Hi all,
I have had a few alphanumeric displays and today I have decided to hook them up to a 74HC595. There are 2 74HC595's in chain that are controlling each segment of the alphanumeric display. By the way, the library is named Pasta (I name all of my libraries after all of my favorite foods, the next one is going to be bacon). I have the .cpp and .h files, but I ran into a problem. I made all of the alphanumeric characters in bytes, 16 bit bytes. The Arduino IDE is giving me error messages like "B1011101000011010 was not declared in this scope." How would I go about fixing this?
.cpp file
#include "Arduino.h"
#include "Pasta.h"
uint8_t Pasta::registerPins(int SER_Pin, int RCLK_Pin, int SRCLK_Pin, int Number_of_Registers) {
_SER_Pin = SER_Pin;
_RCLK_Pin = RCLK_Pin;
_SRCLK_Pin = SRCLK_Pin;
_Number_of_Registers = Number_of_Registers;
pinMode(_SER_Pin, OUTPUT);
pinMode(_RCLK_Pin, OUTPUT);
pinMode(_SRCLK_Pin, OUTPUT);
clear(); //reset all register pins
update();
void Pasta::update(){
//Set and display registers
//Only call AFTER all values are set how you would like (slow otherwise)
digitalWrite(_RCLK_Pin, LOW);
//iterate through the registers
for(int i = _Number_of_Registers - 1; i >= 0; i--){
//iterate through the bits in each registers
for(int j = 8 - 1; j >= 0; j--){
digitalWrite(_SRCLK_Pin, LOW);
int val = _shiftRegisters[i] & (1 << j);
digitalWrite(_SER_Pin, val);
digitalWrite(_SRCLK_Pin, HIGH);
digitalWrite(_RCLK_Pin, HIGH);
void Pasta::setPin(int index, boolean val){
int byteIndex = index/8;
int bitIndex = index % 8;
byte current = _shiftRegisters[byteIndex];
current &= ~(1 << bitIndex); //clear the bit
current |= val << bitIndex; //set the bit
_shiftRegisters[byteIndex] = current; //set the value
update();
void Pasta::setAll(boolean val){
//set all register pins to LOW
for(int i = _Number_of_Registers * 8 - 1; i >= 0; i--){
setPin(i, val);
void Pasta::clear(){
setPin(i, _common);
uint8_t Pasta::segmentPins(int a, int b, int c, int d, int e, int f, int g, int h, int i, int j, int k, int l, int m, int n, int o, int p, boolean common) {
_a=a;
_b=b;
_c=c;
_d=d;
_e=e;
_f=f;
_g=g;
_h=h;
_i=i;
_j=j;
_k=k;
_l=l;
_m=m;
_n=n;
_o=o;
_p=p;
_common=common;
segmentpins[0] = _a;
segmentpins[1] = _b;
segmentpins[2] = _c;
segmentpins[3] = _d;
segmentpins[4] = _e;
segmentpins[5] = _f;
segmentpins[6] = _g;
segmentpins[7] = _h;
segmentpins[8] = _i;
segmentpins[9] = _j;
segmentpins[10] = _k;
segmentpins[11] = _l;
segmentpins[12] = _m;
segmentpins[13] = _n;
segmentpins[14] = _o;
segmentpins[15] = _p;
for(int i=0; i < 16; i++) {
pinMode(segmentpins[i], OUTPUT);
void Pasta::flicker() {
write(0);
delay(50);
write(4);
delay(50);
write(9);
delay(50);
write(1);
delay(50);
write(6);
delay(50);
write(9);
delay(50);
write(3);
delay(50);
write(4);
delay(100);
write(7);
delay(100);
write(9);
delay(100);
write(3);
delay(100);
write(2);
delay(100);
write(5);
delay(100);
write(6);
delay(100);
write(3);
delay(200);
write(5);
delay(300);
void Pasta::write(int character) {
boolean isBitSet;
// ABCDEFGHIJKLMNOP
numeral[0] = B1110001001000111; // 0
numeral[1] = B0000001000000100; // 1
numeral[2] = B1100001111000011; // 2
