Great, got the above figured out with some small edits in the utility libraries, mcufriend_special and mcufriend_shield.
Now working on getting the touch screen calibrated. As mentioned in first post the XYpins share pins with D0-1 and RS/CS. Again, I can get it to work with Adafruit paint (so I guess this screen is a copy of an Adafruit 2.8TFT except that they left the SD card level shifter off, was able to sort that out fortunately)
The code that I am trying to use
At line 30 I have changed the Pins to the correct pins for my setup
Uncommented lines 48~50 as it does share pins (tried it with the lines still commented as well.)
// TouchScreen_Calibr_native for MCUFRIEND UNO Display Shields
// adapted by David Prentice
// for Adafruit's <TouchScreen.h> Resistive Touch Screen Library
// from Henning Karlsen's original UTouch_Calibration program.
// Many Thanks.
#define PORTRAIT 0
#define LANDSCAPE 1
#define USE_XPT2046 0
#define USE_LOCAL_KBV 1
#define TOUCH_ORIENTATION PORTRAIT
#if defined(USB_PID) && USB_PID == 0x804E // Arduino M0 Native
#define Serial SerialUSB
#endif
#define SWAP(x, y) { int t = x; x = y; y = t; }
#define TITLE "TouchScreen.h GFX Calibration"
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
// MCUFRIEND UNO shield shares pins with the TFT.
#if defined(ESP32)
int XP = 27, YP = 4, XM = 15, YM = 14; //most common configuration
#else
//int XP = 6, YP = A1, XM = A2, YM = 7; //most common configuration
int XP = 22, YP = A3, XM = A2, YM = 23; //next common configuration
//int XP=PB7,XM=PA6,YP=PA7,YM=PB6; //BLUEPILL must have Analog for YP, XM
#endif
#if USE_LOCAL_KBV
#include "TouchScreen_kbv.h" //my hacked version
#define TouchScreen TouchScreen_kbv
#define TSPoint TSPoint_kbv
#else
#include <TouchScreen.h> //Adafruit Library
#endif
TouchScreen ts(XP, YP, XM, YM, 300); //re-initialised after diagnose
TSPoint tp; //global point
void readResistiveTouch(void)
tp = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
//digitalWrite(YP, HIGH); //because TFT control pins
//digitalWrite(XM, HIGH);
// Serial.println("tp.x=" + String(tp.x) + ", tp.y=" + String(tp.y) + ", tp.z =" + String(tp.z));
uint16_t readID(void) {
uint16_t ID = tft.readID();
if (ID == 0xD3D3) ID = 0x9486;
return ID;
#define TFT_BEGIN() tft.begin(ID)
#define WHITE 0xFFFF
#define RED 0xF800
#define BLUE 0x001F
#define GREEN 0x07E0
#define BLACK 0x0000
//#define GRAY 0x2408 //un-highlighted cross-hair
#define GRAY BLUE //idle cross-hair colour
#define GRAY_DONE RED //finished cross-hair
bool ISPRESSED(void)
// .kbv this was too sensitive !!
