I was trying to run Arducam mini 5MP OV5642 PLUS with Arduino Uno on the serial monitor, everything seems ok but on the host v2 it shows COM open fail.
Here's the code:
// ArduCAM Mini demo (C)2017 Lee
// Web: http://www.ArduCAM.com
// This program is a demo of how to use most of the functions
// of the library with ArduCAM Mini camera, and can run on any Arduino platform.
// This demo was made for ArduCAM_Mini_5MP_Plus.
// It needs to be used in combination with PC software.
// It can test OV5642 functions.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM_Mini_5MP_Plus
// and use Arduino IDE 1.6.8 compiler or above
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include "memorysaver.h"
//This demo can only work on OV5642_MINI_5MP_Plus platform.
//#if !(defined OV5642_MINI_5MP_PLUS)
// #error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
//#endif
#define BMPIMAGEOFFSET 66
const char bmp_header[BMPIMAGEOFFSET] PROGMEM =
0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x28, 0x00,
0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x03, 0x00,
0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0x1F, 0x00,
0x00, 0x00
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
bool is_header = false;
int mode = 0;
uint8_t start_capture = 0;
ArduCAM myCAM( OV5642, CS );
uint8_t read_fifo_burst(ArduCAM myCAM);
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
Serial.begin(921600);
#endif
Serial.println(F("ACK CMD ArduCAM Start! END"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55){
Serial.println(F("ACK CMD SPI interface Error! END"));
delay(1000);continue;
}else{
Serial.println(F("ACK CMD SPI interface OK. END"));break;
while(1){
//Check if the camera module type is OV5642
myCAM.wrSensorReg16_8(0xff, 0x01);
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if((vid != 0x56) || (pid != 0x42)){
Serial.println(F("ACK CMD Can't find OV5642 module! END"));
else{
Serial.println(F("ACK CMD OV5642 detected. END"));break;
//Change to JPEG capture mode and initialize the OV5642 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK); //VSYNC is active HIGH
myCAM.OV5642_set_JPEG_size(OV5642_320x240);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES,0x00);
uint8_t temp = 0xff, temp_last = 0;
if (Serial.available())
temp = Serial.read();
switch (temp)
case 0:
myCAM.OV5642_set_JPEG_size(OV5642_320x240);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_320x240 END"));
temp = 0xff;
case 1:
myCAM.OV5642_set_JPEG_size(OV5642_640x480);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_640x480 END"));
temp = 0xff;
case 2:
myCAM.OV5642_set_JPEG_size(OV5642_1024x768);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_1024x768 END"));
temp = 0xff;
case 3:
temp = 0xff;
myCAM.OV5642_set_JPEG_size(OV5642_1280x960);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_1280x960 END"));
case 4:
temp = 0xff;
myCAM.OV5642_set_JPEG_size(OV5642_1600x1200);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_1600x1200 END"));
case 5:
temp = 0xff;
myCAM.OV5642_set_JPEG_size(OV5642_2048x1536);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_2048x1536 END"));
case 6:
temp = 0xff;
myCAM.OV5642_set_JPEG_size(OV5642_2592x1944);delay(1000);
Serial.println(F("ACK CMD switch to OV5642_2592x1944 END"));
case 0x10:
mode = 1;
temp = 0xff;
start_capture = 1;
Serial.println(F("ACK CMD CAM start single shoot. END"));
case 0x11:
temp = 0xff;
myCAM.InitCAM();
#if !(defined (OV2640_MINI_2MP))
myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
#endif
case 0x20:
mode = 2;
temp = 0xff;
start_capture = 2;
Serial.println(F("ACK CMD CAM start video streaming. END"));
case 0x30:
mode = 3;
temp = 0xff;
start_capture = 3;
case 0x31:
temp = 0xff;
myCAM.set_format(BMP);
myCAM.InitCAM();
myCAM.clear_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.wrSensorReg16_8(0x3818, 0x81);
myCAM.wrSensorReg16_8(0x3621, 0xA7);
case 0x40:
myCAM.OV5642_set_Light_Mode(Advanced_AWB);temp = 0xff;
Serial.println(F("ACK CMD Set to Advanced_AWB END"));break;
case 0x41:
myCAM.OV5642_set_Light_Mode(Simple_AWB);temp = 0xff;
Serial.println(F("ACK CMD Set to Simple_AWB END"));break;
case 0x42:
myCAM.OV5642_set_Light_Mode(Manual_day);temp = 0xff;
Serial.println(F("ACK CMD Set to Manual_day END"));break;
case 0x43:
myCAM.OV5642_set_Light_Mode(Manual_A);temp = 0xff;
Serial.println(F("ACK CMD Set to Manual_A END"));break;
case 0x44:
myCAM.OV5642_set_Light_Mode(Manual_cwf);temp = 0xff;
Serial.println(F("ACK CMD Set to Manual_cwf END"));break;
case 0x45:
myCAM.OV5642_set_Light_Mode(Manual_cloudy);temp = 0xff;
Serial.println(F("ACK CMD Set to Manual_cloudy END"));break;
case 0x50:
myCAM.OV5642_set_Color_Saturation(Saturation4);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation+4 END"));break;
case 0x51:
myCAM.OV5642_set_Color_Saturation(Saturation3);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation+3 END"));break;
case 0x52:
myCAM.OV5642_set_Color_Saturation(Saturation2);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation+2 END"));break;
case 0x53:
myCAM.OV5642_set_Color_Saturation(Saturation1);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation+1 END"));break;
case 0x54:
myCAM.OV5642_set_Color_Saturation(Saturation0);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation+0 END"));break;
case 0x55:
myCAM.OV5642_set_Color_Saturation(Saturation_1);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation-1 END"));break;
case 0x56:
myCAM.OV5642_set_Color_Saturation(Saturation_2);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation-2"));break;
case 0x57:
myCAM.OV5642_set_Color_Saturation(Saturation_3);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation-3 END"));break;
case 0x58:
myCAM.OV5642_set_Light_Mode(Saturation_4);temp = 0xff;
Serial.println(F("ACK CMD Set to Saturation-4 END"));break;
case 0x60:
myCAM.OV5642_set_Brightness(Brightness4);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness+4 END"));break;
case 0x61:
myCAM.OV5642_set_Brightness(Brightness3);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness+3 END"));break;
case 0x62:
myCAM.OV5642_set_Brightness(Brightness2);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness+2 END"));break;
case 0x63:
myCAM.OV5642_set_Brightness(Brightness1);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness+1 END"));break;
case 0x64:
myCAM.OV5642_set_Brightness(Brightness0);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness+0 END"));break;
case 0x65:
myCAM.OV5642_set_Brightness(Brightness_1);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness-1 END"));break;
case 0x66:
myCAM.OV5642_set_Brightness(Brightness_2);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness-2 END"));break;
case 0x67:
myCAM.OV5642_set_Brightness(Brightness_3);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness-3 END"));break;
case 0x68:
myCAM.OV5642_set_Brightness(Brightness_4);temp = 0xff;
Serial.println(F("ACK CMD Set to Brightness-4 END"));break;
