Hi All,
I have attached a 24V Sensor to an Arduino Board that has been modified to have capability of 24V. The issue i'm having is I have it reading the sensor through an analog port therefore using the AnalogRead function. I am getting different readings for when the sensor sees something vs not however these readings have a bit of a delay to them. Am I over-looking something?
Thanks,
- Matt
A4 is the pin of the sensor.
const int NextButton = 26;
const int SaveButton = 30;
const int UpButton = 32;
const int DownButton = 28;
const int ToggleButton = 40;
const int Led1 = 46;
const int Led2 = 44;
const int Led3 = 42;
const int Led4 = 8;
const int Led5 = 7;
const int ErrorLed = 38;
const int TestSwitch = A4;
const int ErrLight = 48;
class TimeKeeper
unsigned long previousTime;
long TimeVar1;
long TimeVar2;
long TimeVar3;
int a = 1;
public:
TimeKeeper(long TimeDelay1, long TimeDelay2, long TimeDelay3)
TimeVar1 = TimeDelay1;
TimeVar2 = TimeDelay2;
TimeVar3 = TimeDelay3;
previousTime = 0;
a = 1;
void Update()
unsigned long currentTime = millis();
if ((a==1) && (currentTime - previousTime >= TimeVar1)){
previousTime = currentTime;
Serial.println("SEQ1.1 Activated");
a = 2;
if ((a==2) && (currentTime - previousTime >= TimeVar2)){
Serial.println("SEQ2.1 Activated");
a = 3;
if ((a==3) && (currentTime - previousTime >= TimeVar3)){
Serial.println("SEQ3.1 Activated");
a = 1;
int BNextLogic = 0;
int BUpLogic = 0;
int BDownLogic = 0;
int ToggleLogic = 0;
int SaveButtonTrigger = 0;
int x = 0;
int a = 1;
unsigned long previousTimer = 0; //Previous Time for MAIN TIMER
unsigned int y[] = {100, 100, 100, 100, 100}; // Time ARRAY for MAIN TIMER
unsigned long buttonPreviousTime = 0; //Previous Time for Button Timer
unsigned long previousTimer2 = 0;
int buttonWait = 20; //Button wait Variable
int TestCheck = 0;
pinMode(NextButton, INPUT);
pinMode(SaveButton, INPUT);
pinMode(UpButton, INPUT);
pinMode(DownButton, INPUT);
pinMode(ToggleLogic, INPUT);
pinMode(Led1, OUTPUT);
pinMode(Led2, OUTPUT);
pinMode(Led3, OUTPUT);
pinMode(Led4, OUTPUT);
pinMode(Led5, OUTPUT);
pinMode(ErrLight, OUTPUT);
pinMode(ErrorLed, OUTPUT);
pinMode(TestSwitch, INPUT);
Serial.println("Starting...");
digitalWrite(ErrLight, HIGH);
digitalWrite(ErrLight, LOW);
attachInterrupt(digitalPinToInterrupt(38), savetrigger, CHANGE);
// ins.Update();
TestCheck = analogRead(TestSwitch);
unsigned long buttonCurrentTime = millis();
if (TestCheck >= 246){
//buttonPreviousTime = buttonCurrentTime;
Serial.print(TestCheck);
Serial.print(" | ");
Serial.print(buttonCurrentTime);
Serial.println(" | HIGH");
if (TestCheck <= 244){
Serial.println(" | LOW");
BNextLogic = digitalRead(NextButton);
if ((BNextLogic == HIGH) && (buttonCurrentTime - buttonPreviousTime >= buttonWait)){
x++;
if (x >= 5){
x = 0;
Serial.print("Time VAR: ");
Serial.print(x+1);
Serial.print(" selected. | ");
Serial.println(y[x]);
else {
Serial.print(x+1);
BUpLogic = digitalRead(UpButton);
if ((BUpLogic == HIGH) && (buttonCurrentTime - buttonPreviousTime >= buttonWait)){
y[x] = y[x]+100;
Serial.print("TimeVar ");
Serial.print(x+1);
Serial.print(" is now: ");
BDownLogic = digitalRead(DownButton);
if ((BDownLogic == HIGH) && (buttonCurrentTime - buttonPreviousTime >= buttonWait)){
y[x] = y[x]-100;
Serial.print(x+1);
SaveButtonTrigger = digitalRead(SaveButton);
if ((SaveButtonTrigger) && (buttonCurrentTime - buttonPreviousTime >= buttonWait)){
Serial.print(x+1);
Serial.println(" saved.");
savetrigger();
else {
ToggleLogic = digitalRead(ToggleButton);
if (ToggleLogic == HIGH){
digitalWrite(ErrorLed, LOW);
unsigned long Timer1 = millis();
if (a == 1){
if (Timer1 - previousTimer >= y[0]){
previousTimer = Timer1;
Serial.print("SEQ 1 | Running at: ");
Serial.print(y[0]);
Serial.print(" | Time: ");
Serial.println(Timer1);
digitalWrite(Led1, HIGH);
digitalWrite(Led2, LOW);
digitalWrite(Led3, LOW);
digitalWrite(Led4, LOW);
digitalWrite(Led5, LOW);
a = 2;
if (a == 2){
if (Timer1 - previousTimer >= y[1]){
Serial.print("SEQ 2 | Running at: ");
Serial.print(y[1]);
digitalWrite(Led2, HIGH);
digitalWrite(Led1, LOW);
a = 3;
if (a == 3){
if (Timer1 - previousTimer >= y[2]){
Serial.print("SEQ 3 | Running at: ");
Serial.print(y[2]);
a = 4;
digitalWrite(Led3, HIGH);
if (a == 4){
if (Timer1 - previousTimer >= y[3]){
Serial.print("SEQ 4 | Running at: ");
Serial.print(y[3]);
a = 5;
digitalWrite(Led4, HIGH);
if (a == 5){
if (Timer1 - previousTimer >= y[4]){
Serial.print("SEQ 5 | Running at: ");
Serial.print(y[4]);
a = 1;
digitalWrite(Led5, HIGH);
else {
digitalWrite(ErrorLed, HIGH);
switch (x){
case 0:
case 1:
case 2:
case 3:
case 4:
void savetrigger(){
int state = digitalRead(ErrorLed);
delay(200);
delay(200);
delay(200);
delay(200);
digitalWrite(ErrorLed, state);