numeral[3] = B1100001110000111; // 3
numeral[4] = B0010001110000100; // 4
numeral[5] = B1110000110000111; // 5
numeral[6] = B1110000111000111; // 6
numeral[7] = B1100001000000100; // 7
numeral[8] = B1110001111000111; // 8
numeral[9] = B1110001110000111; // 9
numeral[10] = B1110001110000100; // A
numeral[11] = B1110010101001011; // B
numeral[12] = B1110000001000011; // C
numeral[13] = B0011000101100000; // D
numeral[14] = B1110000111000011; // E
numeral[15] = B1110000111000000; // F
numeral[16] = B1110000011000111; // G
numeral[17] = B0010001111000100; // H
numeral[18] = B1100100000010011; // I
numeral[19] = B1100100001010010; // J
numeral[20] = B0000110000011000; // K
numeral[21] = B0010000001000011; // L
numeral[22] = B0011011001000100; // M
numeral[23] = B0011001001001100; // N
numeral[24] = B1110001001000111; // O
numeral[25] = B1110001111000000; // P
numeral[26] = B1110001001001111; // Q!!!!!!!!!
numeral[27] = B1110001111001000; // R
numeral[28] = B1110000110000111; // S
numeral[29] = B1100100000010000; // T
numeral[30] = B0010001001000111; // U
numeral[31] = B0010010001100000; // V
numeral[32] = B0010001001101100; // W
numeral[33] = B0001010000101000; // X
numeral[34] = B0001010000010000; // Y
numeral[35] = B1100010000100011; // Z
numeral[36] = B0000000101010010; // a
numeral[37] = B0010000111000111; // b
numeral[38] = B0000000101000010; // c
numeral[39] = B0000001111000111; // d
numeral[40] = B0010000111000100; // h
numeral[41] = B0000001000000100; // l
numeral[42] = B0000000111000100; // m
numeral[43] = B0000000101010000; // n
numeral[44] = B0000000101010010; // o
numeral[45] = B0000100110010001; // t
numeral[46] = B0000000001000111; // u
numeral[47] = B0000000001010111; // w
numeral[48] = B0000000110000000; // -
numeral[49] = B0000010000100000; // /
numeral[50] = B1110001010000000; // ?
numeral[51] = B0001000000001000; // \
numeral[52] = B0000100000010000; // |
numeral[53] = B0000100110010000; // +
numeral[54] = B0000000000000011; // _
numeral[55] = B1100001000000111; // ]
numeral[56] = B1110000001000011; // [
numeral[57] = B0000000000100000; // ,
numeral[58] = B0001110110111000; // *
numeral[59] = B1101010000101011; // hour glass
if (_common == HIGH) {
for(int segment=1; segment < 17; segment++) {
if(character < 0 || character > 59) {
isBitSet = 0;
}else{
isBitSet = bitRead(numeral[character], segment);
isBitSet = ! isBitSet;
setPin(segmentpins[segment], isBitSet);
update();
}else{
isBitSet = 0;
}else{
update();
.h file
#ifndef Pasta_h
#define Pasta_h
class Pasta
public:
uint8_t registerPins(int SER_Pin, int RCLK_Pin, int SRCLK_Pin, int Number_of_Registers);
uint8_t segmentPins(int a, int b, int c, int d, int e, int f, int g, int h, int i, int j, int k, int l, int m, int n, int o, int p, boolean common);
void write(int character);
void clear();
void setAll(boolean val);
void setPin(int index, boolean val);
void update();
void flicker();
private:
int _a, _b, _c, _d, _e, _f, _g, _h, _i, _j, _k, _l, _m, _n, _o, _p, _character;
int _SER_Pin, _RCLK_Pin, _SRCLK_Pin, _Number_of_Registers;
byte numeral[10];
int segmentpins[8];
boolean _common;
byte _shiftRegisters[25];
boolean _val;
#endif
Qtechknow
