Hello,
Main question:
Could anybody perhaps help me understand how to incorporate the below code into my sketch, or some similar solution. I have an ISR and I want to read A0 and A1 in there.
want to incorporate this stuff: (my sketch below this one)
// FILE: analogRead8.h
// AUTHOR: Rob Tillaart
// DATE: 2015-05-15
// PUPROSE: fast analogRead 8 bit
#ifndef analogRead8_h
#define analogRead8_h
#define ANALOGREAD8_VERSION "0.0.1"
int analogReadP(uint8_t pin, uint8_t prescale=7)
uint8_t ADCSRA_TMP = ADCSRA;
prescale = constrain(prescale, 2, 7);
ADCSRA = (ADCSRA | 0x07) & (0xF8 | prescale);
int value = analogRead(pin);
ADCSRA = ADCSRA_TMP;
return value;
#endif
// --- END OF FILE ---
my sketch
sketch: toy oscilloscope
Citations:
File: Oscilloscope.ino
Title: Standalone Arduino 6 channel Triggered Oscilloscope
Author: Meeker6751
Verson: 2018.4.23
URL: Arduino forum/projects
File: Arduino Interupts
Author: amandaghassaei
URL: https://www.instructables.com/Arduino-Timer-Interrupts/
#define ul unsigned long
#define triggered false // choose with switch
#define continuous true //
bool SweepMode; // 'continuous' or 'triggered'
#define armed true // these 2 inside of trigered mode
#define froze false // trigrd
bool TriggerState; // 'armed' or 'froze'
#define falling false // trigger slope positive
#define rising true // trigger slope negative
bool TriggerDirection = rising; // 'rising' or 'falling'
volatile means can use in ISR like a global
volatile float pot_state;
//volatile float ch1_state
// adjustable variables
float TriggerVolts = 2.0; // trigger vdc; 0 <= TriggerVolts <= 5
// loop procedure variables
float ChannelFloor;
float ChannelHeight;
float ChannelScale; // proportion of signal to display
float TriggerDisplay; // vertical position of trigger
float TriggerLevel; // calculated from 'TriggerVolts'
int zero_line = 0;
//Pins used
int LED_pin = 4; //for indicating trgrint LED_state = LOW;
int switch_pin = 3; //for trgr
int ch1_pin = A0;
int ch2_pin = A1;
int pot_pin = A2; // potentiometer input
float ch1_prev = TriggerVolts; // initially, no last sample
ul ch2_prev = -1; // initially, no last sample
// debug variables
char debugging1[] = "EARSNOT";
char debugging2[] = "SACER";
char debugging3[] = "IRAK";
char debugging4[] = "YEAR";
*Function: Interupt setup
*Purpose: Set up timer
//sample clock
void interruptSetup() {
cli(); //stop interrupts
//set timer2 interrupt at 1MHz (ish?)