// now touch has to be stable for 50ms
int count = 0;
bool state, oldstate;
while (count < 10) {
readResistiveTouch();
state = tp.z > 200; //ADJUST THIS VALUE TO SUIT YOUR SCREEN e.g. 20 ... 250
if (state == oldstate) count++;
else count = 0;
oldstate = state;
delay(5);
return oldstate;
uint32_t cx, cy, cz;
uint32_t rx[8], ry[8];
int32_t clx, crx, cty, cby;
float px, py;
int dispx, dispy, text_y_center, swapxy;
uint32_t calx, caly, cals;
char *Aval(int pin)
static char buf[2][10], cnt;
cnt = !cnt;
#if defined(ESP32)
sprintf(buf[cnt], "%d", pin);
#else
sprintf(buf[cnt], "A%d", pin - A0);
#endif
return buf[cnt];
void showpins(int A, int D, int value, const char *msg)
char buf[40];
sprintf(buf, "%s (%s, D%d) = %d", msg, Aval(A), D, value);
Serial.println(buf);
void bofe(char *buf)
tft.println(buf);
#if USE_XPT2046 == 0
bool diagnose_pins()
uint8_t i, j, Apins[2], Dpins[2], found = 0;
uint16_t value, Values[2];
Serial.println(F("Making all control and bus pins INPUT_PULLUP"));
Serial.println(F("Typical 30k Analog pullup with corresponding pin"));
Serial.println(F("would read low when digital is written LOW"));
Serial.println(F("e.g. reads ~25 for 300R X direction"));
Serial.println(F("e.g. reads ~30 for 500R Y direction"));
Serial.println(F(""));
for (i = A0; i < A5; i++) pinMode(i, INPUT_PULLUP);
for (i = 2; i < 10; i++) pinMode(i, INPUT_PULLUP);
for (i = A0; i < A4; i++) {
for (j = 5; j < 10; j++) {
pinMode(j, OUTPUT);
digitalWrite(j, LOW);
value = analogRead(i); // ignore first reading
if (value < 100 && value > 0) {
showpins(i, j, value, "Testing :");
if (found < 2) {
Apins[found] = i;
Dpins[found] = j;
Values[found] = value;
found++;
pinMode(j, INPUT_PULLUP);
if (found == 2) {
int idx = Values[0] < Values[1];
Serial.println(F("Diagnosing as:-"));
for (i = 0; i < 2; i++) {
showpins(Apins[i], Dpins[i], Values[i],
(Values[i] < Values[!i]) ? "XM,XP: " : "YP,YM: ");
XM = Apins[!idx]; XP = Dpins[!idx]; YP = Apins[idx]; YM = Dpins[idx];
ts = TouchScreen(XP, YP, XM, YM, 300); //re-initialise with pins
return true; //success
if (found == 0) Serial.println(F("MISSING TOUCHSCREEN"));
//else Serial.println(F("BROKEN TOUCHSCREEN"));
return false;
#endif
char buf[40];
uint16_t ID = readID();
TFT_BEGIN();
tft.fillScreen(TFT_NAVY);
tft.println("Waiting for Serial");
while (!Serial);
tft.fillScreen(TFT_BLUE);
Serial.println(TITLE);
bool ret = true;
#if USE_XPT2046 || defined(__arm__) || defined(ESP32)
Serial.println(F("Not possible to diagnose Touch pins on ARM or ESP32"));
#else
ret = diagnose_pins(); //destroys TFT pin modes
TFT_BEGIN(); //start again
#endif
tft.setRotation(TOUCH_ORIENTATION);
dispx = tft.width();
dispy = tft.height();
text_y_center = (dispy / 2) - 6;
sprintf(buf, "ID = 0x%04x", ID);
if (ret == false) {
centerprint("BROKEN TOUCHSCREEN", text_y_center);
fail();
startup();
int x, y, cnt, idx = 0;
tft.fillScreen(BLACK);
for (x = 10, cnt = 0; x < dispx; x += (dispx - 20) / 2) {
for (y = 10; y < dispy; y += (dispy - 20) / 2) {
if (++cnt != 5) drawCrossHair(x, y, GRAY);
centerprint("***********", text_y_center - 12);
centerprint("***********", text_y_center + 12);
if (++cnt != 5) calibrate(x, y, idx++, F(" X, Y, Pressure"));
cals = (long(dispx - 1) << 12) + (dispy - 1);
swapxy = rx[2] - rx[0];
//else swapxy = ry[2] - ry[0];
swapxy = (swapxy < -400 || swapxy > 400);
if (swapxy != 0) {
clx = (ry[0] + ry[1] + ry[2]); //rotate 90
crx = (ry[5] + ry[6] + ry[7]);