case 0x70:
myCAM.OV5642_set_Contrast(Contrast4);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast+4 END"));break;
case 0x71:
myCAM.OV5642_set_Contrast(Contrast3);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast+3 END"));break;
case 0x72:
myCAM.OV5642_set_Contrast(Contrast2);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast+2 END"));break;
case 0x73:
myCAM.OV5642_set_Contrast(Contrast1);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast+1 END"));break;
case 0x74:
myCAM.OV5642_set_Contrast(Contrast0);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast+0 END"));break;
case 0x75:
myCAM.OV5642_set_Contrast(Contrast_1);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast-1 END"));break;
case 0x76:
myCAM.OV5642_set_Contrast(Contrast_2);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast-2 END"));break;
case 0x77:
myCAM.OV5642_set_Contrast(Contrast_3);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast-3 END"));break;
case 0x78:
myCAM.OV5642_set_Contrast(Contrast_4);temp = 0xff;
Serial.println(F("ACK CMD Set to Contrast-4 END"));break;
case 0x80:
myCAM.OV5642_set_hue(degree_180);temp = 0xff;
Serial.println(F("ACK CMD Set to -180 degree END"));break;
case 0x81:
myCAM.OV5642_set_hue(degree_150);temp = 0xff;
Serial.println(F("ACK CMD Set to -150 degree END"));break;
case 0x82:
myCAM.OV5642_set_hue(degree_120);temp = 0xff;
Serial.println(F("ACK CMD Set to -120 degree END"));break;
case 0x83:
myCAM.OV5642_set_hue(degree_90);temp = 0xff;
Serial.println(F("ACK CMD Set to -90 degree END"));break;
case 0x84:
myCAM.OV5642_set_hue(degree_60);temp = 0xff;
Serial.println(F("ACK CMD Set to -60 degree END"));break;
case 0x85:
myCAM.OV5642_set_hue(degree_30);temp = 0xff;
Serial.println(F("ACK CMD Set to -30 degree END"));break;
case 0x86:
myCAM.OV5642_set_hue(degree_0);temp = 0xff;
Serial.println(F("ACK CMD Set to 0 degree END"));break;
case 0x87:
myCAM.OV5642_set_hue(degree30);temp = 0xff;
Serial.println(F("ACK CMD Set to 30 degree END"));break;
case 0x88:
myCAM.OV5642_set_hue(degree60);temp = 0xff;
Serial.println(F("ACK CMD Set to 60 degree END"));break;
case 0x89:
myCAM.OV5642_set_hue(degree90);temp = 0xff;
Serial.println(F("ACK CMD Set to 90 degree END"));break;
case 0x8a:
myCAM.OV5642_set_hue(degree120);temp = 0xff;
Serial.println(F("ACK CMD Set to 120 degree END"));break ;
case 0x8b:
myCAM.OV5642_set_hue(degree150);temp = 0xff;
Serial.println(F("ACK CMD Set to 150 degree END"));break ;
case 0x90:
myCAM.OV5642_set_Special_effects(Normal);temp = 0xff;
Serial.println(F("ACK CMD Set to Normal END"));break ;
case 0x91:
myCAM.OV5642_set_Special_effects(BW);temp = 0xff;
Serial.println(F("ACK CMD Set to BW END"));break ;
case 0x92:
myCAM.OV5642_set_Special_effects(Bluish);temp = 0xff;
Serial.println(F("ACK CMD Set to Bluish END"));break ;
case 0x93:
myCAM.OV5642_set_Special_effects(Sepia);temp = 0xff;
Serial.println(F("ACK CMD Set to Sepia END"));break ;
case 0x94:
myCAM.OV5642_set_Special_effects(Reddish);temp = 0xff;
Serial.println(F("ACK CMD Set to Reddish END"));break ;
case 0x95:
myCAM.OV5642_set_Special_effects(Greenish);temp = 0xff;
Serial.println(F("ACK CMD Set to Greenish END"));break ;
case 0x96:
myCAM.OV5642_set_Special_effects(Negative);temp = 0xff;
Serial.println(F("ACK CMD Set to Negative END"));break ;
case 0xA0:
myCAM.OV5642_set_Exposure_level(Exposure_17_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to -1.7EV"));break ;
