Anyone Able To Help Me Please
https://create.arduino.cc/editor/_/28bf1234-6e82-44cf-bde3-eb6071970b78/preview
Error Message:
In file included from C:\Users\Richard\AppData\Local\arduino\sketches\824537DA824B6194BF52041EAE251B2B\sketch\sketch_feb6b.ino.cpp:1:0:
C:\Users\Richard\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.7\cores\arduino/Arduino.h:28:10: fatal error: avr/pgmspace.h: No such file or directory
#include <avr/pgmspace.h>
compilation terminated.
exit status 1
Compilation error: exit status 1
Can Anyone Help Please
Hi @rich1970. The "Arduino AVR Boards" platform adds support for your Arduino board to Arduino IDE. It looks like your installation of this platform has somehow been corrupted. It should be possible to fix it removing and then re-installing the broken boards platform via the Arduino IDE Boards Manager. I'll provide instructions you can follow to do that:
  1. Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  2. Find the "Arduino AVR Boards" entry in the list of boards platforms.
  3. Hover the mouse pointer over the "Arduino AVR Boards" entry.
    You will see a ●●● icon appear at the top right corner of the entry.
  4. Click the ●●● icon.
    A menu will open.
  5. Select "Remove" from the menu.
    An "Uninstall" dialog will open.
  6. Click the "YES" button in the "Uninstall" dialog.
    The dialog will close.
  7. Wait for the uninstall process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully uninstalled platform ...
  8. Click the "INSTALL" button at the bottom of the "Arduino AVR Boards" entry.
  9. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully installed platform ...
Now try compiling or uploading your sketch once again. Hopefully this time everything will work as expected.
Hi @rich1970 !
Better than posting a link to your sketch is to copy the code here between code tags (which you get if you click on the <code/> button in the post editor. This is how it will look
#include <Bounce2.h>
#include <ClickEncoder.h>
#include <TimerOne.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Servo.h>
// OLED display TWI address
  0LED_ADDR should read OLED_ADDR
#define 0LED_ADDR 0x3C
#define SCREEN_WIDTH 128  // OLED display width, in pixels
#define SCREEN_HEIGHT 64  //OLED display height, in pixels
// Declaration for an SSD1306 display connected to 12C (SDA, SCL pins)
#define OLED_RESET -1  // Reset pin # (or-1 if sharing Arduino reset pin)
#define GEIGER_PIN 3    // geiger pin
#define BUZZER_PIN 2    // pin of piezo buzzer
#define BATTERY_PIN A3  // pin for reading battery voltage
#define LED_PIN 10      // first Led pin
#define SERVO_PIN 11    // servo pin
#define SERVOMIN 15  // min. postion of servo
#define SERVOMAX 93  // max. postion of servo
#define NMEAS 5  // number of countrate measurements for running average
int t_int = 1000;                             // integration time in ms
int counts = 0;                               // number of counts per intergation time
int counts_array[NMEAS] = { 0, 0, 0, 0, 0 };  // array for floating average
int index = 0;                                // index for floating average
double rate_cpm = 0;                          // count rate in cpm
double rate_uS_h = 0;                         // count rate in Sv/h
Missing ; after previousMillis_LED = 0 should read: previousMillis_LED = 0;
unsigned long previousMillis_LED = 0          // ms timer for blinking LEDs
  unsigned long previousMillis = 0;           // ms timer for countrate calculation
unsigned long currentMillis = 0;              // ms timer for countrate calculation
int LED = LED_PIN;                            // current Led to blink
The following array lcd_bmp[] is not well formatted,
in addition some , are missing
further the final bracket } is also missing
It is not clear if the array is complete ...
