Adapting a motor driver l298d from Ardumoto to a l298n motor driver from Keyestudio
Hello! I was wondering how could I adapt a l298d motor driver in a project that uses Keyestudio's l298n motor driver (https://wiki.keyestudio.com/index.php/Ks0192_keyestudio_4WD_Bluetooth_Multi-functional_Car#Project_6:_L298N_Motor_Driver).
My motor driver from Keyestudio was both defective (motorA didn't respond) and my groupmate fried it, thus I had to change it, but the only one that could be provided to me was an l298d motor driver from ardumoto. Help? I don't have much experience in Arduino overall and this project is due tomorrow.
BONUS: I had to change the sensor shield too, drom a Keyestudio sensor shield v5.1 to a Tinyos(? sensor shield, but the similarities between both are more palpable (though I don't see the IIC section that Keyestudio's sensor shield has ? that could be a problem.
Thank you in advance if you see this, please help me!!!
You have the two devices what is the difference between the two?
don't know how to explain it, but the defective motor driver didn't connect directly to the arduino, ardumoto's one does. plus keyestudio's motor driver contains ENA IN1 IN2 IN3 IN4 ENB and ardumoto's motor driver doesn't.
Plus, I don't know how problematic it could be with the sensor driver
Well, neither can I !. Suppose you show a picture of each device as soon as you can. What does the Ardumoto driver show for connections?
motor shield
keyestudio
the first one is the new one i want to adapt and the other one is the project uses. So sorry for inconveniences
The new device is called a "shield". You have the documentation. There are whole bunch of features on the shield. What, exactly, do you want it to do and don't write that you want it to do what that other board did. The other board was destroyed and you do not want to do that.
sorry english isn't my first language, I won't use the other driver but rather had issues adapting and wanted to know what were the changes that could be applied. I researched and found a way to make it work! Thank you for replying I think everything should go smoothly, hope you have a nice day/night
