Utilizing the Arducam Shield Mini 2MP Plus with other components that use the Serial Monitor
Good day to you all,
I am a complete beginner to Arduino, and this is my first project & forum post, so apologies if anything is incorrectly formatted. I am attempting to do an Arduino-based project (an underwater ROV) for a year-long high school creativity assignment, and I have run into an issue that I couldn't find a solution for.
As part of its components, the Arduino-based ROV (the Arduino used is an Arduino Mega 2560 Rev3) will have a camera to be able to view live video footage while operating the ROV from a laptop. The camera module used was the Arducam Shield Mini 2MP Plus. In tandem with this, the other components (20a ESCs & LEDs) will be, in theory, controlled through computer keystrokes utilizing serial. [Main Schmeatic imaged below]
To test out the feasibility of this, I wired up the LED components and the AruCam first to test if they would both be controlled.
While separate, the code for reading keystrokes through the serial monitor to turn on and off the LED lights, as well as the code that I got from the ArduCam library that allows for the livestreaming of video through the ArduCam, works perfectly fine on their own.
However, when I attempted to combine their codes, neither of them worked (consistently) at all. The code complies and uploads, but nothing gets done past a few lines in the void Setup code. The Serial Monitor states that “COM3 is busy” some of the times I’ve tried to type in it. Other times, I am able to type, but nothing occurs, and I get a black diamond with a white question mark as output.
I’ve attempted to get rid of the delay lines in the keystrokes code, but that was to no avail. The aforementioned “COM3 is busy” error leads me to believe that there is some incompatibility between using the AruCam and the Serial Monitor at the same time, but I am unsure.
My main question is, can the Arducam Shield Mini 2MP Plus be utilized with other components that require reading serial-based coding through a single UART port? If so, how can I implement that functionality into the code below? If not, what can I do to circumvent that incompatibility?
Combined code:
// Camera needs
#include <Wire.h>
#define OV2640_MINI_2MP_PLUS
#include <ArduCAM.h>
#include <SPI.h>
#include "memorysaver.h"
//This demo can only work on OV2640_MINI_2MP or OV5642_MINI_5MP or OV5642_MINI_5MP_BIT_ROTATION_FIXED platform.
#if !(defined OV2640_MINI_2MP_PLUS)
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define BMPIMAGEOFFSET 66
const char bmp_header[BMPIMAGEOFFSET] PROGMEM = {
  0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x28, 0x00,
  0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x03, 0x00,
  0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0x1F, 0x00,
  0x00, 0x00
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
bool is_header = false;
int mode = 0;
uint8_t start_capture = 0;
#if defined(OV2640_MINI_2MP_PLUS)
ArduCAM myCAM(OV2640, CS);
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
// Servo list
#include <Servo.h>
Servo myServoFL;
Servo myServoBL;
Servo myServoC;
Servo myServoBR;
Servo myServoFR;
  //Serial Section
    // Led Section
    pinMode(9, OUTPUT);
    pinMode(11, OUTPUT);
    // Servo Esc section
    myServoFL.attach(3);
    myServoBL.attach(4);
    myServoC.attach(5);
    myServoBR.attach(6);
    myServoFR.attach(8);
    Serial.println("ESCs Attached");
    delay(7000);
    myServoFL.writeMicroseconds(1500);
    myServoBL.writeMicroseconds(1500);
    myServoC.writeMicroseconds(1500);
    myServoBR.writeMicroseconds(1500);