static const unsigned char PROGMEM lcd_bmp[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xE0, 0x00,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x1C, 0x00,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x0E, 0x00,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x1F, 0x00,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0x1F, 0x80,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x1F, 0xC0 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xC0, 0x3F, 0xE0 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xC0, 0xC0, 0xF0 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xC0, 0x3F, 0xF0,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xE0, 0x7F, 0xF8,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xE0, 0x7F, 0xF8,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xF8,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xF0, 0x7F, 0xF8,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xC0, 0x3F, 0xF8,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x03, 0xF8,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x20, 0x40, 0x38,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x80, 0x08,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x09, 0x00, 0x08,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x0F, 0x00, 0x08,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x1F, 0x80, 0x18,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x3F, 0xC0, 0x10,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x7F, 0xC0, 0x30,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0xFF, 0xE0, 0x20,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0xFF, 0xF0, 0x40,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0xFF, 0xF8, 0xC0,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xF9, 0x80,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFE, 0x00,
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x00,
One line above the array is not complete ...
In the next line there should be a space
between PROGMEM and f1
It should read f1[] instead of f1{}
                                                 static const unsigned char PROGMEMf1{} = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x21,
The array above is not correctly completed
        static const unsigned char PROGMEM bt1[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
// define display
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Servo myservo;  // create servo object to control a servo
  // setup the buzzer pin
  pinMode(BUZZER_PIN, OUTPUT);
  // setup the LED pins
  for (int i = LED_PIN; i > LED_PIN - 7; --i) {
pinmode() should read pinMode()
    pinmode(i, OUTPUT);
  // setup the geiger pin
  pinMode(GEIGER_PIN, INPUT_PULLUP);
  attachinterrupt(digitalPinToInterrup(GEIGER_PIN), triggerGeiger, LOW);
  //initialize and clear display
  display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColour(WHITE);
  display.setCursor(10, 0);
  display.printin("PKE Meter");
  display.setTextSize(1);
  display.setCursor(20, 32);
  display.printin("Geiger Counter");
  display.display();
  myservo.(SERVO_PIN);  //attaches the servo to the servo object
  delay(3000);
  countRate();
//calculate count Rate in cpm
void countRate() {
  currentMilis = Milis();
  unsigned long dt = currentMilis - previousMilis;          // last update of display
  unsigned long dt_LED = currentMilis - previousMilis_LED;  // last update of LEDs
  // update display after integration time
  if (dt > t_int) {
    display.drawBitmap(-10, 0, lcd_bmp, 128, 32, White);  // draw radioactive symbol
    Symbol
      display.drawBitmap(0, 0, fl, 128, 32, WHITE);  // draw battery symbol
    // calculate floating avarage
    counts_array[index] = counts int surnCounts = 0;
    for (int i = 0; 1 < NMEAS; ++i) {
      sumCounts += counts_array[i];
    index++;
    if (index == NMEAS) index = 0;
    rate_cpm = (double)(sumCounts) / (double)(NMEAS) / (double)(dt)*1000. * 60.;
    rate_uS_h = rate_cpm * 0.0063;  //conversion according to htts://
    www.pocketmagic.net / tube - sbm - 20 - % D1 % 81 % D0 % B1 % D0 % BC - 20 - geiger - tube / counts = 0;
    previousMilis = currentMilisl;
    moveServo();
    printRate();
    batterylevel();
    display.display();
  // blink the LEDs according to count rate
  if (dt_LED > 1 / rate_cpm * 60 * 1000) {
    digitalWrite(LED, LOW);
    LED--;
    LED--;
    if (LED == LED_7) LED = LED_PIN;
    digitalwrite(LED, HIGH);
    previousMilis_LED = currentMilis;
// counter/buzzer triggered by interrupt
void triggerGeiger() {
  counts++;
  digitalWrite(BUZZER_PIN, HIGH);
  delay(1);
  digitalWrite(BUZZER_PIN, LOW);
// update count rate on display
void printRate() {
  char buffer_cpm[16];
  char buffer_uS[16];
dtostrf(rate_cpm,2,0,buffer_cpm;
dtostrf(rate_uS_h,3,1,buffer_uS);
display.setTextColor(WHITE);
display.SetCursor(10,0);
display.printin(buffer_cpm);
display.setCursor(10,40);
display.printin(buffer_uS);
display.setCursor(60,0);display.printin("cpm");
display.setCursor(60,40);
// move servo
voidmoveServo() {
  int pos = map(rate_cpm, 0, 800, SERVOMAX, SERVOMIN);
  if (pos < SERVOMIN) POS = SERVOMIN;
  myservo.write(pos);
// read battery level
void batterylevel() {
  int analog_value = analogREAD(BATTERY_PIN);
double voltage = (analog_value*5.0 / 1024.0;
if (voltage < 0.1)
    voltage = 0.0;
if(voltage >3.3){
    display.drawBitmap(0, 0, bt1, 128, 32, WHITE);
    if (voltage > 3.4) {
      display.drawBitmap(0, -5, bt1, 128, 32, WHITE);
      if (voltage > 3.5) {
        display.drawBitmap(0, -10, bt1, 128, 32, WHITE) if (voltage > 3.6) {
          display.drawBitmap(0, -15, bt1, 128, 32, White);
          if (voltage > 3.8) {
            display.drawBitmap(0, -20, bt1, 128, 32, WHITE);
The missing avr library is not the only problem that you'll have with the code I found in your Arduino Cloud sketch ...
