Advanced chart problem
What dose not make sense to me is why if the green line (gardenTemp) is 16.168 and the red line which is 28.194 is below the green line?
I have tried different Max Min Avg and also chart styles yet they all produce the same output which to me looks wrong as the higher temp should be above the lower temp.
is this a bug or am I missing somthing
thanks for looking
David
The Advanced Chart can have a single Y-Axis or Multiple Y-Axes.
You clearly have Multiple Y-Axes selected.
You need to edit the chart in your dashboard.
Click on the 'Edit' button at the top right hand side:
Click on the chart, then on the pop-up select 'Open Settings'.
Now you can de-select 'Multiple Axes':
Then your two variables will be shown on a common Y-Axis:
Click on 'Done' at the bottom right.
Another case of not scrolling down… I had not seen that option, I do feel a bit stupid. Many thanks for your reply John I now have it all looking correct.
Good to hear that you have now got it to your liking.
