an error "expected unqualified-id before string constant" when compiling
my project is:
a force is applied on a peizo sensor, a voltage will be produced. Now my code can judge what’s a real hit (quick touch and then release). When a hit is applied on the sensor, the Pin 13 will produce a high level. at the same time I want to call the SineWave generator function. Actually the SineWave generator code is from Richard Cappels. It can work alone. But once it is put in my code, an error “expected unqualified-id before string constant” will happen.
my Code is:
 #include <avr/interrupt.h>
 #include <stdlib.h>
int led =13;
const int N=100;
float voltageValue[N];
float voltage[N];
int PressStatus;//Pressing flag;
//define Sinewave
 char sinetable [32];
 int  j ;
 void ioinit (void)
   //Initialize output ports
   PORTD = B11111111;
   DDRD  = B11111111;
 void timer_setup(){
   TCCR2A = 0;
   TCNT2=455;    //455 outputs 1.007khz
   TCCR2B = B00000010;
   //Timer2 Overflow Interrupt Enable
   TIMSK2 = 1<<TOIE2;
void setup(){
   ioinit();
   arraysetup();
   cli();
   timer_setup();
   j = 0;
   sei();
  //initialize serial communication at 4800bit per second;
Serial.begin(4800);
pinMode (led,OUTPUT);
void arraysetup(void){
   sinetable[0]=127;  // Put 32 step 8 bit sine table into array.
   sinetable[1]=152;
   sinetable[2]=176;
   sinetable[3]=198;
   sinetable[4]=217;
   sinetable[5]=233;
   sinetable[6]=245;
   sinetable[7]=252;
   sinetable[8]=254;
   sinetable[9]=252;
   sinetable[10]=245;
   sinetable[11]=233;
   sinetable[12]=217;
   sinetable[13]=198;
   sinetable[14]=176;
   sinetable[15]=152;
   sinetable[16]=128;
   sinetable[17]=103;
   sinetable[18]=79;
   sinetable[19]=57;
   sinetable[20]=38;
   sinetable[21]=22;
   sinetable[22]=10;
   sinetable[23]=3;
   sinetable[24]=0;
   sinetable[25]=3;
   sinetable[26]=10;
   sinetable[27]=22;
   sinetable[28]=38;
   sinetable[29]=57;
   sinetable[30]=79;
   sinetable[31]=103;
void loop(){
 int i;
 for(i=0;i<N;i++){
  //read the input on analog pin A0;
voltageValue[i] = analogRead(A0);
voltage[i] = voltageValue[i] * (5.0 / 1023.0);
if (i>0&&voltage[i]-voltage[i-1]>=0.1){
// Serial.println("voltage = ");
PressStatus=1;
digitalWrite(led,HIGH);
//call SineWave generator function
ISR(TIMER2_OVF_vect) {
   PORTD=(sinetable[j++]);
   TCNT2=455;
   if(j==32){
     j=0;
else {
PressStatus=0;
digitalWrite(led,LOW);
Serial.println(voltage[i]);
//Serial.println(Press);
Consistent indentation will help you spot your problem.
Serial i/o in an interrupt service routine is never a good idea.
The compiler will initialise your sine table for you when you declare it.
Hi AWOL,
What shall I do next?
Thanks
Check your indentation.
This flavour of C++ doesn't allow function declarations inside other functions.
Here someone else suggested you concentrate on indentation.
I am so sorry, I really don't know what is the indentation. Pls help me out or give me more hints.
Thanks a lot.
Indentation is the visual structure of the code.
The compiler ignores it completely, but it helps humans follow the structure.
There are many different styles, but consistency is key.
If you find yourself typing a {, then type the matching } with exactly the same number of spaces in front of it.
Nested blocks have successively more spaces in front of them.
I'm pretty sure there's a Wikipedia page on the different styles.
I'm posting from my phone, so I can't easily post examples.
Not posting from a phone so:
The Arduino IDE has an auto format feature (ctrl-t). Learn it, love it.
Embrace and love it, but it won't work if the code is badly formed.
Hi AWOL,
I have Checked my indentation. the error is still reported. the function "ISR(TIMER2_OVF_vect)" can not been called?
You aren't supposed to check your indentation, more re-do it so you can read your own code easier.
Maybe you are unsure because they are macros, but ISR(){ //... } is a function definition and must go at file scope like loop(), rather than in loop() itself ( nested ).
//Should not be declared inside a function
   TCNT2=455;
   if(j==32){
     j=0;
Hi pYro_65,
Even I declare the function outside the loop, the error still happen.
my code:
#include <stdlib.h>
int led =13;
const int N=100;
float voltage[N];
//define Sinewave
int  j ;
void ioinit (void)
  PORTD = B11111111;
  DDRD  = B11111111;
void timer_setup(){
  TCCR2A = 0;
  TCCR2B = B00000010;
  TIMSK2 = 1<<TOIE2;
void setup(){
  ioinit();
  arraysetup();
  cli();
  timer_setup();
  j = 0;
  sei();
  Serial.begin(4800);
  sinetable[1]=152;
  sinetable[2]=176;
  sinetable[3]=198;
  sinetable[4]=217;
  sinetable[5]=233;
  sinetable[6]=245;
  sinetable[7]=252;
  sinetable[8]=254;
  sinetable[9]=252;
  sinetable[10]=245;
  sinetable[11]=233;
  sinetable[12]=217;
  sinetable[13]=198;
  sinetable[14]=176;
  sinetable[15]=152;
  sinetable[16]=128;
  sinetable[17]=103;
  sinetable[18]=79;
  sinetable[19]=57;
  sinetable[20]=38;
  sinetable[21]=22;
  sinetable[22]=10;
  sinetable[23]=3;
  sinetable[24]=0;
  sinetable[25]=3;
  sinetable[26]=10;
  sinetable[27]=22;
  sinetable[28]=38;
  sinetable[29]=57;
  sinetable[30]=79;
  sinetable[31]=103;
void loop(){
  int i;
  for(i=0;i<N;i++){
      PressStatus=1;
    else {
      PressStatus=0;
  [b]  //call SineWave generator function[/b]
      if (PressStatus==1){
        TCNT2=455;
        if(j==32){
          j=0;
my code:
No, completely outside of the function "loop()"
AWOL,
Thank you so much!
const int N=100;
float voltage[N];
That's 802 bytes of memory gone, right there. Do you really need to store 200 floats? The "voltage" read is an int. Why not, if you really need floats, store the ints read, and produce the floats as needed?
The voltageValue array should definitely be int, since that is what analogRead() returns.
Frankly, I can't see that you need to save more than two readings, since it is only the current and previous readings that matter.
On the subject of Indentation and CRTL T (autoformat) I Love that tool for these two messages ""autoformat???: too many right curly braces or too many left curly braces.
Much of my education here came from CutNpaste... because I was uncomfortable writing sketches I would find one close and then find or write the necessary glue code to make it work. Very frequently before I learned to count the braces properly and place them in the correct order this tool saved my butt on a daily (almost) basis. There is another nice feature in the IDE and that is finding matching curly braces. Place the cursor on the open side of any curly brace and the IDE will draw a box around the matching curly brace... No box is an error and very easy to fix. I've noticed that I don't need to use it as often as I once did But that is because I spend two hours a day reading Prata's C++ Primer 5th ed. I have the 6th ed but it refers to the C11 ISO definition and the IDE more or less conforms to the C99 ISO definition. I used to say that my total knowledge of C & C++ could be written legibly on the head of a pin, now I need a small finishing nail..
Bob