case 0xA1:
myCAM.OV5642_set_Exposure_level(Exposure_13_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to -1.3EV END"));break ;
case 0xA2:
myCAM.OV5642_set_Exposure_level(Exposure_10_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to -1.0EV END"));break ;
case 0xA3:
myCAM.OV5642_set_Exposure_level(Exposure_07_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to -0.7EV END"));break ;
case 0xA4:
myCAM.OV5642_set_Exposure_level(Exposure_03_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to -0.3EV END"));break ;
case 0xA5:
myCAM.OV5642_set_Exposure_level(Exposure_default);temp = 0xff;
Serial.println(F("ACK CMD Set to -Exposure_default END"));break ;
case 0xA6:
myCAM.OV5642_set_Exposure_level(Exposure07_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to 0.7EV END"));break ;
case 0xA7:
myCAM.OV5642_set_Exposure_level(Exposure10_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to 1.0EV END"));break ;
case 0xA8:
myCAM.OV5642_set_Exposure_level(Exposure13_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to 1.3EV END"));break ;
case 0xA9:
myCAM.OV5642_set_Exposure_level(Exposure17_EV);temp = 0xff;
Serial.println(F("ACK CMD Set to 1.7EV END"));break ;
case 0xB0:
myCAM.OV5642_set_Sharpness(Auto_Sharpness_default);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Sharpness default END"));break ;
case 0xB1:
myCAM.OV5642_set_Sharpness(Auto_Sharpness1);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Sharpness +1 END"));break ;
case 0xB2:
myCAM.OV5642_set_Sharpness(Auto_Sharpness2);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Sharpness +2 END"));break ;
case 0xB3:
myCAM.OV5642_set_Sharpness(Manual_Sharpnessoff);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Manual Sharpness off END"));break ;
case 0xB4:
myCAM.OV5642_set_Sharpness(Manual_Sharpness1);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Manual Sharpness +1 END"));break ;
case 0xB5:
myCAM.OV5642_set_Sharpness(Manual_Sharpness2);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Manual Sharpness +2 END"));break ;
case 0xB6:
myCAM.OV5642_set_Sharpness(Manual_Sharpness3);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Manual Sharpness +3 END"));break ;
case 0xB7:
myCAM.OV5642_set_Sharpness(Manual_Sharpness4);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Manual Sharpness +4 END"));break ;
case 0xB8:
myCAM.OV5642_set_Sharpness(Manual_Sharpness5);temp = 0xff;
Serial.println(F("ACK CMD Set to Auto Manual Sharpness +5 END"));break ;
case 0xC0:
myCAM.OV5642_set_Mirror_Flip(MIRROR);temp = 0xff;
Serial.println(F("ACK CMD Set to MIRROR END"));break ;
case 0xC1:
myCAM.OV5642_set_Mirror_Flip(FLIP);temp = 0xff;
Serial.println(F("ACK CMD Set to FLIP END"));break ;
case 0xC2:
myCAM.OV5642_set_Mirror_Flip(MIRROR_FLIP);temp = 0xff;
Serial.println(F("ACK CMD Set to MIRROR&FLIP END"));break ;
case 0xC3:
myCAM.OV5642_set_Mirror_Flip(Normal);temp = 0xff;
case 0xD0:
myCAM.OV5642_set_Compress_quality(high_quality);temp = 0xff;
Serial.println(F("ACK CMD Set to high quality END"));break ;
case 0xD1:
myCAM.OV5642_set_Compress_quality(default_quality);temp = 0xff;
Serial.println(F("ACK CMD Set to default quality END"));break ;
case 0xD2:
myCAM.OV5642_set_Compress_quality(low_quality);temp = 0xff;
Serial.println(F("ACK CMD Set to low quality END"));break ;
case 0xE0:
myCAM.OV5642_Test_Pattern(Color_bar);temp = 0xff;
Serial.println(F("ACK CMD Set to Color bar END"));break ;
case 0xE1:
myCAM.OV5642_Test_Pattern(Color_square);temp = 0xff;
