Solving Error Code " expected unqualified-id before string constant"
I have tried many things, checked the accolades, and can't find the problem.
I use an Arduino Due, with a u8g2 SH1106 oled 128x64, with a INA219 current sensor module.
I intend to get the measured readings on the oled. But It wont compile.
Could someone please look at the code, and help?
Code:
//    Copyright[free]
//    < Free for all to benefit from. >
// INCLUDE  LIBRARies:
#include <LiquidCrystal.h>
  #include <U8g2lib.h>                // OLED
#include <U8x8lib.h>                 // OLED
#include <Adafruit_INA219.h>        // voltage sensor
  #include <Adafruit_INA219.h>;   // VOLTage SENSor
  #include <Wire.h>;             //  I2c communication library
                          // oled constructor: no reset pin
    u8g2_Ssh1106_128X64_noname_1_hw_i2c u8g2(u8g2_r0, u8x8_pin_none);
                          // set font for oled display:
    u8g2.setFont(u8g2_xxx_xe);
    Adafruit_INA219 ina219_A;      // set name
                           // Adafruit_INA219 ina219_B(0x41);
                           // for SECOND BOARD, CHANGE SOLDER PAD sets ADRESS
    ina219_A.begin();
                          // Initialize first board (default address 0x40)
                          //  ina219_B.begin();
                          // Initialize second board with the address 0x41
void loop()   {
                                  // set floating integers
    float shuntvoltage = 0;
    float busvoltage   = 0;
    float current_mA   = 0;
    float loadvoltage  = 0;
                                   // measurements from ina219 i2c
    shuntvoltage = ina219.getShuntVoltage_mV();
    busvoltage   = ina219.getBusVoltage_V();
    current_mA   = ina219.getCurrent_mA();
    loadvoltage  = busvoltage + (shuntvoltage / 1000);
    power = (loadvoltage * current_mA);
                                    // print data
u8g2.drawStr(0, 15, "Bus Voltage:  ");
        u8g2.drawStr(busvoltage);
        u8g2.drawStr(" V");
u8g2.drawStr(0, 30, "Shunt Voltage:");
        u8g2.drawStr(shuntvoltage);
        u8g2.drawStr(" mV");
u8g2.drawStr(0, 45, "Load Voltage: ");
        u8g2.drawStr(loadvoltage);
        u8g2.drawStr(" V");
u8g2.drawStr(0, 60, "Current:      ");
        u8g2.drawStr(current_mA);
        u8g2.drawStr(" mA");
u8g2.drawStr(0, 75, "power:        ");
        u8g2.drawStr(power);
        u8g2.drawStr(" mW");
error code:
Arduino: 1.8.11 (Windows 10), Board: "Arduino Due (Programming Port)"
In file included from C:\Users\ibona\Documents\Arduino\libraries\U8g2\src/U8x8lib.h:45:0,
                 from C:\Users\ibona\Documents\Arduino\libraries\U8g2\src/U8g2lib.h:50,
                 from C:\Users\ibona\Documents\Arduino\BASIC_SKETCH_error\BASIC_SKETCH_error.ino:7:
C:\Users\ibona\Documents\Arduino\libraries\U8g2\src/clib/u8x8.h: In function 'void setup()':
C:\Users\ibona\Documents\Arduino\libraries\U8g2\src/clib/u8x8.h:124:8: error: expected unqualified-id before string constant
 extern "C" {
BASIC_SKETCH_error:59:13: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
"C:\Users\ibona\Documents\Arduino\libraries\U8g2\src/clib/u8x8.h:124:8: error: expected unqualified-id before string constant
extern "C" {
Is probably the cause.
Thank you!
(deleted)
Thanks spycatcher2k.
I missed that one, but problem stays the same.
"expected unqualified-id before string constant"
I don't know much about constructors, but can you have a comment inside one?
   U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
It seems it can be used, evanmars.
I removed the comment, and the error code stayed the same
extern "C" {
Move #include statements to outside of setup()
arduino_new:
I have no clue what you are saying here. Makes no sense at all. What do you suggest?
