Hello, I am using Arduino Uno and ADS1115 ADC module to read two voltages, shunt voltage on across a resistor (current) and input voltage from a voltage divider resistor. The signals will be used to generate a refrence control signal to drive a half bridge converter. The problem i am facing is that i get inverted reading for both of the signals, all the 4 ADS1115 analog channels are giving inverted readings, multiplying the values by -1 gives the correct signal but the values goes to negative, and this is not siutable for my application. Using the Arduino inbuilt ADC gives correct values but the ADC resolution is a little poor since i need very accutare signal. How can i get the real signal to view same as it can be seen on the oscilloscope, and is it possible to configure the ADS1115 module to show readings from 0 to the DAC max value, same as in Arduino inbuilt ADC while getting rid of the negative side since i am only reading positive voltage. I mostly deal with hardware and have little understaing of software. below are the waveforms from cope and serial monitor
Hello and welcome. Please take a few minutes and read How to get the best out of this forum . If you follow the recommendations there, you will make it possible for others to help you.
Ok, I'm out of my depth predicting what waveform would be expected with that circuit. But I think it's possible that the circuit could be responsible for inverting the signal. I can't see anything in the code that would invert the signal.
The signal on the serial monitor is the raw signal without any computation on it.
((current/100)/0.01); 100 is the gain of the amplifier and 0.01 is the value of the current sense resistor. everything is fine when using oscilloscope but signal inverted when using ADS1115
You need to consider which way current flows through R48, the current shunt.
At the output of the bridge rectifier, conventional current flows from its + terminal to its - terminal, when the current flows through R48 it enters at pin 1 and exits at pin 2, making pin 1 the more positive. Hence pin 2 of the resistor is negative with respect to GND_PRI.
You can make the output of the AD620 instumentation amplifier go positive instead of negative by transposing the connections to pins 2 and 3.
Can't. Because the ADS1115 can't handle negative input voltages (point2 of R48 goes negative).
Differential for the ADS means the difference between two positive voltages.
Leo..
i had some tests and one differential channel of ads1115 now showing -2913 without any voltage applied. a second channel is still about 0. but both channels seems to be usable because readings are linear in both positive and negative range.
