I am using an Arduino (powered from a small 5v battery) with a transistor as a switch to control a high current 12v device. This all works well, but it requires constant voltage from the Arduio pin to the transistor gate for the 12 volt device to stay on. This constant voltage to the transistor gate, will obviously deplete the small 5v Arduino battery if I want to keep the 12v device on for extended periods of time (hours or days).
Is there a transistor like device (does not have to be a transistor, but just have the function I want) which would work more like a light switch in a house? e.g. the Arduino would apply a voltage to the gate only ONCE and the 12v device would remain permanently on. If a voltage is applied by the Arduino ONCE again to the gate, the 12v device would turn permanently off. A similar principal to a light switch in a house e.g. there is no need to keep your finger (apply voltage analogy) pressed on the switch at all times. Does such a component exist?
A logic level MOSFET only consumes current when first turned on (charging gate capacitance). Once the MOSFET is fully on, no more current is drawn by the MOSFET. If you post a schematic of your current setup maybe we can suggest a better method.
groundFungus:
I am using a N channel mosfett fdp6030bl
What about BJT TRANSISTORS? Do they only consume current when first turned on? My research tells me Mosfets have a much less drain on a battery.
BJT transistors are current operated. They will always have current flowing into (or out of) the base to keep them turned on. MOSFETs are voltage operated. Once turned on (gat capacitance charged) they will draw near 0 current. Your research is correct in that respect.
Yes, it's called a thyristor. Once current is flowing it stays on until you interrupt it by some other means. You then have the problem of interrupting the current.
There is also a gate turn off thyristor , never use one, never seen anyone on here refer to one, don't know how good they are.
