Greetings all,
I'm working on a charitable project and have the following causing me to want to rip my hair out!
uint8_t data[] = "zzz";
What I need to do is append "xxxx" to the end of the "zzz"
Further to this Im looking for a very short simple method of accessing the content by means of an index.
For example:
data[1] needs to return a "z"
and data[4] needs to return a "x"
A solution would help me greatly,
Kind Regards
system
April 15, 2015, 4:20pm
2
You can not do that. The array data is sized to hold exactly three bytes.
You could:
uint8_t data[20 ] = "zzz";
strcat((cahr *)data, "xxxx");
PaulS-
The array is actually 4 bytes (with room for the '\0') but your point is the same.
I was just saying that if you create a string array and let the compiler set the size by providing no size in the [] brackets, it creates a string with the trailing nul, not the exact size of the characters, unless you do this:
char array[3] = "zzz";
which creates a string without the trailing nul.
You asked about indexing, it's easy. You just do this: data[index], where index is a variable.
system
April 16, 2015, 9:47am
7
unless you do this:
Actually, it doesn't. What is DOES is this:
sketch_apr16a:1: error: initializer-string for array of chars is too long
C allows you to omit the null terminator in a string initializer like that, but C++ does not.
DRSolomon:
For example:
An array index starts at 0.
