Advice needed to help 'translate' flowchart to code
Hello everyone, this is my first time posting on any forum so I hope I'm doing things right.
I need some help as to how I should continue my Arduino code while following my flowchart. I am doing this for an internship but I have almost zero prior experience with Arduino or any kind of programming language in general.
The program is meant to control 3 relays by detecting and comparing current values of 3 devices.
I have tried looking up many 'if else' and 'switch' cases online but I have yet to find any information that can help. Another possible way that looks like it will work is a nested-if but my flowchart will require 2 nested-ifs.
My main question is how do I code the part of the flowchart circled in red, so that after [ K2=1 ], the program will continue to the [ I(L)=I(PV) ] decision?
Here is what I have:
int K1=22;  //relay switch K1
int K2=24;
int K3=26;
byte Power=23;     //Virtual switches
byte Charging=25;
byte Manual=27;
byte GetValues=29;
//Variables that are not defined here are defined in another sketch:
//current_mA_PV, current_mA_Load, current
    pinMode(K1, OUTPUT);
    pinMode(K2, OUTPUT);
    pinMode(K3, OUTPUT);
    pinMode(Power, INPUT);
    pinMode(Charging, INPUT);
    pinMode(Manual, INPUT);
    pinMode(GetValues, INPUT);
    int valPower = digitalRead(Power); //Read state of Power button
    int valCharging = digitalRead(Charging); //Read state of Charging button
    int valManual = digitalRead(Manual); //Read state of Manual mode button
    int valGetValues = digitalRead(GetValues); //Read state of GetValues button
  if (valCharging > 0) {  // if the Charging is on, turn on K3 only:
    digitalWrite(K1, LOW);
    digitalWrite(K2, LOW);
    digitalWrite(K3, HIGH);
  } else if (valManual > 0) { //if Manual mode on, reset relay switches to 0, for manual operation.
      digitalWrite(K3, LOW);
      } else if (current_mA_PV > 0) { //if I(pv)>0A, turn on K2 only:
          digitalWrite(K2, HIGH);
        } else if (current_mA_Load <= current) {  //if I(Load)<=I(batt), turn on K2 and K3 only.
          } else if (current_mA_Load > current) { //if I(Load)>I(batt), turn on K1 only.
              digitalWrite(K1, HIGH);
              continue; //if all condition above are false, return back to Charging stage.
            }              //rest of the code which I do not know where to insert
Attached is a picture of my flowchart for your reference.
Any suggestions to make the code cleaner or better are welcome! :smiley:
Thanks for all your help!
Be aware that Booleans are only o or 1, meaning false or true.
You have:
boolean Power=23; //Virtual switches
boolean Charging=25;
boolean Manual=27;
boolean GetValues=29;
These will all compile to true with a value of 1.
Please change to:
byte Charging=25;
byte Manual=27;
byte GetValues=29;
Paul
I'm a little confused by your flowchart. Perhaps it's supposed to be this way but what happens at the dead-end conditions? For example, if you follow the chart from "Is IL <= Ibatt" and you set K1..3 as (0,1,1) but then what? In the code do you do this:
But your flowchart shows more:
            while(1);
There is there's no exit from that data shape. If there's supposed to be an exit, where would it go?
Same with the 'Y' answer to "Charging?"; no exit.
This sort of thing is what state machines were designed to do but unless it's absolutely intentional, a state machine should be "closed", meaning every state has at least one entry and one exit and no "hangers".
You might have a dead-end in the flow if a serious or safety-related fault were found and you just want to safe the system and intentionally do nothing. But generally, for most logic, after you perform some operation on I/O or memory, you should go somewhere afterward.
On a similar note, what happens in the "manual operation" shape? What happens during the manual operation of IN1..3 and how does one get out of that condition?
Paul_KD7HB:
Hello, thanks for your suggestion! My thinking was that since I'm using these 4 variables as just on and off switches, I thought that boolean would be suitable. (i.e. the 4 variables will only have 2 states, 1 and 0)
Blackfin:
Hi, thanks for your reply! You're right, there should be a return path after the process is executed. Thus for all of the parallelograms and the 'manual operation' shapes, there should be routed back to just below the Power block. I will update the flowchart attachment.