cty = (rx[0] + rx[3] + rx[5]);
cby = (rx[2] + rx[4] + rx[7]);
clx = (rx[0] + rx[1] + rx[2]); //regular
crx = (rx[5] + rx[6] + rx[7]);
cty = (ry[0] + ry[3] + ry[5]);
cby = (ry[2] + ry[4] + ry[7]);
clx /= 3;
crx /= 3;
cty /= 3;
cby /= 3;
px = float(crx - clx) / (dispx - 20);
py = float(cby - cty) / (dispy - 20);
// px = 0;
clx -= px * 10;
crx += px * 10;
cty -= py * 10;
cby += py * 10;
calx = (long(clx) << 14) + long(crx);
caly = (long(cty) << 14) + long(cby);
if (swapxy)
cals |= (1L << 31);
report(); // report results
while (true) {} // tread water
void readCoordinates()
int iter = 5000;
int failcount = 0;
int cnt = 0;
uint32_t tx = 0;
uint32_t ty = 0;
uint32_t tz = 0;
bool OK = false;
while (OK == false)
centerprint("* PRESS *", text_y_center);
while (ISPRESSED() == false) {}
centerprint("* HOLD! *", text_y_center);
cnt = 0;
iter = 400;
do
if (tp.z > 200) //.kbv
tx += tp.x;
ty += tp.y;
tz += tp.z;
cnt++;
failcount++;
} while ((cnt < iter) && (failcount < 10000));
if (cnt >= iter)
OK = true;
tx = 0;
ty = 0;
tz = 0;
cnt = 0;
if (failcount >= 10000)
fail();
cx = tx / iter;
cy = ty / iter;
cz = tz / iter;
void calibrate(int x, int y, int i, String msg)
drawCrossHair(x, y, WHITE);
readCoordinates();
centerprint("* RELEASE *", text_y_center);
drawCrossHair(x, y, GRAY_DONE);
rx[i] = cx;
ry[i] = cy;
char buf[40];
sprintf(buf, "\r\ncx=%ld cy=%ld cz=%ld %s", cx, cy, cz, msg.c_str());
Serial.print(buf);
while (ISPRESSED() == true) {}
void report()
uint16_t TS_LEFT, TS_RT, TS_TOP, TS_BOT, TS_WID, TS_HT, TS_SWAP;
int16_t tmp;
char buf[60];
centertitle(TITLE);
tft.println(F("To use the new calibration"));
tft.println(F("settings you must map the values"));
tft.println(F("from Point p = ts.getPoint() e.g. "));
tft.println(F("x = map(p.x, LEFT, RT, 0, tft.width());"));
tft.println(F("y = map(p.y, TOP, BOT, 0, tft.height());"));
tft.println(F("swap p.x and p.y if diff ORIENTATION"));
//.kbv show human values
TS_LEFT = (calx >> 14) & 0x3FFF;
TS_RT = (calx >> 0) & 0x3FFF;
TS_TOP = (caly >> 14) & 0x3FFF;
TS_BOT = (caly >> 0) & 0x3FFF;
TS_WID = ((cals >> 12) & 0x0FFF) + 1;
TS_HT = ((cals >> 0) & 0x0FFF) + 1;
TS_SWAP = (cals >> 31);
if (TOUCH_ORIENTATION == LANDSCAPE) { //always show PORTRAIT first
tmp = TS_LEFT, TS_LEFT = TS_BOT, TS_BOT = TS_RT, TS_RT = TS_TOP, TS_TOP = tmp;
tmp = TS_WID, TS_WID = TS_HT, TS_HT = tmp;
sprintf(buf, "\n\n*** COPY-PASTE from Serial Terminal:");
bofe(buf);
bool ts_landscape = (TOUCH_ORIENTATION == LANDSCAPE) ^ swapxy;
#if (USE_XPT2046)
sprintf(buf, "const int TS_LANDSCAPE=%d; //%s", ts_landscape, TITLE);
bofe(buf);
#else
if (ts_landscape) {
SWAP(XM, YP);
SWAP(XP, YM);
SWAP(TS_LEFT, TS_RT);
SWAP(TS_TOP, TS_BOT);
sprintf(buf, "const int XP=%d,XM=%s,YP=%s,YM=%d; //%dx%d ID=0x%04X",
XP, Aval(XM), Aval(YP), YM, TS_WID, TS_HT, readID());
sprintf(buf, "\nTouch Pin Wiring XP=%d XM=%s YP=%s YM=%d",
XP, Aval(XM), Aval(YP), YM);
tft.println(buf);
#endif
sprintf(buf, "const int TS_LEFT=%d,TS_RT=%d,TS_TOP=%d,TS_BOT=%d;",
TS_LEFT, TS_RT, TS_TOP, TS_BOT);
#if !defined(ARDUINO_AVR_LEONARDO)
for (int orient = 0; orient < 2; orient++) {
sprintf(buf, "\n%s CALIBRATION %d x %d",
orient ? "LANDSCAPE" : "PORTRAIT ", TS_WID, TS_HT);
bofe(buf);
sprintf(buf, "x = map(p.%s, LEFT=%d, RT=%d, 0, %d)",
orient ? "y" : "x", TS_LEFT, TS_RT, TS_WID);
bofe(buf);
sprintf(buf, "y = map(p.%s, TOP=%d, BOT=%d, 0, %d)",
orient ? "x" : "y", TS_TOP, TS_BOT, TS_HT);
bofe(buf);