    myServoFR.writeMicroseconds(1500);
    Serial.println("ESCs Pinged");
    delay(3000);
  //Cam section
  uint8_t vid, pid;
  uint8_t temp;
#if defined(__SAM3X8E__)
  Wire1.begin();
#else
  Wire.begin();
  Serial.begin(921600);
#endif
  Serial.println(F("ACK CMD ArduCAM Start! END"));
  // set the CS as an output:
  pinMode(CS, OUTPUT);
  digitalWrite(CS, HIGH);
  // initialize SPI:
  SPI.begin();
  //Reset the CPLD
  myCAM.write_reg(0x07, 0x80);
  delay(100);
  myCAM.write_reg(0x07, 0x00);
  delay(100);
  while (1) {
    //Check if the ArduCAM SPI bus is OK
    myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
    temp = myCAM.read_reg(ARDUCHIP_TEST1);
    if (temp != 0x55) {
      Serial.println(F("ACK CMD SPI interface Error!END"));
      continue;
      Serial.println(F("ACK CMD SPI interface OK.END"));
  while (1) {
    //Check if the camera module type is OV2640
    myCAM.wrSensorReg8_8(0xff, 0x01);
    myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
    if ((vid != 0x26) && ((pid != 0x41) || (pid != 0x42))) {
      Serial.println(F("ACK CMD Can't find OV2640 module!"));
      continue;
      Serial.println(F("ACK CMD OV2640 detected.END"));
#endif
  //Change to JPEG capture mode and initialize the OV5642 module
  myCAM.set_format(JPEG);
  myCAM.InitCAM();
  myCAM.OV2640_set_JPEG_size(OV2640_320x240);
#endif
  myCAM.clear_fifo_flag();
  // Cam section
  uint8_t temp = 0xff, temp_last = 0;
  if (Serial.available()) {
    temp = Serial.read();
    switch (temp) {
      case 0:
        myCAM.OV2640_set_JPEG_size(OV2640_160x120);
        Serial.println(F("ACK CMD switch to OV2640_160x120END"));
#elif defined(OV3640_MINI_3MP)
        myCAM.OV3640_set_JPEG_size(OV3640_176x144);
#else
        myCAM.OV5642_set_JPEG_size(OV5642_320x240);
        Serial.println(F("ACK CMD switch to OV5642_320x240END"));
#endif
        temp = 0xff;
      case 1:
        myCAM.OV2640_set_JPEG_size(OV2640_176x144);
        Serial.println(F("ACK CMD switch to OV2640_176x144END"));
        myCAM.OV3640_set_JPEG_size(OV3640_320x240);
        Serial.println(F("ACK CMD switch to OV3640_320x240END"));
#else
        myCAM.OV5642_set_JPEG_size(OV5642_640x480);
        Serial.println(F("ACK CMD switch to OV5642_640x480END"));
#endif
        temp = 0xff;
      case 2:
        Serial.println(F("ACK CMD switch to OV2640_320x240END"));
        myCAM.OV3640_set_JPEG_size(OV3640_352x288);
        Serial.println(F("ACK CMD switch to OV3640_352x288END"));
#else
        myCAM.OV5642_set_JPEG_size(OV5642_1024x768);
        Serial.println(F("ACK CMD switch to OV5642_1024x768END"));
#endif
        temp = 0xff;
      case 3:
        temp = 0xff;
        myCAM.OV2640_set_JPEG_size(OV2640_352x288);
        Serial.println(F("ACK CMD switch to OV2640_352x288END"));
        myCAM.OV3640_set_JPEG_size(OV3640_640x480);
        Serial.println(F("ACK CMD switch to OV3640_640x480END"));
#else
        myCAM.OV5642_set_JPEG_size(OV5642_1280x960);
        Serial.println(F("ACK CMD switch to OV5642_1280x960END"));
#endif
      case 4:
        temp = 0xff;
#if defined(OV2640_MINI_2MP)
        myCAM.OV2640_set_JPEG_size(OV2640_640x480);
        Serial.println(F("ACK CMD switch to OV2640_640x480END"));
        myCAM.OV3640_set_JPEG_size(OV3640_800x600);
        Serial.println(F("ACK CMD switch to OV3640_800x600END"));
#else
        myCAM.OV5642_set_JPEG_size(OV5642_1600x1200);
        Serial.println(F("ACK CMD switch to OV5642_1600x1200END"));
#endif
      case 5:
        temp = 0xff;
        myCAM.OV2640_set_JPEG_size(OV2640_800x600);
        Serial.println(F("ACK CMD switch to OV2640_800x600END"));
