When running a sketch that uses a DFROBOT BMM150 library in IDE 2 it will compile and run without issues. However when running the sketch in App Lab the library throws an error message: Sketch profile configured: FQBN="arduino:zephyr:unoq", Port="" The library ArxContainer has been automatically added from sketch project. The library ArxTypeTraits has been automatically added from sketch project. The library DFRobot_BMM150 has been automatically added from sketch project. The library DebugLog has been automatically added from sketch project. The library MsgPack has been automatically added from sketch project. The library SparkFun BMI270 Arduino Library has been automatically added from sketch project. /home/arduino/.arduino15/internal/DFRobot_BMM150_1.0.0_98c1a4170799e41f/DFRobot_BMM150/DFRobot_BMM150.cpp: In member function 'float DFRobot_BMM150::getCompassDegree()': /home/arduino/.arduino15/internal/DFRobot_BMM150_1.0.0_98c1a4170799e41f/DFRobot_BMM150/DFRobot_BMM150.cpp:229:26: error: 'M_PI' was not declared in this scope 229 | return compass * 180 / M_PI;
So question why is it being found under ide2 and not in app lab? think everything is updated.
Try to explicitly include #include <math.h> at the top of the sketch or the library, or define M_PI manually with #define M_PI 3.14159265358979323846 before it’s used.
Although the M_PI macro is defined as an extension by some implementations of the C++ standard library (example), it is not part of the official C++ specification:
The C++ standard library that is part of the UNO Q's toolchain does contain a definition of the macro, but conditionally:
The configuration of the "UNO Q Board" platform does not result in the conditions being met for the macro's definition under normal conditions.
I was able to get the definition via adjustment of the sketch code alone using the advice at the issue above in a simple case:
However, that approach doesn't work in a case like the "DFRobot_BMM150" library, where the macro is referenced via a separate translation unit from that of the sketch .ino files:
c:\Users\per\Documents\Arduino\libraries\DFRobot_BMM150\DFRobot_BMM150.cpp:229:26: error: 'M_PI' was not declared in this scope
So I think it would be necessary to either modify the source code of the library, or else add the -D_XOPEN_SOURCE=700 flag to the platform's compilation command patterns.
@ptillisch Yep tried a few things and came to the same conclusion that the library would need to be updated. But trying not to that as a lot of libraries that you would install would need to be modified for use with the Q - just a cut feel.
Changing the compile pattern would probably be the way to go. But a quick question is where in linux directory structure is arduino located? For that matter where are libraries installed - was poking around and couldn’t find them
EDIT:
Libs are located: ./home/arduino/.arduino15/internal/. Just do a CD to it
Not sure how to update the compile pattern in linux - located in ~/.arduino15/packages/arduino/hardware/zephyr/0.51.0
I add -D_XOPEN_SOURCE=700 to platforms.txt and that seemed to resolve the issue.
Just for documentation I edited the platforms.txt .ccp flags line to read: compiler.cpp.flags=-g -Os -std=gnu++17 -c -D_XOPEN_SOURCE=700 {compiler.warning_flags} {compiler.zephyr.macros} "@{compiler.zephyr.cxxflags_file}" {compiler.zephyr.common_ldflags} {compiler.zephyr.extra_ldflags} {compiler.zephyr.common_cxxflags} {compiler.zephyr.extra_cxxflags} -MMD -mcpu={build.mcu} {build.float-abi} {build.fpu}
Then opened applab and recompiled and now seeing
Acceleration in g's X: 0.007 Y: -0.012 Z: 0.992 Rotation in deg/sec X: 0.122 Y: 0.000 Z: 0.122
mag x = -3 uT
mag y = 6 uT
mag z = 0 uT
the angle between the pointing direction and north (counterclockwise) is:333.43
Acceleration in g's X: 0.006 Y: -0.012 Z: 0.993 Rotation in deg/sec X: 0.183 Y: 0.244 Z: 0.122
mag x = -4 uT
mag y = 6 uT
mag z = 0 uT
the angle between the pointing direction and north (counterclockwise) is:326.31
Acceleration in g's X: 0.006 Y: -0.011 Z: 0.994 Rotation in deg/sec X: 0.000 Y: -0.061 Z: 0.122
mag x = -3 uT
mag y = 6 uT
mag z = 0 uT
But not in serial monitor in applab but on Serial through a FTDI connector so still missing something I guess
