nahiko -
Thanks for the quick response. I have no idea if they're i2c or not. I've been told to try the code at the end of this post but it leave me scratching my head - I don't know where to attach the clock & data pins, the strip documentation is missing.
about the 5v... I've seen some documentation suggest I need as much as 1a/m to send the address&value to each "pixel" on the strip. This is frightening - I imagine the whole strip melting.
#include <TimerOne.h>
//Example to control 10 RGB LED Modules.
//Bliptronics.com
//Ben Moyes 2009
//Use this as you wish, but please give credit, or at least buy some of my LEDs!
// Choose which 2 pins you will use for output.
// Can be any valid output pins.
int clockPin = 2; // connect to
int dataPin = 3; // connect to
byte SendMode=0; // Used in interrupt 0=start,1=header,2=data,3=data done
byte BitCount=0; // Used in interrupt
byte LedIndex=0; // Used in interrupt - Which LED we are sending.
byte BlankCounter=0; //Used in interrupt.
unsigned int BitMask; //Used in interrupt.
//Holds the 15 bit RGB values for each LED.
//You'll need one for each LED, we're using 10 LEDs here.
//Note you've only got limited memory on the Arduino, so you can only control
//Several hundred LEDs on a normal arduino. Double that on a Duemilanove.
unsigned int Display[10];
byte Counter;
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// Turn all LEDs off.
for(Counter=0;Counter < 10; Counter++)
Display[Counter]=Color(Counter,0,31-Counter);
show();
Timer1.initialize(25); // initialize timer1, 25 microseconds refresh rate.
Timer1.attachInterrupt(LedOut); // attaches callback() as a timer overflow interrupt
//Interrupt routine.
//Frequency was set in setup(). Called once for every bit of data sent
//In your code, set global Sendmode to 0 to re-send the data to the pixels
//Otherwise it will just send clocks.
void LedOut()
switch(SendMode)
case 3: //Done..just send clocks with zero data
digitalWrite(dataPin, 0);
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW);
case 2: //Sending Data
if (BitCount==0) //First bit is always 1
{ digitalWrite(dataPin, 1);
BitMask=0x8000;//Init bit mask
else if(BitMask & Display[LedIndex]) //If not the first bit then output the next bits (Starting with MSB bit 15 down.)
BitMask>>=1;
BitCount++;
if(BitCount == 16) //Last bit?
LedIndex++; //Move to next LED
if (LedIndex < 10) //Still more leds to go or are we done?
BitCount=0; //Start from the fist bit of the next LED
SendMode=3; //No more LEDs to go, we are done!
// Clock out data.
case 1: //Header
if (BitCount < 32)
BitCount++;
if(BitCount==32)
SendMode++; //If this was the last bit of header then move on to data.
LedIndex=0;
BitCount=0;
case 0: //Start
if(!BlankCounter) //AS SOON AS CURRENT pwm IS DONE. BlankCounter
BitCount=0;
LedIndex=0;
SendMode=1;
//Keep track of where the LEDs are at in their pwm cycle.
BlankCounter++;
void show() {
// The interrupt routine will see this as re-send LED color data.
SendMode = 0;
// Create a 15 bit color value from R,G,B
unsigned int Color(byte r, byte g, byte b) {
//Take the lowest 5 bits of each value and append them end to end
return( ((unsigned int)g & 0x1F )<<10 | ((unsigned int)b & 0x1F)<<5 | (unsigned int)r & 0x1F);
// Show a colour bar going up from 0 to 9
void ColorUp( unsigned int ColourToUse) {
byte Counter;
for(Counter=0;Counter < 10; Counter++) {
Display[Counter]=ColourToUse;
show();
delay(25);
// Show a colour bar going down from 9 to 0
void ColorDown( unsigned int ColourToUse) {
byte Counter;
for(Counter=10;Counter > 0; Counter--) {
Display[Counter-1]=ColourToUse;
show();
delay(25);
//Input a value 0 to 127 to get a color value.
//The colours are a transition r - g -b - back to r
unsigned int Wheel(byte WheelPos) {
byte r,g,b;
switch(WheelPos >> 5) {
case 0:
r=31- WheelPos % 32; //Red down
g=WheelPos % 32; // Green up
b=0; //blue off
case 1:
g=31- WheelPos % 32; //green down
b=WheelPos % 32; //blue up
r=0; //red off
case 2:
b=31- WheelPos % 32; //blue down
r=WheelPos % 32; //red up
g=0; //green off
return(Color(r,g,b));
unsigned int Counter, Counter2, Counter3;
// Lets show some demo patterns.
// Just change Display array, then set SendMode to 0
//Spin LED with colour changing
for(Counter=0;Counter < 10;Counter++) {
for(Counter2=0; Counter2 < 10 ; Counter2++) {
Display[Counter2] = Wheel(Counter * 10 + Counter2);
show();
delay(25);
Display[Counter2] = Color(0,0,0) ;
show();
//Scrolling Rainbow Effect
for(Counter=0; Counter < 200 ; Counter++) {
Counter3=Counter * 1;
for(Counter2=0; Counter2 < 10; Counter2++) {
Display[Counter2] = Wheel(Counter3%95); //There's only 96 colors in this pallette.
Counter3+=10;
show();
delay(25);
//Color wipes.
for(Counter=0;Counter < 2;Counter++) {
ColorUp(Color(random(0,32),random(0,32),random(0,32)));
ColorDown(Color(random(0,32),random(0,32),random(0,32)));
