hello
we will not give up on Yun, we need to use such great model!!!
will get new board, for Arduino
we learned a lot during this period!!!
yes we tried plan A = Ethernet cable
it did take the router IP address 192-168.240.1
will perform 2 paths:
no update
instruction (1) "make sure port 5353 is not being blocked by a firewall." how to check on that?
answer (1)
instruction (2) when board arrive it should turn on and capable of connecting to IDE and shows its Yun-MAC name as a Port in tool-ports, this never happen
answer (2)
a- if not then the problem in the router
b- we need to find IP address first, No, because this step has nothing to do with IP but uses the MAC address Yun-MAC
instruction (3) "The Yún has the ability to act as an Access Point, but it can also connect to an existing network."
the AP-router/server function exist and we find Yun-MAC icon in network manager list
after we turn power,
answer-3: yes we find that and reset by (>5 secnd , <30 second reset) does that also
we should find IDE Yun-MAC under Ports (**that step does not happen at all in previous trials)
- we should find Yun-MAC under network active list (but not connected)
*********Thus Power on do nothing, should shows the 2 Yun-MAC address ***********
Q: if this do nothing not correct, then what the correct sequence to get IDE-Ports Yun-MAC address, since only COMxx(Arduino Yun) appears for the USB-CDC-VCP connection
last resort Step:
before that check to see if IP address acquired
the assumption, the turn power on, will allow Yun to communicate and acquire IP address form the router, but this not true and the above assumption wrong" why"
because Yun has AP-mode in power on and will not acquire a client IP address from home router
and it will not show any thing on IDE ports except the USB-CDC-VCP port COMxx
Q: why we need to re number the port like COM13 to COMx below 10 like COM7? why 13 not a good number?
then: the following sequence should be the correct one for what to do:
1- built in IP 192-168.240.1 will allow us in AP-mode, at power-on time,
to ne used with PC browser to access the config page
Instruction (4): that where the same "make sure" in any writing, how to make sure?
a- this Yun-MAC does appears in network list
we can PC-browser type 192.168.240.1 and we can get the webpage from Yun
"When you first power on the Yún, it will create a WiFi network called ArduinoYun-XXXXXXXXXXXX. Connect your computer to this network."
Do we have correct interpretation: Yun-AP-mode on start up, PC can connect with no problem:
b- this webpage log in -> configure will show IP address
Q: what the correct address to appear now 192.168.240.1 or the one form our home-router
192.168.1.xx (0-20 in our home router setup for wireless). before we did shows arduino x.240.1 address
Answer 4-b: ?????????? Assume will be exact 192.168.240.1 because we never acquired a home router IP automatically
Once you've obtained an IP address, open a web browser, and enter http://arduino.local or 192.168.240.1 in the address bar. After a few moments, a web page will appear asking for a password. Enter "arduino" and click the Log In button. "
This step Yun in AP-mode and we want to convert to client-mode and acquire an IP address form our home router
that the purpose of the config and restart: convert the Yun from master - AP - mode to client mode
instruction (5) "You can now join the network you assigned to the Yún."
this after restart - configure bar and we get the page with " click here "
that where it fails, that has to be from the home router
Last resort:
fuzzy on details when done before with Ethernet cable connected
check the router wireless table, that where we insert names of each wifi in the home-router domain and list them to have constant IP address
IP-name-MAC address and add this to the table
the following the last Notes I have: and shut down to get third new board:
instructions:
"If you make a note of the MAC address, then you can see it in the list of attached devices on your router and the IP that is assigned to it."
"Once you know the MAC address, you can then reserve an IP in your router, so every time you connect, your router will issue it with the same IP address."
download wifistatus program form bridge
open the serial monitor,
this the current output the router name comes in the serial com as client, which represent the Yun as the router and the router PC connection as client?
Current WiFi configuration
SSID: Implied 2.4G
Mode: Client
Signal: 0%
Encryption method: -
Interface name: wlan0
Active for: 0 minutes
MAC address: B4:21:8A:F0:20:F5
RX/TX: 5/7 KBs
before, this step we did : the output from the serial connection to Yun (means we used Yun serial monitor to access the Linux shell on IDE not on PuTTY SSH, it will not work: log in taken, password frozen do not accept keyborad input, and return access denied and shows ---- #password again
SSID: Arduino Yun-B4218AF020F5
Mode: Master
Signal: 0%
Encryption method: None
Active for: 28 minutes
IP address: 192.168.240.1/255.255.255.0
RX/TX: 144/151 KBs
If all above doesn't work, try ssh to the yun shield (means Dragino) and run
/etc/init.d/avahi-daemon restart
This will broadcast the Arduino service and Arduino IDE should get it.
we did similar restart and still did not get any results
the question this problem Linux or PC or Router?
