Hi again
here is all the error message, there is a LOT.
Hope this helps
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_Motor_Shield_V2_Library\Adafruit_MotorShield.cpp.o (symbol from plugin): In function `Adafruit_MotorShield::begin(unsigned int, TwoWire*)':
(.text+0x0): multiple definition of `Adafruit_MotorShield::begin(unsigned int, TwoWire*)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_Motor_Shield_V2_Library\Adafruit_MotorShield - Copy.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `Adafruit_MotorShield::setPWM(unsigned char, unsigned int)'
(.text+0x0): multiple definition of `Adafruit_MotorShield::setPin(unsigned char, bool)'
(.text+0x0): multiple definition of `Adafruit_MotorShield::getMotor(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_MotorShield::getStepper(unsigned int, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DCMotor::Adafruit_DCMotor()'
(.text+0x0): multiple definition of `Adafruit_MotorShield::Adafruit_MotorShield(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DCMotor::run(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DCMotor::setSpeed(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_DCMotor::setSpeedFine(unsigned int)'
(.text+0x0): multiple definition of `Adafruit_DCMotor::fullOn()'
(.text+0x0): multiple definition of `Adafruit_DCMotor::fullOff()'
(.text+0x0): multiple definition of `Adafruit_StepperMotor::Adafruit_StepperMotor()'
(.text+0x0): multiple definition of `Adafruit_StepperMotor::setSpeed(unsigned int)'
(.text+0x0): multiple definition of `Adafruit_StepperMotor::release()'
(.text+0x0): multiple definition of `Adafruit_StepperMotor::onestep(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_StepperMotor::step(unsigned int, unsigned char, unsigned char)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_Motor_Shield_V2_Library\utility\Adafruit_MS_PWMServoDriver.cpp.o (symbol from plugin): In function `Adafruit_MS_PWMServoDriver::Adafruit_MS_PWMServoDriver(unsigned char)':
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::Adafruit_MS_PWMServoDriver(unsigned char)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_Motor_Shield_V2_Library\utility\Adafruit_MS_PWMServoDriver - Copy.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::setPWM(unsigned char, unsigned int, unsigned int)'
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::read8(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::write8(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::reset()'
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::begin(TwoWire*)'
(.text+0x0): multiple definition of `Adafruit_MS_PWMServoDriver::setPWMFreq(float)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o (symbol from plugin): In function `Adafruit_BusIO_Register::Adafruit_BusIO_Register(Adafruit_I2CDevice*, unsigned int, unsigned char, unsigned char, unsigned char)':
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::Adafruit_BusIO_Register(Adafruit_I2CDevice*, unsigned int, unsigned char, unsigned char, unsigned char)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_BusIO\Adafruit_BusIO_Register - Copy.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::Adafruit_BusIO_Register(Adafruit_SPIDevice*, unsigned int, _Adafruit_BusIO_SPIRegType, unsigned char, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::Adafruit_BusIO_Register(Adafruit_I2CDevice*, Adafruit_SPIDevice*, _Adafruit_BusIO_SPIRegType, unsigned int, unsigned char, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::write(unsigned char*, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::write(unsigned long, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::readCached()'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::read(unsigned char*, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::read()'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::read(unsigned int*)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::read(unsigned char*)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::print(Stream*)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::println(Stream*)'
(.text+0x0): multiple definition of `Adafruit_BusIO_RegisterBits::Adafruit_BusIO_RegisterBits(Adafruit_BusIO_Register*, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_RegisterBits::read()'
(.text+0x0): multiple definition of `Adafruit_BusIO_RegisterBits::write(unsigned long)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::width()'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::setWidth(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::setAddress(unsigned int)'
(.text+0x0): multiple definition of `Adafruit_BusIO_Register::setAddressWidth(unsigned int)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o (symbol from plugin): In function `Adafruit_I2CDevice::Adafruit_I2CDevice(unsigned char, TwoWire*)':
(.text+0x0): multiple definition of `Adafruit_I2CDevice::Adafruit_I2CDevice(unsigned char, TwoWire*)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_BusIO\Adafruit_I2CDevice - Copy.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `Adafruit_I2CDevice::end()'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::detected()'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::begin(bool)'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::write(unsigned char const*, unsigned int, bool, unsigned char const*, unsigned int)'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::_read(unsigned char*, unsigned int, bool)'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::read(unsigned char*, unsigned int, bool)'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::write_then_read(unsigned char const*, unsigned int, unsigned char*, unsigned int, bool)'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::address()'
(.text+0x0): multiple definition of `Adafruit_I2CDevice::setSpeed(unsigned long)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o (symbol from plugin): In function `Adafruit_SPIDevice::Adafruit_SPIDevice(signed char, unsigned long, _BitOrder, unsigned char, SPIClass*)':
(.text+0x0): multiple definition of `Adafruit_SPIDevice::Adafruit_SPIDevice(signed char, unsigned long, _BitOrder, unsigned char, SPIClass*)'
C:\Users\User\AppData\Local\Temp\arduino\sketches\9566D567CA748F27F5D59E416AE65AB1\libraries\Adafruit_BusIO\Adafruit_SPIDevice - Copy.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `Adafruit_SPIDevice::Adafruit_SPIDevice(signed char, signed char, signed char, signed char, unsigned long, _BitOrder, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::~Adafruit_SPIDevice()'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::begin()'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::transfer(unsigned char*, unsigned int)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::transfer(unsigned char)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::beginTransaction()'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::endTransaction()'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::setChipSelect(int)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::beginTransactionWithAssertingCS()'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::endTransactionWithDeassertingCS()'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::write(unsigned char const*, unsigned int, unsigned char const*, unsigned int)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::read(unsigned char*, unsigned int, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::write_then_read(unsigned char const*, unsigned int, unsigned char*, unsigned int, unsigned char)'
(.text+0x0): multiple definition of `Adafruit_SPIDevice::write_and_read(unsigned char*, unsigned int)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
I closed the sketch and reopened it, and recompiled it, does this all relate to just one try of compiling or is it cumulative.
Thank you for your efforts with this problem.
Regards
Ian Rusch