        myCAM.OV3640_set_JPEG_size(OV3640_1024x768);
        Serial.println(F("ACK CMD switch to OV3640_1024x768END"));
#else
        myCAM.OV5642_set_JPEG_size(OV5642_2048x1536);
        Serial.println(F("ACK CMD switch to OV5642_2048x1536END"));
#endif
      case 6:
        temp = 0xff;
        myCAM.OV2640_set_JPEG_size(OV2640_1024x768);
        Serial.println(F("ACK CMD switch to OV2640_1024x768END"));
        myCAM.OV3640_set_JPEG_size(OV3640_1280x960);
        Serial.println(F("ACK CMD switch to OV3640_1280x960END"));
#else
        myCAM.OV5642_set_JPEG_size(OV5642_2592x1944);
        Serial.println(F("ACK CMD switch to OV5642_2592x1944END"));
#endif
      case 7:
        temp = 0xff;
        myCAM.OV2640_set_JPEG_size(OV2640_1280x1024);
        Serial.println(F("ACK CMD switch to OV2640_1280x1024END"));
#else
        myCAM.OV3640_set_JPEG_size(OV3640_1600x1200);
        Serial.println(F("ACK CMD switch to OV3640_1600x1200END"));
#endif
      case 8:
        temp = 0xff;
        myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);
        Serial.println(F("ACK CMD switch to OV2640_1600x1200END"));
#else
        myCAM.OV3640_set_JPEG_size(OV3640_2048x1536);
        Serial.println(F("ACK CMD switch to OV3640_2048x1536END"));
#endif
      case 0x10:
        mode = 1;
        temp = 0xff;
        start_capture = 1;
        Serial.println(F("ACK CMD CAM start single shoot.END"));
      case 0x11:
        temp = 0xff;
        Serial.println(F("ACK CMD Change OK.END"));
        myCAM.InitCAM();
      case 0x20:
        mode = 2;
        temp = 0xff;
        start_capture = 2;
        Serial.println(F("ACK CMD CAM start video streaming.END"));
      case 0x30:
        mode = 3;
        temp = 0xff;
        start_capture = 3;
      case 0x31:
        temp = 0xff;
        myCAM.set_format(BMP);
        myCAM.InitCAM();
      default:
  if (mode == 1) {
    if (start_capture == 1) {
      myCAM.flush_fifo();
      //Start capture
      myCAM.start_capture();
      start_capture = 0;
    if (myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK)) {
      Serial.println(F("ACK CMD CAM Capture Done.END"));
      delay(50);
      read_fifo_burst(myCAM);
      //Clear the capture done flag
  } else if (mode == 2) {
    while (1) {
      if (temp == 0x21) {
        start_capture = 0;
        mode = 0;
        Serial.println(F("ACK CMD CAM stop video streaming.END"));
      if (start_capture == 2) {
        myCAM.flush_fifo();
        //Start capture
        start_capture = 0;
        uint32_t length = 0;
        length = myCAM.read_fifo_length();
        if ((length >= MAX_FIFO_SIZE) | (length == 0)) {
          start_capture = 2;
          continue;
        myCAM.CS_LOW();
        myCAM.set_fifo_burst();  //Set fifo burst mode
        temp = SPI.transfer(0x00);
        length--;
        while (length--) {
          temp_last = temp;
          if (is_header == true) {
            Serial.write(temp);
          } else if ((temp == 0xD8) & (temp_last == 0xFF)) {
            is_header = true;
            Serial.println(F("ACK CMD IMG END"));
            Serial.write(temp_last);
            Serial.write(temp);
          if ((temp == 0xD9) && (temp_last == 0xFF))  //If find the end ,break while,
          delayMicroseconds(15);
        myCAM.CS_HIGH();
        start_capture = 2;
        is_header = false;
  else if (mode == 3) {
    if (start_capture == 3) {
      //Flush the FIFO
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
      delay(50);
      uint8_t temp, temp_last;
      if (length >= MAX_FIFO_SIZE) {
