Analog comparator Frequency Measurement
Put together the attached code and put it into a NANO and a UNO
The NANO shows triggering of ANALOG_COMP-vect with silly results that stay about the same irrespective of frequency iput. The UNO does not trigger
I have a signal generator with 5VP-P wave, set at 2.5VDC offset as will be seen on photo of generator and oscilloscope reading
Input is A1 and the mode is using the internal 1.1V reference
Can anyone tell me what I am doing wrong. It must be code, but I cannot find it
The photo shows the readings
Freq_Test_Rod_Rev1.ino (2.89 KB)
Please provide a wiring diagram.
I haven't found that photo in your post.
If I understand your post correctly you apply the signal to A1 but in the software you configure D7(AIN1) as input (ADCSRB=0).
Thanks for the reply, but
27,2 of the manual says
"When ADCSRB.ACME=0 or ADCSCRA.ADEN=1 , AIN1 is applied to the negative input of the Analog Converter"
SOLVED
I put the inputs into A0 and A1 ( ADC0/ADC1) not AIN0-D6/AIN1-D7 :slight_smile:
Duh!
:slight_smile: :slight_smile: :slight_smile:
