I have a custom drawing machine, effectively like a CNC machine but with a custom pen holder.
In my current design I have an X and Y motor, but I am going to switch to a more conventional design with two Y motors and an X motor, as here: OpenBuilds ACRO System
They have a current rating of 0.4A but a reasonable torque. I am struggling to find a matching motor - most seem to have a higher current rating, e.g. 1.68A.
Thanks. It's a while since I set up the shield with the drivers, I will check that they are adjustable. So presumably I would adjust my power supply to the max current rating, 1.68A in this case?
LemmyC:
Don't set the current at the power supply because it will drop the voltage to achieve the lower current. Make sure it is set well above the max that could be required so that the power supply limits never kick in.
Thanks. I saw that one and thought the torque looked relatively low but translating N-m to Kg-cm to it's similar to my current motors which appear to be 2.65 kg-cm. Do you think these would be capable of moving a gantry along a frame as per the CNC frame cited previously?
Your existing motor is a massive 30 ohm, so its not allowing the A4988 to work properly with only
12V supply.
For a drawing robot you probably need a lot less torque than a NEMA17 generates, but they are usually
the cheapest(*), so stick with them, perhaps get some 1.5A ones and try running at 0.75A each, that
may be enough torque and they will run 4 times cooler...
With low-impedance motors like this you'll get much more top speed, even from 12V.
(*) NEMA11's and 8's are very cute (& costly), but much less torque. NEMA14 is more likely to be a
possible compromise but will probably be more expensive than stock '17's
MarkT:
I got a batch of 5 NEMA 14 for less than 20 CDN !
They sufficed chomping wood albeit at a reduced rate of feed until I got the hang of CNC / GRBL then picked up a batch of NEMA 17 at waaay more than that.