(deleted)
if I do that, I get even more error codes " not declared"
C:\Users\ibona\Documents\Arduino\BASIC_SKETCH_error\BASIC_SKETCH_error.ino: In function 'void setup()':
BASIC_SKETCH_error:6:4: error: 'U8G2_SH1106_128X64_NONAME_1_HW_I2C' was not declared in this scope
BASIC_SKETCH_error:6:39: error: expected ';' before 'u8g2'
BASIC_SKETCH_error:8:4: error: 'u8g2' was not declared in this scope
BASIC_SKETCH_error:8:17: error: 'u8g2_xxx_xe' was not declared in this scope
BASIC_SKETCH_error:11:4: error: 'Adafruit_INA219' was not declared in this scope
BASIC_SKETCH_error:11:20: error: expected ';' before 'ina219_A'
BASIC_SKETCH_error:13:3: error: 'ina219_A' was not declared in this scope
   ina219_A.begin();  // Initialize first board (default address 0x40)
C:\Users\ibona\Documents\Arduino\BASIC_SKETCH_error\BASIC_SKETCH_error.ino: In function 'void loop()':
BASIC_SKETCH_error:31:18: error: 'ina219' was not declared in this scope
BASIC_SKETCH_error:35:3: error: 'power' was not declared in this scope
   power = loadvoltage * current_mA ;
BASIC_SKETCH_error:38:4: error: 'u8g2' was not declared in this scope
    u8g2.drawStr(0,15,"Bus Voltage:   "); u8g2.drawStr(busvoltage);   u8g2.drawStr(" V");
exit status 1
//measurements
Makes no sense at all. (and is missing a semicolon - perhaps you could recycle the unwanted one here #include <wire.h>;)
TheMemberFormerlyKnownAsAWOL:
Makes no sense at all.;[/code])
Ah! you also don't get it. Thanks.
EVOSTARS:
Why initialise a bunch of variables to zero, then assign a new set of values?
That's what I don't get (unless you're being paid by the LOC)
Also, sp. "Wire.h"
thanks, and I updated the code on first message
EVOSTARS:
Well, that was a dumb thing to do.
What did you change?
Now the rest of the thread doesn't make sense.
No more errors. it all works.
topic can be closed
error was due to beginners virus
//INCLUDE  LIBRARies:
  #include <Adafruit_INA219.h> //VOLT sensor
  #include <wire.h> // i2C
// oled constructor: (rotation, [reset [, clock, data]])
//                    [full framebuffer, size = 1024 bytes]
  U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, U8X8_PIN_NONE);
    //  2ND_HW_I2C  If supported, use second hardware I2C (Arduino Wire lib)scl1 and sda1
// 4x voltage sensor met 4 adressen i2c
  Adafruit_INA219 ina219_A(0x40);
  Adafruit_INA219 ina219_C(0x44);
  Adafruit_INA219 ina219_D(0x45);
// variabelen floating point
  float shuntvoltageA = 0;
  float shuntvoltageB = 0;
  float shuntvoltageC = 0;
  float shuntvoltageD = 0;
u8g2.begin();
  ina219_B.begin();  // Initialize second board with the address 0x41
  ina219_C.begin();  // Initialize third board with the address 0x44
  ina219_D.begin();  // Initialize fourth board with the address 0x45
  shuntvoltageA  = ina219_A.getShuntVoltage_mV();
  shuntvoltageB  = ina219_B.getShuntVoltage_mV();
  shuntvoltageC  = ina219_C.getShuntVoltage_mV();
  shuntvoltageD  = ina219_D.getShuntVoltage_mV();
  u8g2.clearBuffer(); // initialises screen buffer
  u8g2.setFont(u8g2_font_8x13B_tf); // font
  // puts text into buffer:
  u8g2.drawStr(0,12,"VoltA=");
  u8g2.setCursor(55,12);
  u8g2.print(shuntvoltageA);
  u8g2.drawStr(100,12," mV");
  u8g2.drawStr(0,26,"VoltB=");
  u8g2.setCursor(55,26);
  u8g2.print(shuntvoltageB);
  u8g2.drawStr(100,26," mV");
  u8g2.drawStr(0,40,"VoltC=");
   u8g2.setCursor(55,40);
  u8g2.print(shuntvoltageC);
  u8g2.drawStr(100,40," mV");
  u8g2.drawStr(0,54,"VoltD=");
  u8g2.setCursor(55,54);
  u8g2.print(shuntvoltageD);
  u8g2.drawStr(100,54," mV");
  u8g2.sendBuffer();  // sends buffer to screen
  delay(1500);
//  busvoltage    = ina219_A.getBusVoltage_V(); // voorlopig niet nodig
//  current_mA    = ina219_A.getCurrent_mA();
//  loadvoltage   = busvoltage + (shuntvoltage / 1000);
//  power         = (current_mA * shuntvoltage);
I don't think there's a closed comment function.
But you can edit the title and add "[Solved]" as a prefix.
