Thank you Budvar10,
If I use the Microsoft driver everything looks okay except that uploading the sketch fails "avrdude:st500_getsync()..."
From this I conclude that the PC should be okay and the problem is between Windows and the Arduino driver. If that is the case I cannot do much, but why don't I see similar problems on these pages ?...
(For more background see Feb 02 " My PC does not find the Arduino Uno)
Incorrect port or driver. I don't know much about Win8, but I'm supposing the device should be visible in device manager with installed driver or not, similarly as in other Windows.
There is only one COM port in the HP 250 G3 it cannot be the wrong port but could that be the problem, ie. that there is only one COM !?
The link to a similar problem ends up in a blank page ??
With the Arduino driver installed (advance over-ride) the Device Manager shows
Ports (COM & LPT)
! Arduino Uno (COM1) (with the small yellow traffic warning sign)
And then if I look under Properties it shows
" This device cannot start (Code 10) "
In the Arduino program/IDE under Tools I have
Tools
Board -> Arduino Uno
Ports <- Ports cannot be opened, unavailable !
Then if I go back to Device Manager and Roll back the previous driver. Ports now shows
Ports (COM & LPT)
Communications Port (COM1) (no warnings)
And in the Arduino program/IDE under Tools
Tools
Ports -> v COM1 <- Arduino IDE is communicating with the Microsoft driver !
So my conclusion is that the problem is between Win 8.1 and the Arduino driver.
It is not very likely that the OS is corrupted, virus infection or confused by old age & tear and wear, because my PC is new and it is not normally connected to the internet.
I think the problem is in Windows 8.1
Does anyone have a working Win 8.1 + Arduino Uno R3 environment ?
PC may not be infected by virus or malware even though to connect once into internet is enough. I think the reason can be incorrect driver installation, corrupted registry, etc. One of the solutions is to uninstall the driver and reinstall it.
Makew ensure your port being detected in device manager.
I have attached the driver here, download the driver, Through device manager manually install the driver using the driver location.
once driver install, make ensure port being detect with board name. Please share us screen shot of device manager after installing driver pack i shared.
if port detected in device manager & arduino IDE, even if getting error share us the screenshot of error msg you get.
Thanks Budvar10 and AMPS-N.
I'm having a problem sending you the screen shots " Error ... entity too large " but let's try again.
Nope obviously it is larger than 1M.
Do you have a normal mailbox or any suggestions.
Semiduplex:
How you taking screen shot it will not exceed 1mb .
open screeen -> choose printscreen option-> open paint-> ctrl+V to screenshot of printed screen. Save as jpeg instead of PNG .so your file will automatically reduce. Then ZIp all image together
AMPS-N, that is the problem. I could not make a normal screen shot like you described but have a photo in my iPad and I am not nerd enough to make a zip in my iPad.
I shall have another go at the screen shot before I give up.
I completely agree with Sploddy's final Words in his post from May 23 (Drivers for Windows 8.1 64 bit)
" If the latest drivers have a genuine MS signed and approved certificate embodied, then why is Windows 8.1 rejecting them ? Are they contained in the latest IDE release ? If not why not and where are they ?"
For Windows 8 users it is a cold comfort that arduino drivers work fine with Win 7 and Win 10 ( Windows 10 is not available for normal users).
Basically - rather than using the "official Arduino LLC driver" - you use one from another manufacturer (in this case, for a modem!) - that used the same drivers as the "official" one. With a bit of configuration and such, in theory (if this guy's video is legit) - it just "works".
Seems like a hack to me - but if it works, who cares, right?
gconlon:
After months of searching and trying Registry editing, Virtual Machines and other potential solution, what eventually worked for me was to install and old Vista version of the driver driver for Prolific USB to serial Driver.
