This chip seems to have it's own 2.5volt reference.
So 0-2.5volt should give a value of 0-4095.
Is this chip mounted on a breakout board (link).
How do you supply the Micro and this board.
Post a diagram and/or picture of your setup/wiring.
And the code (inside code tags).
Leo..
i tried with internal reference voltage , ext Vref = 0, Vdd = 5v. i gave. Yes it is going till 4095. but value is not constant when i gave constant 3.3v at ch0 analog pin.
Even at no signal at analog channel input, during initial reading it gives 0 value. when i try to read frequently it gives some decimal values like 30,40,..
but when i try to read with sufficient time interval between two adc.read i am getting 0v.
i am confused much,...
