Anemometer code help?
Hi, I'm trying to create an anemometer with Arduino Nano and Optocoupler Module LM393. I need to write on the display wind speed in km / h. I used a formula 2píR RPM * * (60/100), but it says it only multiples of 1.13.
You advise me please? I need to get out of this rotation speed in km / h.
Thank you
Ivica
CODE:
// Compute the RPM of a simple DC Motor using a photomicrosensor(PMS)
#include <Wire.h>
#include <LCD.h>
#define PMS_PIN A0 // Pin for signal from Photomicrosensor
#define LED_PIN 13 //Using Arduino's Internal LED; just as an indicator
boolean counted=false;
int t1=0,t2=0;
int hits=0;
int rps=0;
LiquidCrystal_I2C  lcd(0x27,2,1,0,4,5,6,7);
void setup(){
  pinMode(PMS_PIN, INPUT);
  pinMode(LED_PIN, OUTPUT);
  lcd.setBacklightPin(3,POSITIVE);
  lcd.setBacklight(HIGH); // NOTE: You can turn the backlight off by setting it to LOW instead of HIGH
  lcd.begin(16, 2);
  lcd.clear();
void loop(){
  t2 = millis();
  if(t2 >= (t1 + 1000)){
    rps = hits;
    hits = 0;
    t1=t2;
    rps = (rps*60);
    lcd.clear();
    lcd.print("Vitr: ");
    lcd.print(0.3142*rps*0.06);
    lcd.print(" km/h");
  if(digitalRead(PMS_PIN) == HIGH){
    if(!counted){
      counted = true;
      hits++;
    counted = false;
  digitalWrite(LED_PIN, digitalRead(PMS_PIN));
This is module what i use for count RPM:
https://www.aliexpress.com/item/J34-Free-Shipping-3-3V-5V-Slot-Type-Optocoupler-Module-LM393-Comparator-Slot-Type-For-Arduino/32402018702.html?spm=2114.13010608.0.86.hCDrvX
60 x 0.3142 x 0.06 = ?
And you are storing millis() in an integer. Try unsigned long to avoid truncation.
I am newbie with arduino. Can you help with code?
Ivica
What is the problem ?
Is it the mathematics of converting the rotational speed of the anemometer to a wind speed. If so, you have to say what the lengths of the anemometer arms are.
Apart from that, does it otherwise look ok. For example, when the wind speed increases, does the value in the display increase etc.?
Yes, it increases. I modified the code a bit and it seems much better, I just wanted to show it to 2 decimal places.
You can peek at it, please?
#include <Wire.h>
#include <LCD.h>
const float pi = 3.14159265;
int t1=0,t2=0;
int hits=0;
int rps=0;
void setup(){
  lcd.begin(16, 2);
  lcd.clear();
void loop(){
  t2 = millis();
    rps = hits;
    hits = 0;
    t1=t2;
    int rpm;
    int speedwind;
    rpm = (rps*60);
    lcd.clear();
    speedwind = ((2 * pi * 100.00 * rpm)/60.00) / 1000.00;
    //lcd.print(0.3142*rps*0.06);
    lcd.print(speedwind);
    lcd.print(" km/h");
    if(!counted){
      counted = true;
      hits++;
    counted = false;
But you missed the bit about using "unsigned long" for the value returned by "millis()"
Im no sure how. :-/
int t1=0,t2=0;
unsigned long t1=0,t2=0;
This gives the wind speed in meters per second, assuming that the arms of the anemometer are 100mm in length:
To convert meters per second to kilometers per hour, multiply by 3.6
In the pursuit of accuracy, the calculation will always be less than the actual wind speed. The wind speed needed to begin and continue rotation needs to be added to the equation. At the conclusion of the calculation, if the wind speed is exactly equal to the added wind speed, the effective wind speed can be assumed to be zero.
Paul
