AMT23 Absolute Encoder Position
Hello - i'm attempting to read along the AZ of my telescope using an absolute encoder. With the code below from the manufacturing company i'm able to receive 0-4096 figures back from the AMT23 device, but it starts over every 90 degrees. Any ideas how I can change the code to determine where its positioned as an absolute value rather than relative? Appreciate the assistance.
Thank you,
Smalls
 * AMT23_SSI_Sample_Code.ino
 * Company: CUI Inc.
 * Author: Jason Kelly
 * Version: 1.0.0.1
 * Date: February 14, 2020
 * This sample code can be used with the Arduino Mega to control the AMT22 encoder.
 * It uses SSI to control the encoder and the the Arduino UART to report back to the PC
 * via the Arduino Serial Monitor. Code can be modified for any Arduino including the UNO.
 * The pins are the same on the Arduino UNO but you will need to make sure to change the board
 * type in the Tools Menu.
 * For more information or assistance contact CUI Inc for support.
 * After uploading code to Arduino Mego open the open the Serial Monitor under the Tools
 * menu and set the baud rate to 115200 to view the serial stream the position from the AMT23.
 * Arduino Pin Connections
 * SSI Chip Select: Pin 7
 * SSI Clock (SCK): Pin 10
 * SSI Data (SDO):  Pin 11
 * AMT23 Pin Connections
 * Vdd (5V):              Pin 1
 * SSI DATA (SDO):        Pin 2
 * SSI CLOCK (SCK):       Pin 3
 * GND:                   Pin 4
 * Mode (unconnnected:    Pin 5
 * SSI Chip Select:       Pin 6
 * This is free and unencumbered software released into the public domain.
 * Anyone is free to copy, modify, publish, use, compile, sell, or
 * distribute this software, either in source code form or as a compiled
 * binary, for any purpose, commercial or non-commercial, and by any
 * means.
 * In jurisdictions that recognize copyright laws, the author or authors
 * of this software dedicate any and all copyright interest in the
 * software to the public domain. We make this dedication for the benefit
 * of the public at large and to the detriment of our heirs and
 * successors. We intend this dedication to be an overt act of
 * relinquishment in perpetuity of all present and future rights to this
 * software under copyright law.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
 * IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
 * OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
 * ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 * OTHER DEALINGS IN THE SOFTWARE.
/* NOP */
#define NOP __asm__ __volatile__ ("nop\n\t")
/* Define special ascii characters */
#define carriageReturn  0x0D
#define newLine         0x0A
#define tab             0x09
/* boolean */
#define OFF             0
#define ON              1
/* pins */
#define SSI_CS          7
#define SSI_SCK         10
#define SSI_SDO         11
/* available resolutions */
#define res12           12
#define res14           14
/* Serial */
#define baudRate        115200
  //pin modes for AMT23 SSI
  pinMode(SSI_SCK, OUTPUT);
  pinMode(SSI_CS, OUTPUT);
  pinMode(SSI_SDO, INPUT);
  //serial port for debugging
  Serial.begin(baudRate);
  //we don't need to redeclare variables so they can go here
  //and then we can have our own infinite loop below
  uint16_t encoderPosition; //holder for encoder position
  uint8_t attempts; //we can use this for making sure position is valid
  while(1)
    //set attemps counter at 0 so we can try again if we get bad position
    attempts = 0;
    //this function gets the encoder position and returns it as a uint16_t
    //send the function either res12 or res14 for your encoders current resolution
    encoderPosition = getPositionSSI(res12);
    while (encoderPosition == 0xFFFF && attempts++ < 3)
      delay(1);
      encoderPosition = getPositionSSI(res12); //try again
    Serial.print(encoderPosition, DEC); //print the position
    Serial.write(newLine);
 * Use this function to understand how the SSI protocol works first, then you can use the function
 * below that has better efficiency.
uint16_t getPositionSSI(uint8_t resolution)
  uint8_t i, j; //we'll use these incrementers
  uint16_t currentPosition;
  uint8_t _clockCounts = resolution + 2; //the AMT23 includes 2 additional bits in the response that are used as checkbits
  bool binaryArray[_clockCounts]; //we'll read each bit one at a time and put in array. SSI comes out reversed so this helps reorder
  bool bitHolder; //this variable holds the current bit in our read loop
  bool checkBit0, checkBit1; //the frist two bits in the position response are checkbits used to check the validity of the position response
  //drop cs low and wait the minimum required time. This is done with NOPs
  digitalWrite(SSI_CS, LOW);
  for (i = 0; i < 5; i++) NOP;
  //We will clock the encoder the number of times (resolution + 2), incrementing with 'j'
  //note that this method of bit-banging doesn't give a reliable clock speed.