Here's one framework you can look at. I didn't try to compile it because it's not complete but it might illustrate how one approach to your problem:
const byte K1=22;  //relay switch K1
const byte K2=24;
const byte K3=26;
const byte Power=23;     //Virtual switches
const byte Charging=25;
const byte Manual=27;
const byte GetValues=29;    //note: if you want this to truly be an interrupt, you'll have to change pins
    pinMode( K1, OUTPUT );
    pinMode( K2, OUTPUT );
    pinMode( K3, OUTPUT );
    pinMode( Power, INPUT );
    pinMode( Charging, INPUT );
    pinMode( Manual, INPUT );
    pinMode( GetValues, INPUT );
    //does this need to be an interrupt?
    attachInterrupt( digitalPinToInterrupt( GetValues ), ISR_GetValues, RISING );
}//setup
    static byte
        stateControl = ST_POWER;
    switch( stateControl )
        case    ST_POWER:
            //Power
            if( digitalRead( Power ) == HIGH )
                stateControl = ST_CHARGING;
        case    ST_CHARGING:
            //Charging on?
            if( digitalRead( Charging ) == LOW )
                //No
                stateControl = ST_MANUAL;
                //Yes
                digitalWrite( K1, LOW );
                digitalWrite( K2, LOW );
                digitalWrite( K3, LOW );
                stateControl = ST_CHARGING; //redundant, presented for illustrative purposes
            }//else
        case    ST_MANUAL:
            //Manual mode on?
            if( digitalRead( Manual ) == LOW )
                //No
                stateControl = ST_CHECK_CURRS;
                //Yes
                //Manual Operation of IN1, INT2, IN3
                //assumed to return false when "finished" manual operation
                //when done, go back to charging state
                if( !HandleManualInputs() )
            }//else
        case    ST_CHECK_CURRS:
            //Is Ipv > 0A?
            if( current_mA_PV > 0.0 )
                //Yes
                digitalWrite( K2, HIGH );
                //Is Il = Ipv?
                if( current_mA_Load == current_mA_PV )
                    //Yes
                }//if
                //No
                //Is Il > Ipv?
                else if( current_mA_Load > current_mA_PV )
                    //Yes
                    digitalWrite( K1, HIGH );
                }//else if
                //No
                //Is Il < Ipv?
                    //Yes
                }//else
            }//if
            //No
            //Is Il <= Ibatt?
            else if( current_mA_Load <= current_mA_Battery )
                //Yes
                digitalWrite( K3, HIGH );
            }//else if
            //No
            //Is Il > Ibatt?
                //Yes
            }//else
            //No
            //Go back to chargin state
    }//switch
}//loop
bool HandleManualInputs( void )
    //"Manual Operation of IN1, IN2 and IN3"
}//HandleManualInputs
void ISR_GetValues( void )
    //"Get voltage/current of PV, Gen, Load and Batt"
}//ISR_GetValues
Wow!! Thanks for taking the time to write out all the code!! :smiley:
I think I understood how the switch and if cases work now thanks to your detailed comments!
I still have a few questions if you don't mind~
Blackfin:
Sorry but I don't really get your question here?
Blackfin:
How would I handle the inputs here? Do I just use digitalRead?
    Serial.println("              INA219_PV  |   INA219_Load   ");
    Serial.print("Load Voltage:  "); Serial.print(loadvoltage_PV); Serial.print("      | ");
    Serial.print(loadvoltage_Load); Serial.println(" V");
    Serial.print("Current:       "); Serial.print(current_mA_PV); Serial.print("       | ");
    Serial.print(current_mA_Load); Serial.println("  mA");
    Serial.print("Power:         "); Serial.print(power_mW_PV); Serial.print("         | ");
    Serial.print(power_mW_Load);Serial.println("     mW");
//etc.
}//ISR_GetValues
Is this how I should include the GetValues output here?
I've also gotten some errors after compiling, the main ones being that the ST_() group of variables were not declared.
Thanks for your help again!!
You could go to flow code which will convert your flowchart automatically so-to-speak.
Tankfuzz:
Quote from: Blackfin on Today at 12:04 am
Interrupts are normally reserved for capturing/responding to short duration events. A human pushing a button doesn't usually qualify because in that case the button input will be active for eons of processor time. A correctly constructed (no delay()) program scan will easily notice and process such. Now, if the input is a 23nsec pulse an interrupt would be indicated because the pulse could start just after the code checks it and then be gone by the time it's checked again.
dougp:
Hi, are you suggesting I don't use the interrupt function?
Tankfuzz:
I'm suggesting interrupts should not be used indiscriminately. If your application needs interrupts to work then use interrupts. Most times however, what is needed instead is a different approach in the code. If your code is non-blocking the switches and other inputs can be sensed and acted upon using several things at the same time techniques.
Can I suggest you do not go back to posts and change/update their content.
This causes confusion to anyone reading and trying to use this thread as a guide.
You should have posted your revised flowchart in a new post.
Tom... :slight_smile:
