I've read many posts, including recent ones below, that sound similar to my problem, but I haven't been able to get it going yet. I am able to ping my ethernet shield and cisco network magic shows it as 'online', but when I try any of the sample sketches testing the connection, like a recent one from zoomkat, I get 'connection failed', and the ip address doesn't show up in my 2WIRE 3800HGV-B router listing. I've tried different myserver addresses, mac addresses, ip addresses, ports (80 below) without any success.
Here's the code as I'm presently trying it.
//zoomkat 4-04-12
//simple client test
//for use with IDE 1.0
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
//the arduino lan IP address { 192, 168, 1, 102 } may need
//to be modified modified to work with your router.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE }; //physical mac address
byte ip[] = {
192, 168, 1, 104 }; // ip in lan assigned to arduino
byte gateway[] = {
192, 168, 1, 254}; // internet access via router
byte subnet[] = {
255, 255, 255, 0 }; //subnet mask
byte myserver[] = {
208, 104, 2, 86 }; // zoomkat web page server IP address
EthernetClient client;
void setup(){
//Ethernet.begin(mac, ip);
Ethernet.begin(mac, ip, gateway, subnet);
Serial.println("Better client test 4/04/12"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(myserver, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
Here's the output:
connection failed
disconnecting.
connection failed
disconnecting.
Thanks in advance for any advice on what to check for this.