  //in applications where datarate is important, the Arduino is not the best solution unless you
  //can find a way to make the SPI interface work for this protocol format.
  for (j = 0; j < _clockCounts; j++)
    //first we lower the clock line and wait until the pin state has fully changed
    digitalWrite(SSI_SCK, LOW);
    for (i = 0; i < 10; i++) NOP;
    //now we go high with the clock. no need to wait with NOPs because the pin read we'll do next times sufficient time
    digitalWrite(SSI_SCK, HIGH);
    //Grab the data off of the SDO line and place it into the binary array
    binaryArray[j] = digitalRead(SSI_SDO);
  //release cs line, position has been fully received
  digitalWrite(SSI_CS, HIGH);
  //now we'll reverse the order of the binary array so that the bit ordering matches binary
  for (i = 0, j = _clockCounts - 1; i < (_clockCounts / 2); i++, j--)
    bitHolder = binaryArray[i];
    binaryArray[i] = binaryArray[j];
    binaryArray[j] = bitHolder;
  //create uint16_t from binary array by masking and bit shifting
  for (i = 0; i < _clockCounts - 2; i++) currentPosition |= binaryArray[i] << i;
  //grab check bits in highest bit slots
  checkBit1 = binaryArray[_clockCounts - 1];
  checkBit0 = binaryArray[_clockCounts - 2];
  //use the checkbit equation from the ATM23 datasheet
  if (resolution == res12) //if we're in 12-bit
    if (!(checkBit1 == !(binaryArray[11] ^ binaryArray[9] ^ binaryArray[7] ^ binaryArray[5] ^ binaryArray[3] ^ binaryArray[1]))
        && (checkBit0 == !(binaryArray[10] ^ binaryArray[8] ^ binaryArray[6] ^ binaryArray[4] ^ binaryArray[2] ^ binaryArray[0])))
      currentPosition = 0xFFFF; //bad pos, return 0xFFFF which is not a valid value
  else if (resolution == res14) //if we're in 14-bit
    if (!(checkBit1 == !(binaryArray[13] ^ binaryArray[11] ^ binaryArray[9] ^ binaryArray[7] ^ binaryArray[5] ^ binaryArray[3] ^ binaryArray[1]))
        && (checkBit0 == !(binaryArray[12] ^ binaryArray[10] ^ binaryArray[8] ^ binaryArray[6] ^ binaryArray[4] ^ binaryArray[2] ^ binaryArray[0])))
  return currentPosition;
 * This function is a more efficient version of the getPositionSSI() function
 * that strips out some of the bit reordering and improves the speed of calculating the checkbit.
 * Once the SSI protocol is fully understood, this function will be more useful in an end application.
uint16_t getPositionSSI_efficient(uint8_t resolution)
  uint8_t odd, even; //bit parity counters
  uint16_t currentPosition = 0;
  uint8_t checkBit1, checkBit0; //the frist two bits in the position response are checkbits used to check the validity of the position response
    //throw the pin value into the position, note that it's reversing it as well
    currentPosition |= (digitalRead(SSI_SDO) << (_clockCounts - j - 1));
  //grab the highest two bits and put them into the checkbit holders
  checkBit1 = (currentPosition >> (_clockCounts - 1)) & 0x01;
  checkBit0 = (currentPosition >> (_clockCounts - 2)) & 0x01;
  //at this point currentPosition still holds the checkbits. So if we're in 14 bit mode, there's 16 bits
  //we only move up 14 bits here (resolution) because we're only tallying up the 1's in the position
  //we're counting the bits in even slots and the ones in odd slots
  for (uint8_t i = 0; i < resolution; i++) (i % 2 == 0) ? even += ((currentPosition >> i) & 0x01) : odd += ((currentPosition >> i) & 0x01);
  //check the counts against the checkbits
  if ((checkBit1 == odd % 2) || (checkBit0 == even % 2)) currentPosition = 0xFFFF;
    //this isn't the 'fastest' since we're introducting an if/else but doing
    // currentPosition &= 2^resolution; doesn't work because arduino has a problem with
    // powers.
    if (resolution == res12) currentPosition &= 0xFFF;
    else if (resolution == res14) currentPosition &= 0x3FFF;
I think you have a res14 encoder. Try
 encoderPosition = getPositionSSI(res14);
Thank you for the reply - I had the same idea and unfortunately the same behavior occurs, instead moving from 0-16k every 90 degrees
Is it getting every value sequentially from 0-16383? Or is it skipping by 4s?
I'd wonder how you get 0-16384 or 0-4095 in a quadrant without missing bits.
Maybe ask Jason Kelly at CUI for expeted behavior or ask for a new device.
With the code set to 14 bits the numbers appear to step by 4 within each 90 degrees segment so at the beginning of the turn I start at 0 and at the end of the 90 degrees i'm at 16k, then it resets to 0 as you move into the next 90. I have reached out to Jason via linkedin, but he no longer is with CU
While typed as bool, the binaryArray values are actually 8 bit bytes either 00000000 or 00000001.
I'm not clear if the bitshifting to create the positional value is correct and some of the high order bytes are being sifted to oblivion.
In my code with the SSi encoders, once the data is in the array, I have always used something like this to build the positional value.
currentPosition = 0; //clear previous value
for(byte i = 0; i< _clockCounts - 2; i++)
 currentPosition = currentPosition << 1;
 currentPosition += binaryArray[i];
If they right-sized him because his code didn't work with their encoders, maybe they have somebody new with new code. A 90° absolute encoder is insane.
