Arduino 101 + Win10 = STILL AN ISSUE
Hi guys. I'm not too happy today. It's been a while since I bought my Arduino101. Guess what? I tried plugging it in today, and it STILL doesn't work. I have to enable/disable it a ton in Device Manager. Most of the time it doesn't work. It usually says this in the device properties status area:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
I tried updating, reinstalling, etc. the driver. No luck. Reset/Master reset give me some beeping indicitive of device connecting/disconnecting. I know this is a long standing issue for this, but I've returned and replaced the Arduino 3 times now. No luck. None of the other computers I have access to work with it, not Win7 or Win8.1. Why didn't Intel fix this yet? I believe they said they would. Furthermore, why are these STILL on sale?!
If you have replaced the unit 3 times it should at least tell you "ITS NOT THE UNIT".
Code 10 is generic but usually indicates a driver issue.
Reasons for drivers not working can be numerous.
  1. User does not have the correct permissions and or priveledges to install a driver.
  2. Antivirus or similar software can prevent system changes.
  3. Firewall issues where driver and or associates software is not being allowed to update properly.
  4. Virus or other malware present in system.
  5. Trying to install a 64 bit driver on a 32 bit system (and occasionally the other way around).
  6. Previous drivers were not removed properly or cleaned up causing older or wrong drivers to assert themselves.
  7. Same as (6) but more specifically the main software to use the device in this case the IDE.
  8. A faulty KB update was installed on a windows OS. (couple of win 10 KB's cause issues with USB devices)
Those are the ones that quickly come to mind and I am sure others could add to the list of reasons.
