I'm trying to amplify sound of isd1820. I bought pam8403 ic module .
I first connect SP - pin of isd1820 to ground pin of Pam(input) .Then I connected SP + to L or R pin of pam. ANd then I fully hear distortion.
What is the way yo connect isd1820 to pam8403 module? I'm little bit confused
Pam module has 3 input pins namely l r and ground. In thus case how i can connect depending on your suggestion? Also,with using capacitors as isd data sheet, is it ok for pam module as well? If so how?