TCCR2A = 0; // set entire TCCR2A register to 0
TCCR2B = 0; // same for TCCR2B
TCNT2 = 0; //initialize counter value to 0
OCR2A = 2; // =
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS11 bit for 8 prescaler
TCCR2B |= (1 << CS11);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
sei(); //allow interrupts
} //end setup
Function : void read_trigger_choice(
Behavior: use a switch to choose for choose Sweepmode (continous or triggered)
sets Sweepmode (global bool no need for return)
void read_trigger_choice() {
int switch_state = digitalRead(switch_pin);
if (switch_state == LOW) {
SweepMode = continuous;
digitalWrite(LED_pin, HIGH);
} else if (switch_state == HIGH) {
SweepMode = triggered;
digitalWrite(LED_pin, LOW);
Function : void test_for_ch1_triggering_event()
Behavior: ch 1 look for event
output: armed or froze
void test_for_ch1_triggering_event() {
float ch1_state = analogRead(ch1_pin);
ch1_state = ch1_state * ChannelScale + ChannelFloor; // mapping from 0-1023 to 0-5 for display purposes
/*Serial.println(debugging4);
Serial.println("ch1_prev: ");
Serial.println(ch1_prev);
Serial.println("ch1_state: ");
Serial.println(ch1_state);
Serial.println("TriggerDirection: ");
Serial.println(TriggerDirection);
delay(3000);*/
if (SweepMode == triggered) {
if (ch1_state >= 0 and ((TriggerDirection == rising and ch1_state >= TriggerVolts and ch1_prev < TriggerVolts) or (TriggerDirection == falling and ch1_state <= TriggerVolts and ch1_prev > TriggerVolts))) {
TriggerState = froze;
TriggerState = armed;
ch1_prev = ch1_state;
Function : void test_for_ch2_triggering_event()
Behavior: ch21 look for event
void test_for_ch2_triggering_event() {
int ch2_state = analogRead(ch2_pin);
if (ch2_prev > 0 and ((TriggerDirection == rising and ch2_state >= TriggerLevel and ch2_prev < TriggerLevel)or (TriggerDirection == falling and ch2_state <= TriggerLevel and ch2_prev > TriggerLevel) )) {
int ch2_prev = ch2_state;
*Function: Interupt Service Routine
*Purpose: -Read signal
-set triggering mode
-set trigger state
ISR(TIMER2_COMPA_vect) {
read_trigger_choice();
Function : setup()
This is just some setup buisness.
ISR and timer setup need should come first nonetheless
pinMode(LED_pin, OUTPUT);
pinMode(switch_pin, INPUT);
pinMode(ch1_pin, INPUT);
pinMode(ch2_pin, INPUT);
pinMode(pot_pin, INPUT);
TriggerLevel = (TriggerVolts / 5.0) * 1023;
ChannelHeight = 5.0;
ChannelScale = 5.0 / 1024.0; //mapping from 0-1023 to 0-5 for display purposes
TriggerDisplay = TriggerVolts * ChannelScale + 5.0 - ChannelHeight;
interruptSetup();
Function : loop()
Behavior: In the loop the signal is actually drawn (3 choices continouse, armed, trigrd)
-Sweepmode (continous or triggered) and
-if in triggered mode then TriggerState is either (armed or froze)
ChannelFloor = 5.0 - ChannelHeight; // display trigger level, if applicable
//ch1 reading pin
//ch2 reading pin
float ch2_state = analogRead(ch2_pin);
ch2_state = ch2_state * ChannelScale + ChannelFloor;
//Y-scaling reading pin
pot_state = analogRead(pot_pin);
pot_state = pot_state * ChannelScale + ChannelFloor;
test_for_ch1_triggering_event();
*SweepMode = continous just show channels and Y-axis scaling
if (SweepMode == continuous) {
Serial.print("ch1:");
Serial.print(ch1_state);
Serial.print(" ");
Serial.print("ch2:");
Serial.print(ch2_state);
Serial.print(" ");
Serial.print("Y-axis-scaling:");
Serial.print(pot_state);
Serial.print(" ");
Serial.print("base-line:");
Serial.print(zero_line);
Serial.print(" ");
ChannelFloor -= ChannelHeight;
Serial.println(debugging1);
//delay(1000);
*SweepMode = triggered (looking for trigger) (show the trigger level and channels and Y-scaling)
else if ((SweepMode == triggered) && (TriggerState == armed)) {
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Serial.print("trigger-level: ");
Serial.print(TriggerVolts);
Serial.println(debugging2);
// delay(1000);
} else if ((SweepMode == triggered) && (TriggerState == froze)) {
//freeze
Serial.println(debugging3);
//delay(1000);
//Serial.begin(9600); //kills serial monitor
Side note: I measured my frequency to be about 100KHz (by driving a pin hi/low and scoping that). From my reading and researching it seems like this is about as fast as I will get in this application. This seems relevant because the analog read might be a limiting factor in the speed.
