer(){ // --> RESULT = kitchentimer_remain value
WiFiClient client;
HTTPClient http;
if (http.begin(client, serverName + http_kitchentimer_get)) {  // HTTP
  if (httpCode > 0) {
    String kitchentimer_remain_http = http.getString();
    kitchentimer_remain_http.trim();
    kitchentimer_remain = kitchentimer_remain_http.toInt();
  }else{
  http.end();
}else{
//DISPLAY_FUNCTIONS________
void display_splashscreen() {
display.display();
void display_volume() {
Serial.print("draw: ");
Serial.print(onkyo_volume_current);
Serial.println(" to display");
//draw to display
display.setFont(&FreeSansBold18pt7b);
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(24, 55); // left/right, up/down
display.print(onkyo_volume_current);
display.display();
void display_kitchentimer(){
Serial.println("kitchen_timer_threshold reached");
Serial.print(kitchentimer_remain);
Serial.println(" min. to display");
//draw first line to display
display.setFont(&FreeSans9pt7b);
display.setTextSize(1);
display.setCursor(13, 12); // left/right, up/down
display.print("Timer noch:");
//draw second line to display
display.setFont(&FreeSansBold12pt7b);
display.setCursor(0, 56); // left/right, up/down
display.print(kitchentimer_remain);
display.println(" min.");
display.display();
void display_clear(){
display.display();
//MAIN_LOOP_______
//___________________________________HTTP GET
http_get_onkyo_volume();
http_get_harmony_activity();
http_get_kitchentimer();
//___________________________________ROTARY AND BUTTONS
// volume control by rotary encoder
encoder->tick();
int dir = (int)encoder->getDirection();
lastTime_knoob_encoder = millis();
if(dir != 0){
if(dir == 1){
  if ((millis() - lastTime_knoob_right) > knoob_delay) {
    Serial.println("knoob rotate right");
    http_post_vol_up();
  lastTime_knoob_right = millis();
else if(dir == -1){
  if ((millis() - lastTime_knoob_left) > knoob_delay) {
    Serial.println("knoob rotate left");
    http_post_vol_down();
  lastTime_knoob_left = millis();
// harmony activity "Musik" ON by knoob pressed short
if (knoob_button.pressed()){
Serial.println("knoob: short press");
if(harmony_music == 0){
  Serial.println("start harmony activity music");
  http_post_music_on();
// harmony "poweroff" by knoob pressed long
knoob_currentState = digitalRead(KNOOB_BUTTON_PIN);
if(knoob_lastState == HIGH && knoob_currentState == LOW) {
knoob_pressedTime = millis();
knoob_isPressing = true;
else if(knoob_lastState == LOW && knoob_currentState == HIGH) {
if(knoob_isPressing == true && knoob_isLongDetected == false) {
long pressDuration = millis() - knoob_pressedTime;
if( pressDuration > KNOOB_LONG_PRESS_TIME ) {
  Serial.println("knoob: long press");
  knoob_isLongDetected = true;
  Serial.println("harmony: poweroff");
  http_post_power_off();
knoob_lastState = knoob_currentState;
//___________________________________DISPLAY FUNCTIONS
// print onkyo volume to display if changed
if(onkyo_volume_previous != onkyo_volume_current && displaystate != 2){
onkyo_volume_previous = onkyo_volume_current;
if(harmony_music == 1){
  display_volume();
  displaystate = 1;
  // reset display timer
  display_timer = millis();
}else{
  if(displaystate != 2){
    displaystate = 0;
// print kitchentimer remain to display if changed
if(kitchentimer_previous != kitchentimer_remain){
kitchentimer_previous = kitchentimer_remain;
if (kitchentimer_remain <= kitchen_timer_threshold) {
  if(kitchentimer_remain != 0){
    display_kitchentimer();
    displaystate = 2;
      display_clear();
      displaystate = 0;
    }else{
      display_splashscreen();
      displaystate = 3;
//___________________________________DISPLAY CONTROLLER
displaystate
0 = off
1 = onkyo volume
2 = kitchentimer
3 = splashscreen
// display timer -> show logo or clear
if(displaystate != 0 && displaystate != 2){
  if (millis() > display_timeout + display_timer && displaystate != 3){
    // reset timer
    displaystate = 3;
}else{
  if(displaystate == 3){
    //reset timer
    display_clear();
    displaystate = 0;
}else{
  //reset timer
  display_clear();
  displaystate = 0;
// show logo at music start
if(harmony_music == 1 && displaystate == 0 && displaystate != 3){
//reset timer
displaystate = 3;
// clear display if power off while volume is printed
if(harmony_music == 0 && displaystate == 1){
//reset timer
display_clear();
displaystate = 0;
The first thing you need to do is read the tutorial on how to use the forum. Code must be posted in code tags, must be Auto Formatted.
A quick look at your sketch shows two rotary encoder libraries. get rid of the
#include <KY040rotary.h> all you need is #include <RotaryEncoder.h>
Also what is all that stuff beginning with
PiCorePlayer volume control onkyo [HTTP]
Not needed
Hi sonofcy! apology for my late response . i already took out all those line with picorePlayer control.
i also delete the 'include 'KY040rotary.h' and i run a verify/compile and the result still the same and no idea which right library should i call for this . thanks
here are the message saying...
C:\Users\dell\Downloads\firmware_2.1\firmware_2.1.ino:529:3: error: 'encoder' was not declared in this scope
529 | encoder->tick();
exit status 1