Serial.println(F("ACK CMD Set to Color square END"));break ;
case 0xE2:
myCAM.OV5642_Test_Pattern(BW_square);temp = 0xff;
Serial.println(F("ACK CMD Set to BW square END"));break ;
case 0xE3:
myCAM.OV5642_Test_Pattern(DLI);temp = 0xff;
Serial.println(F("ACK CMD Set to DLI END"));break ;
default:
if (mode == 1)
if (start_capture == 1)
myCAM.flush_fifo();
//Start capture
myCAM.start_capture();
start_capture = 0;
if (myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK))
Serial.println(F("ACK CMD CAM Capture Done. END"));delay(50);
read_fifo_burst(myCAM);
//Clear the capture done flag
else if (mode == 2)
while (1)
if (temp == 0x21)
start_capture = 0;
mode = 0;
Serial.println(F("ACK CMD CAM stop video streaming. END"));
switch(temp){
case 0x40:
case 0x41:
case 0x42:
case 0x43:
case 0x44:
case 0x45:
case 0x50:
case 0x51:
case 0x52:
case 0x53:
case 0x54:
case 0x55:
case 0x56:
Serial.println(F("ACK CMD Set to Saturation-2 END"));break;
case 0x57:
case 0x58:
case 0x60:
case 0x61:
case 0x62:
case 0x63:
case 0x64:
case 0x65:
case 0x66:
case 0x67:
case 0x68:
case 0x70:
case 0x71:
case 0x72:
case 0x73:
case 0x74:
case 0x75:
case 0x76:
case 0x77:
case 0x78:
case 0x80:
case 0x81:
case 0x82:
case 0x83:
case 0x84:
case 0x85:
case 0x86:
case 0x87:
case 0x88:
case 0x89:
case 0x8a:
case 0x8b:
case 0x90:
case 0x91:
case 0x92:
case 0x93:
case 0x94:
case 0x95:
case 0x96:
case 0xA0:
Serial.println(F("ACK CMD Set to -1.7EV END"));break ;
case 0xA1:
case 0xA2:
case 0xA3:
case 0xA4:
case 0xA5:
case 0xA6:
case 0xA7:
case 0xA8:
case 0xA9:
case 0xB0:
case 0xB1:
case 0xB2:
case 0xB3:
case 0xB4:
case 0xB5:
case 0xB6:
case 0xB7:
case 0xB8:
case 0xC0:
case 0xC1:
case 0xC2:
case 0xC3:
case 0xD0:
case 0xD1:
case 0xD2:
case 0xE0:
case 0xE1:
case 0xE2:
case 0xE3:
if (start_capture == 2)
myCAM.flush_fifo();
//Start capture
start_capture = 0;
uint32_t length = 0;
length = myCAM.read_fifo_length();
if ((length >= MAX_FIFO_SIZE) | (length == 0))
start_capture = 2;
continue;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
temp = SPI.transfer(0x00);
length --;
while ( length-- )
temp_last = temp;
if (is_header == true)
Serial.write(temp);
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
Serial.println(F("ACK IMG END"));
Serial.write(temp_last);
Serial.write(temp);
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
delayMicroseconds(4);
myCAM.CS_HIGH();
start_capture = 2;
is_header = false;
else if (mode == 3)
if (start_capture == 3)
//Flush the FIFO
myCAM.flush_fifo();
//Start capture
start_capture = 0;
uint8_t temp, temp_last;
if (length >= MAX_FIFO_SIZE )
Serial.println(F("ACK CMD Over size. END"));
return;
if (length == 0 ) //0 kb
Serial.println(F("ACK CMD Size is 0. END"));
return;
myCAM.CS_LOW();
Serial.write(0xFF);
Serial.write(0xAA);
for (temp = 0; temp < BMPIMAGEOFFSET; temp++)
Serial.write(pgm_read_byte(&bmp_header[temp]));
//SPI.transfer(0x00);
char VH, VL;
int i = 0, j = 0;
for (i = 0; i < 240; i++)
for (j = 0; j < 320; j++)
VH = SPI.transfer(0x00);;
VL = SPI.transfer(0x00);;
Serial.write(VL);
delayMicroseconds(12);
Serial.write(VH);
Serial.write(0xBB);
Serial.write(0xCC);
myCAM.CS_HIGH();
uint8_t temp = 0, temp_last = 0;
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //512 kb
return 0;
return 0;
myCAM.CS_LOW();
length --;
while ( length-- )
temp_last = temp;
Serial.write(temp);
is_header = true;
Serial.write(temp);
delayMicroseconds(15);
myCAM.CS_HIGH();
is_header = false;
return 1;
