I recently posted topics related to using the Uno R4 WiFi and the Arduino Cloud (see: R4 WiFi). Now I seem to be over the steepest part of the learning curve, and I am using the Dashboard to display my data in "near-real-time".
For graphs / charts, I observe that Arduino Cloud seems to unilaterally decide what the scale of the ordinate (Y-) axis is, once the user chooses the abscissa (the latter choices being "live", 1 hour, 1 day, 7 days, 15 days).
Presently, I am using the "free" version of Arduino Cloud, which excludes the use of OTA uploading of Sketches and so forth. I was wondering:
- Does the 'free' version also have restrictions on the ordinate-scaling of graphical output? Or...
- Is the "automatic scaling" of the ordinate-axis true for all Arduino Cloud dashboards, regardless of the subscription plan that the user has?
(edit...)
I was prompted to look at related graphical question which I thought might provide some solution to my question. However...that posting mentions altering the update of the variable from "periodic" to "on change". When I try to edit my Dashboard, it does not give me that option within the Dashboard setup. Is this a reference to the lines in the Sketch which (in my case...) look like:
Since Mass is READ_WRITE variable, onMassChange() is
executed every time a new value is received from IoT Cloud.
void onMassChange() {
// Add your code here to act upon Mass change
Hi @polarmolar.
The Variable update policy is defined in the sketch code, but not in the part of the code you referenced. The onMassChange function is a callback function that is automatically called whenever the Dashboard user changes the value of the Mass Variable via the Dashboard (some Widget allow you to modify Variable values). The callback function is not related to the Variable update policy (it is instead related to the Variable permissions). Even though the The Variable update policy is defined in the sketch code, it is not recommended to adjust its configuration via the sketch code. You should instead use the convenient Variable configuration interface provided by the Arduino Cloud website.
I'll provide instructions you can follow if you want to change the update policy of a Variable to "periodic":
- Open your Thing in the Arduino Cloud website.
- Select the "Data" tab at the top of the page.
- You will see a list of the Thing's Variables on the page. Select the Variable you wish to configure.
A "Variable Properties" panel will open at the right hand side of the page.
- Select "Periodic" from the "Variable Update Policy" menu in the "Variable Properties" panel.
A new "Update every:" field will appear in the "Variable Properties" panel.
- Configure the update interval you want from the "Update every:" field.
- Select the "Sketch" tab at the top of the page.
- Upload the Thing sketch to your Arduino board.
Thank you! That was very helpful. I will need to read through a couple of more times, and look again (more carefully) at the Sketch. I will post another reply tomorrow (with a fresher brain!).
The "Maker" plan provides access to the "Advanced Chart" Widget:
https://docs.arduino.cc/arduino-cloud/features/advanced-chart/
It does provide some additional configurability over the "Chart" Widget available to "Free" plan users:
However, I'm not sure if any of the additional features of the "Advanced Chart" Widget would provide the control of the ordinate axis you are hoping to achieve.
