Bonjour a tous, pour un projet en cours je travaille sur le Grove - 125KHz RFID Reader Pour lire des badges
Voici le programme en question :
link between the computer and the SoftSerial Shield
at 9600 bps 8-N-1
Computer is connected to Hardware UART
SoftSerial Shield is connected to the Software UART:D2&D3
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(2, 3);
unsigned char buffer[64]; // buffer array for data receive over serial port
int count = 0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
// if date is coming from software serial port ==> data is coming from SoftSerial shield
if (SoftSerial.available())
while(SoftSerial.available()) // reading data into char array
buffer[count++] = SoftSerial.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer, count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the stored data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardware serial port ==> data is coming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
// clear all index of array with command NULL
for (int i=0; i<count; i++)
buffer[i]=NULL;
Donc voila c'est celui la que je suis censé utiliser,source:Grove - 125KHz RFID Reader | Seeed Studio Wiki
Pour le branchement j'ai procédé comme suis:
Uart Mode
GND > GND
VCC > 5v
RX > RX
TX > TX
J'ai ça après la compilation:
Puis je téléverse , message derreur
Arduino : 1.8.1 (Windows 10), Carte : "Arduino/Genuino Uno"
C:\Users\Yaze\Documents\Arduino\sketch_apr03aa\sketch_apr03aa.ino: In function 'void clearBufferArray()':
C:\Users\Yaze\Documents\Arduino\sketch_apr03aa\sketch_apr03aa.ino:42:18: warning: converting to non-pointer type 'unsigned char' from NULL [-Wconversion-null]
buffer[i]=NULL;
Le croquis utilise 3210 octets (9%) de l'espace de stockage de programmes. Le maximum est de 32256 octets.
Les variables globales utilisent 363 octets (17%) de mémoire dynamique, ce qui laisse 1685 octets pour les variables locales. Le maximum est de 2048 octets.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc8
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Avez vous une idée?
Merci d'avance
