Have a working thermocouple displaying values to an adafruit hxd8357d 3.5" display from an uno. They are also displayed via bar graph, which works nicely. I have been trying to get color gradients though as the bar graph moves.
Intention is to have multiple sensors (pressure, temperature, etc) read out to the screen, each with a bar graph and values displayed.
I’ve seen some of bodmer’s libraries etc, but have been unable to get it to work with my hardware. Well, I did after extensive library changes, but the values would not display, so I scrapped it and started over.
Here’s my current project.
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_HX8357.h"
#include "Adafruit_MAX31855.h"
// Assign human-readable names to some common 16-bit color values:
#define LTBLUE 0xB6DF
#define LTTEAL 0xBF5F
#define LTGREEN 0xBFF7
#define LTCYAN 0xC7FF
#define LTRED 0xFD34
#define LTMAGENTA 0xFD5F
#define LTYELLOW 0xFFF8
#define LTORANGE 0xFE73
#define LTPINK 0xFDDF
#define LTPURPLE 0xCCFF
#define LTGREY 0xE71C
#define BLUE 0x001F
#define TEAL 0x0438
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define ORANGE 0xFD20
#define PINK 0xF81F
#define PURPLE 0x801F
#define GREY 0xC618
#define WHITE 0xFFFF
#define BLACK 0x0000
#define DKBLUE 0x000D
#define DKTEAL 0x020C
#define DKGREEN 0x03E0
#define DKCYAN 0x03EF
#define DKRED 0x6000
#define DKMAGENTA 0x8008
#define DKYELLOW 0x8400
#define DKORANGE 0x8200
#define DKPINK 0x9009
#define DKPURPLE 0x4010
#define DKGREY 0x4A49
// These are 'flexible' lines that can be changed
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST -1 // RST can be set to -1 if you tie it to Arduino's reset
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
// SoftSPI - note that on some processors this might be *faster* than hardware SPI!
//Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, MOSI, SCK, TFT_RST, MISO);
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO 2
#define MAXCS 3
#define MAXCLK 4
// Initialize the Thermocouple
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// Example creating a thermocouple instance with hardware SPI
// on a given CS pin.
//#define MAXCS 3
//Adafruit_MAX31855 thermocouple(MAXCS);
int high = 0;
int low = 1500;
int egt;
boolean graph_1 = true;
tft.begin();
Serial.println("HX8357D Test!");
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(HX8357_RDPOWMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDCOLMOD);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDDIM);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDDSDR);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
tft.setRotation(0);
tft.fillScreen(HX8357_BLACK);
tft.fillScreen(HX8357_RED);
Serial.println("MAX31855 test");
// wait for MAX chip to stabilize
Serial.print("Initializing sensor...");
if (!thermocouple.begin()) {
Serial.println("ERROR.");
while (1) delay(10);
Serial.println("DONE.");
egt = (thermocouple.readFahrenheit());
DrawBarChartH(tft, 30, 70, 200, 30, 0, 2000, .5, egt, 4, 0, GREEN, DKGREEN, GREEN, WHITE, BLACK, "EGT", graph_1);
//Store and Display High Temperature Readings
HighReadings(tft, 180, 15, 4, 0);
//Store and Display Low Temperature Readings
LowReadings(tft, 10, 15, 4, 0);
delay(250);
void DrawBarChartH(Adafruit_HX8357 & d, double x , double y , double w, double h , double loval , double hival , double inc , double curval ,
int dig , int dec, unsigned int barcolor, unsigned int voidcolor, unsigned int bordercolor, unsigned int textcolor,
unsigned int backcolor, String label, boolean & redraw){
double stepval, range;
double mx, level;
double i, data;
// draw the border, scale, and label once
// avoid doing this on every update to minimize flicker
// draw the border and scale
if (redraw == true) {
redraw = false;
d.drawRect(x , y , w, h, bordercolor);
d.setTextColor(textcolor, backcolor);
d.setTextSize(2);
d.setCursor(x , y - 20);
d.println(label);
// step val basically scales the hival and low val to the width
stepval = inc * (double (w) / (double (hival - loval))) - .00001;
// draw the text
for (i = 0; i <= w; i += stepval) {
d.drawFastVLine(i + x , y + h + 1, 5, textcolor);
// draw lables
d.setTextSize(1);
d.setCursor(i + x , y + h + 10);
// addling a small value to eliminate round off errors
// this val may need to be adjusted
data = ( i * (inc / stepval)) + loval + 0.00001;
d.println(Format(data, dig, dec));
// compute level of bar graph that is scaled to the width and the hi and low vals
// this is needed to accompdate for +/- range capability
// draw the bar graph
// write a upper and lower bar to minimize flicker cause by blanking out bar and redraw on update
level = (w * (((curval - loval) / (hival - loval))));
d.fillRect(x + level + 1, y + 1, w - level - 2, h - 2, voidcolor);
d.fillRect(x + 1, y + 1 , level - 1, h - 2, barcolor);
// write the current value
d.setTextSize(2);
d.setCursor(x + w + 10 , y + 5);
d.println(Format(curval, dig, dec));
void HighReadings(Adafruit_HX8357 & d, double x, double y, int dig, int dec)
if(egt>high){
d.setCursor(x,y);
d.setTextSize(4);
tft.print(Format(egt, dig, dec));
high=egt;
void LowReadings(Adafruit_HX8357 & d, double x, double y, int dig, int dec)
if(egt<low){
d.setCursor(x,y);
d.setTextSize(4);
low=egt;
String Format(double val, int dec, int dig ) {
int addpad = 0;
char sbuf[20];
String condata = (dtostrf(val, dec, dig, sbuf));
int slen = condata.length();
for ( addpad = 1; addpad <= dec + dig - slen; addpad++) {
condata = " " + condata;
return (condata);
