Hi all,
I am trying to read the angle of a dc motor with encoder using arduino uno board.I want to use this engine :
http://www.roboweb.net/rw-ml-1350.html
360 degree necessary to measure and with %1 sensitivity of
What do I need?
Hi all,
What do I need?
Hi Kinqwolf,
Well, you'll need a driver to drive the motor itself, obviously.
If you want to read encoder, you can use 2 different approaches:
I suggest to go for #1 option, and if you think it does not satisfy you, try #2.
Avalonnw:
Hi Kinqwolf,
- Use Encoder library. Encoder Library, for Measuring Quadarature Encoded Position or Rotation Signals
In most cases it's great, simple and pretty accurate. It's good if you are position-dependant and can use all your resources counting "ticks" from encoder. You can even do a lot more stuff at the same time, but at some moment you'll find that your arduino can't handle any more procedures... Here is option 2 for this situation:- Use external counter and poll it time to time. I personally use this chip: HCTL-2022 (http://australia.rs-online.com/web/p/decoders-demultiplexers/4965642/). I will require a bit of an extra programming, but you'll get all your resources back and will be able to read your encoder not when it "ticks" another count, but anytime you want.
Thank you for your response, I've seen these methods. I want to do exactly, measure the angle of rotation by moving a disc.
For example:
Go with the library first.
Avalonnw:
Thanks but Can you share an example of the encoding here? and the engine's output shaft 12000 CPR (counts per revolution) value
I think if you follow the link I provided, you'll find all the useful information there as well as some example code.