        Serial.println(F("ACK CMD Over size.END"));
        return;
      if (length == 0)  //0 kb
        Serial.println(F("ACK CMD Size is 0.END"));
        return;
      myCAM.CS_LOW();
      Serial.write(0xFF);
      Serial.write(0xAA);
      for (temp = 0; temp < BMPIMAGEOFFSET; temp++) {
        Serial.write(pgm_read_byte(&bmp_header[temp]));
      char VH, VL;
      int i = 0, j = 0;
      for (i = 0; i < 240; i++) {
        for (j = 0; j < 320; j++) {
          VH = SPI.transfer(0x00);
          VL = SPI.transfer(0x00);
          Serial.write(VL);
          delayMicroseconds(12);
          Serial.write(VH);
      Serial.write(0xBB);
      Serial.write(0xCC);
      myCAM.CS_HIGH();
uint8_t read_fifo_burst(ArduCAM myCAM) {
  uint8_t temp = 0, temp_last = 0;
  Serial.println(length, DEC);
  if (length >= MAX_FIFO_SIZE)  //512 kb
    return 0;
    return 0;
  myCAM.CS_LOW();
  length--;
  while (length--) {
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
  //Led & ESCs section
      char key = Serial.read();  // Read the incoming character
      switch (key) {
        case 'o':
          digitalWrite(9, HIGH);
          digitalWrite(11, HIGH);
          Serial.println("LED ON");
        case 'p':
          digitalWrite(9, LOW);
          digitalWrite(11, LOW);
          Serial.println("LED OFF");
        case 'e':
          myServoFL.writeMicroseconds(1800);
          myServoBL.writeMicroseconds(1800);
          myServoBR.writeMicroseconds(1800);
          myServoFR.writeMicroseconds(1800);
          Serial.println("Up");
        case 'd':
          Serial.println("Neutral");
        case 'c':
          myServoFL.writeMicroseconds(1200);
          myServoBL.writeMicroseconds(1200);
          myServoBR.writeMicroseconds(1200);
          myServoFR.writeMicroseconds(1200);
          Serial.println("Down");
        case 'q':
          myServoFL.writeMicroseconds(1600);
          myServoBL.writeMicroseconds(1600);
          Serial.println("Left");
        case 'a':
        case 'z':
          myServoBR.writeMicroseconds(1600);
          myServoFR.writeMicroseconds(1600);
          Serial.println("Right");
        case 'w':
          myServoC.writeMicroseconds(1800);
          Serial.println("Forward");
        case 's':
          Serial.println("Stop");
        case 'x':
          myServoC.writeMicroseconds(1200);
          Serial.println("Back");
        case 'v':
          Serial.println("T.Forward");
        case 'b':
        case 'n':
          Serial.println("T.Back");
        case 'm':
          Serial.println("R.Left");
        case 'k':
        case 'l':
          Serial.println("R.Right");
There are some other points of error that I can think of, but I would like the opinion of someone more experienced with Arduino. Please note that this is my first time dealing with electronics and coding, so there may be points of error there if that aids. Any advice and critiques related to the question or unrelated would be much appreciated and are welcome, please and thank you.
Look at the tutorials on the forum re doing several things at once and state machines. Those delay statements are your enemy.
That code was written by someone who knows a lot more than a beginner. Was it AI or copied from somewhere?
The Camera-related code was copied from the AruCam Library, the keystrokes-related (LEDs and myServo) code at the end was written by me
Thank you, I'll check some out if I can find something that helps. Is there any specific tutorial I should look out for?
Check a few (3+) re doing multiple things also state machines.
BTW, hand draw a real wiring diagram.