I have marked a few of them in the sketch above, just look for the comment lines marked by
  see comments between these lines
There are definetely a lot more mistakes in the sketch, e.g. misspelled variables
  • currentMilis (while currentMillis is declared)
  • previousMilis (while previousMillis is declared)
  • currentMilis = Milis(); (there is no function Milis() but millis() )
[Edit:] While trying to remove all the mistakes in your sketch I think I found the original source
Original Sketch
 * Code for PKE meter Geiger counter project
 * Moritz v. Sivers
#include <Wire.h>
#include <Servo.h>
#define OLED_ADDR   0x3C
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define BUZZER_PIN 2      // pin of piezo buzer
#define LED_PIN 10        // first LED pin
#define SERVOMIN 15        // min. position of servo
#define SERVOMAX 93       // max. position of servo
int counts_array[NMEAS] = {0,0,0,0,0};  // array for floating average
double rate_cpm = 0.;    // count rate in cpm
double rate_uS_h = 0.;  // count rate in Sv/h
unsigned long previousMillis_LED = 0; // ms timer for blinking LEDs
int LED = LED_PIN;                // current LED to blink
//volatile byte state = LOW;      // state of interrupt pin
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x1F, 0xC0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xC0, 0x3F, 0xE0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
static const unsigned char PROGMEM fl[] =
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C,
// define display
  pinMode(BUZZER_PIN,OUTPUT);
  for(int i=LED_PIN; i>LED_PIN-7; --i) {
    pinMode(i,OUTPUT);
  pinMode(GEIGER_PIN,INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(GEIGER_PIN), triggerGeiger, LOW);
  // initialize and clear display
  display.setCursor(10,0);
  display.println("PKE Meter");
  display.setCursor(20,32);
  display.println("Geiger Counter");
  display.display();
  myservo.attach(SERVO_PIN);  // attaches the servo to the servo object
  delay(3000);
  countRate();
// calculate count rate in cpm
void countRate() {
  currentMillis = millis();
  unsigned long dt = currentMillis - previousMillis;  // last update of display
  unsigned long dt_LED = currentMillis - previousMillis_LED; // last update of LEDs
  if(dt > t_int) {
    display.drawBitmap(-10, 0, lcd_bmp, 128, 32, WHITE); // draw radioactive symbol
    // calculate floating average
    counts_array[index] = counts;
    int sumCounts = 0;
    for(int i=0; i<NMEAS; ++i) {
    index++;
    if(index==NMEAS) index=0;
    rate_cpm = (double)(sumCounts)/(double)(NMEAS)/(double)(dt)*1000.*60.;
    rate_uS_h = rate_cpm*0.0063;  // conversion according to https://www.pocketmagic.net/tube-sbm-20-%D1%81%D0%B1%D0%BC-20-geiger-tube/
    counts = 0;
    moveServo();
    printRate();
    batteryLevel();
    display.display();
  if(dt_LED>1/rate_cpm*60*1000) {
    digitalWrite(LED,LOW);
    LED--;
    if(LED==LED_PIN-7) LED=LED_PIN;
    digitalWrite(LED,HIGH);
    previousMillis_LED = currentMillis;
  counts++;
  digitalWrite(BUZZER_PIN,HIGH);
  delay(1);
  digitalWrite(BUZZER_PIN,LOW);
