DVDdoug:
You can't fry it unless you apply excess voltage.
First off, thank you for the information. I thought I read somewhere that excess amperage could cause the coils inside to melt; or can I not get excess amperage without producing excess voltage?
MorganS:
You can just try it out at different voltages and see what happens. Measure the temperature of the motor. If it gets too hot* then reduce the voltage.
Thank you for the info. Mind elaborating on what "too hot" is? It gets just a tad warm, but there is a smell when it is running. Not quite burning smell, but ... grinding gears, maybe?
ReverseEMF:
Yes, and once you find a voltage where the motor seems to run OK, without getting "too hot", then put a current meter in series with the motor and the power supply, and then stall the motor -- i.e., stop the shaft from turning. This, of course, may be difficult for larger motors--AND DANGEROUS!! So be careful!!!. The current you read [assuming you are using a power supply that can deliver enough current], will be the "stall current", and this will be the maximum current the motor will ever need [at that voltage], so whatever you use to actually drive that motor [in it's target application], will need to be able to deliver that current.
Thank you for your reply. At 6V, I'm getting about .60A with no load, and .80A when stalled. If I run the motor through a transistor, and a Pro Mini can only supply about .40A per pin, could that blow a Pro Mini board?
In the past I've had really bad experience with Pro Mini and DC motors, to which I still haven't figured out the problem. I would very much like not to destroy another board.
Any tips on connecting DC motor being controlled by light sensor using Pro Mini, both powered with the same power supply?
Thanks all for your inputs!