tmp = TS_LEFT, TS_LEFT = TS_TOP, TS_TOP = TS_RT, TS_RT = TS_BOT, TS_BOT = tmp;
int16_t x_range = TS_LEFT - TS_RT, y_range = TS_TOP - TS_BOT;
if (abs(x_range) > 500 && abs(y_range) > 650) //LANDSCAPE
return;
sprintf(buf, "\n*** UNUSUAL CALIBRATION RANGES %d %d", x_range, y_range);
bofe(buf);
#endif
void drawCrossHair(int x, int y, uint16_t color)
tft.drawRect(x - 10, y - 10, 20, 20, color);
tft.drawLine(x - 5, y, x + 5, y, color);
tft.drawLine(x, y - 5, x, y + 5, color);
void centerprint(const char *s, int y)
int len = strlen(s) * 6;
tft.setTextColor(WHITE, RED);
tft.setCursor((dispx - len) / 2, y);
tft.print(s);
void centertitle(const char *s)
tft.fillRect(0, 0, dispx, 14, RED);
tft.fillRect(0, 14, dispx, 1, WHITE);
centerprint(s, 1);
tft.setCursor(0, 30);
tft.setTextColor(WHITE, BLACK);
void startup()
centertitle(TITLE);
tft.println(F("#define NUMSAMPLES 3 in Library\n"));
tft.println(F("Use a stylus or something"));
tft.println(F("similar to touch as close"));
tft.println(F("to the center of the WHITE"));
tft.println(F("crosshair. Keep holding"));
tft.println(F("until crosshair turns RED."));
tft.println(F("Repeat for all crosshairs.\n"));
tft.println(F("Report can be pasted from Serial\n"));
tft.println(F("Touch screen to continue"));
// waitForTouch();
void fail()
centertitle("Touch Calibration FAILED");
tft.println(F("Unable to read the position"));
tft.println(F("of the press. This is a"));
tft.println(F("hardware issue and can not"));
tft.println(F("be corrected in software."));
tft.println(F("check XP, XM pins with a multimeter"));
tft.println(F("check YP, YM pins with a multimeter"));
tft.println(F("should be about 300 ohms"));
while (true) {};
Serial Monitor
11:52:25.844 -> TouchScreen.h GFX Calibration
11:52:25.844 -> Making all control and bus pins INPUT_PULLUP
11:52:25.937 -> Typical 30k Analog pullup with corresponding pin
11:52:25.937 -> would read low when digital is written LOW
11:52:26.031 -> e.g. reads ~25 for 300R X direction
11:52:26.031 -> e.g. reads ~30 for 500R Y direction
11:52:26.077 ->
11:52:26.077 -> MISSING TOUCHSCREEN
11:52:26.638 -> ID = 0x9325
Screen displays:
Any pointers would be greatly appreciated.
EDIT: Tried setting #define USE_LOCAL_KBV 1 to 0 so the code will use the TouchScreen Library to no real effect.
I also gave the diagnose_Touchpins example sketch a try with a little massaging of the code with each attempted to see if I was missing something simple but also no luck.
EDIT2: MCUFRIEND example for simple buttons works, but the calibration is just a bit off. I thought I would just give it a try and see. So at least I know that the touch panel it self is deffinitely working and the pins are working as they should. Going to try work backwards through the button_simple example and try figure out why the calibration example is not working.
EDIT3: Got a step further, the diagnose_pins section now works, this was the hold up before. I see now that they were mapped for different digital pins vs what I am using which makes complete sense in the context of the shield plugged directly onto an UNO. The rest of the the calibration is still not working, the screen now requests a press to proceed with calibration but it is not detecting anything. I figure pin modes are are not being switched back somewhere.
Serial monitor now returns:
Testing : (A2, D22) = 26
Testing : (A3, D23) = 29
ID = 0x9325
tp.x=0, tp.y=0, tp.z =0