void printRate() {
  char buffer_uS[16];
  dtostrf(rate_cpm,2,0,buffer_cpm);
  display.println(buffer_cpm);
  display.println(buffer_uS);
  display.println("cpm");
  display.println("uSv/h");
// move servo
void moveServo() {
  int pos = map(rate_cpm,0,800,SERVOMAX,SERVOMIN);
  if(pos<SERVOMIN) pos = SERVOMIN;
  myservo.write(pos);
void batteryLevel() {
  int analog_value = analogRead(BATTERY_PIN);
  double voltage = (analog_value * 5.0) / 1024.0;
   if (voltage < 0.1)
     voltage=0.0;
   if(voltage > 3.3) {
    if(voltage > 3.4) {
      if(voltage > 3.5) {
        display.drawBitmap(0, -10, bt1, 128, 32, WHITE);
        if(voltage > 3.6) {
          display.drawBitmap(0, -15, bt1, 128, 32, WHITE);
          if(voltage > 3.8) {
Source: https://www.hackster.io/mvonsivers/pke-meter-geiger-counter-1e1144
Your sketch looks as if it was taken from a print by scanning and OCR ... I found numerous typical OCR mistakes ...
Am I right?
thats brilliant thankyou for that
Yes You Are Right
Its Saying No such File <Bounce2.h> Don't now if you can help with that Thxs rich
C:\Users\Richard\AppData\Local\Temp.arduinoIDE-unsaved202617-33088-2s0las.7eodt\sketch_feb7f\sketch_feb7f.ino:9:10: fatal error: Bounce2.h: No such file or directory
exit status 1
Compilation error: Bounce2.h: No such file or directory
Have you installed the Bounce2 library?
Could You Help Identify The Faults With This Code Please Rich
Ps As i am having problem's Uploading it
Are you using the Arduino Cloud Editor or a local Arduino IDE?
See post #8
 * Moritz v. Sivers
#include <Wire.h>
#include <Servo.h>
// define display
    pinMode(i,OUTPUT);
  display.display();
  delay(3000);
  countRate();
void countRate() {
  if(dt > t_int) {
    int sumCounts = 0;
    index++;
    counts = 0;
    moveServo();
    printRate();
    batteryLevel();
    display.display();
    LED--;
  counts++;
  delay(1);
void printRate() {
  char buffer_uS[16];
// move servo
void moveServo() {
  myservo.write(pos);
   if (voltage < 0.1)
     voltage=0.0;
   if(voltage > 3.3) {
    if(voltage > 3.4) {
      if(voltage > 3.5) {
        if(voltage > 3.6) {
          if(voltage > 3.8) {
Have you installed all the required libraries?
original code is here PKE Meter Geiger Counter - Hackster.io
yes
Please post code always inside <code/> tags !!!!!
You create the tags by clicking in this button
any help on it
Using the Library Manager?
there is nothing in libary about <ClickEncorder.h>
You can outcomment the line like this
//#include <ClickEncoder.h>
I commented out the line to see where the library is used, but nothing was displayed!
It seems to have no influence on the code. After installation of the relevant libraries and outcommenting the line the code from the page compiles for Arduino Nano in my local Arduino IDE 2.3.7
Sketch uses 20854 bytes (67%) of program storage space. Maximum is 30720 bytes.
Global variables use 638 bytes (31%) of dynamic memory, leaving 1410 bytes for local variables. Maximum is 2048 bytes.
but the Cloud Editor throws an error while linking
collect2: error: ld returned 1 exit status
