Arduino 2.0.0 not working
I thought the new release Arduino 2.0.0 should do the job....
I was wrong.
Even with the simple basic example "Blink" from the menu you get an error message when compiling for ESP32 Feather......
What shall I do to set up the system to develop sw for an ESP32 Feather?
Leif
error code:
Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32/Arduino.h:184:12: error: 'std::round' has not been declared
using std::round;
exit status 1
Compilation error: exit status 1
Your topic was MOVED to its current forum category which is more appropriate than the original
Does the code compile using IDE version 1?
Out of interest, what is the value of LED_BUILTIN for the board ?
Hi Bob, I took the sketch "Blink" from the "Examples" in the Arduino IDE 2.0.0 menu.
This was after I failed with all my own sketches.
I try to simplify in order to get to the problem....
Leif
OK, but does the same sketch compile with IDE version 1 ?
Please post the full error message copied from teh IDE using the "Copy error message" button and please use code tags when you post it
Exactly which board have you got set as the target in the IDE ?
Hi Bob,
This is what I get after compilation of ā€Blinkā€-sketch in Arduino 1.8.19:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\leif0\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\leif0\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\leif0\Documents\Arduino\libraries -fqbn=esp32:esp32:featheresp32:LoopCore=1,EventsCore=1,PartitionScheme=default,CPUFreq=240,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path C:\Users\leif0\AppData\Local\Temp\arduino_build_921137 -warnings=none -build-cache C:\Users\leif0\AppData\Local\Temp\arduino_cache_682414 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\leif0\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\leif0\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\leif0\Documents\Arduino\libraries -fqbn=esp32:esp32:featheresp32:LoopCore=1,EventsCore=1,PartitionScheme=default,CPUFreq=240,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path C:\Users\leif0\AppData\Local\Temp\arduino_build_921137 -warnings=none -build-cache C:\Users\leif0\AppData\Local\Temp\arduino_cache_682414 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'featheresp32' from platform in folder: C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
Using core 'esp32' from platform in folder: C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
cmd /c if exist "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\partitions.csv" COPY /y "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\partitions.csv" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\partitions.csv"
cmd /c if not exist "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\partitions.csv" if exist "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32\partitions.csv" COPY "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32\partitions.csv" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\partitions.csv"
cmd /c if not exist "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\partitions.csv" COPY "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\tools\partitions\default.csv" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\bootloader.bin" ( COPY /y "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\bootloader.bin" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\Blink.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32\bootloader.bin" ( COPY "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32\bootloader.bin" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\Blink.ino.bootloader.bin" ) ELSE ( "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\Blink.ino.bootloader.bin" "C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\tools\sdk\esp32\bin\bootloader_dio_80m.elf" ) )
esptool.py v4.2.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\build_opt.h" COPY /y "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\build_opt.h" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\build_opt.h"
cmd /c if not exist "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\build_opt.h" type nul > "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\build_opt.h"
Detecting libraries used...
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.2"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/console" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_FEATHER_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="FEATHER_ESP32"" "-DARDUINO_VARIANT="feather_esp32[" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/build_opt.h](mailto:%22%20-DARDUINO_PARTITION_default%20-DESP32%20-DCORE_DEBUG_LEVEL=0%20-DARDUINO_RUNNING_CORE=1%20-DARDUINO_EVENT_RUNNING_CORE=1%20-DARDUINO_USB_CDC_ON_BOOT=0%20%22@C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/build_opt.h) "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\sketch\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.2"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/console" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_FEATHER_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="FEATHER_ESP32"" "-DARDUINO_VARIANT="feather_esp32[" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/build_opt.h](mailto:%22%20-DARDUINO_PARTITION_default%20-DESP32%20-DCORE_DEBUG_LEVEL=0%20-DARDUINO_RUNNING_CORE=1%20-DARDUINO_EVENT_RUNNING_CORE=1%20-DARDUINO_USB_CDC_ON_BOOT=0%20%22@C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/build_opt.h) "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\sketch\Blink.ino.cpp" -o "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\preproc\ctags_target_for_gcc_minus_e.cpp"
Kompilerar skiss...
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.2"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/console" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_FEATHER_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="FEATHER_ESP32"" "-DARDUINO_VARIANT="feather_esp32[" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/build_opt.h](mailto:%22%20-DARDUINO_PARTITION_default%20-DESP32%20-DCORE_DEBUG_LEVEL=0%20-DARDUINO_RUNNING_CORE=1%20-DARDUINO_EVENT_RUNNING_CORE=1%20-DARDUINO_USB_CDC_ON_BOOT=0%20%22@C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/build_opt.h) "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32" "-IC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\variants\feather_esp32" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\sketch\Blink.ino.cpp" -o "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\leif0\AppData\Local\Temp\arduino_cache_682414\core\core_6dbd430f9da78871992d03a2ca0daa2a.a
Linking everything together...
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/Blink.ino.map" "-LC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/lib" "-LC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/ld" "-LC:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/dio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137\sketch\Blink.ino.cpp.o" "C:\Users\leif0\AppData\Local\Temp\arduino_cache_682414\core\core_6dbd430f9da78871992d03a2ca0daa2a.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/Blink.ino.elf"
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/Blink.ino.bin" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/Blink.ino.elf"
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/gen_esp32part.exe" -q "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/partitions.csv" "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/Blink.ino.partitions.bin"
"C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size" -A "C:\Users\leif0\AppData\Local\Temp\arduino_build_921137/Blink.ino.elf"
Sketch uses 219077 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16088 bytes (4%) of dynamic memory, leaving 311592 bytes for local variables. Maximum is 327680 bytes.
Did you miss the bit about using code tags when posting the errors ? Please edit your post and add them to make reading and copying the errors easier
Hi, I have been an Arduino IDE-user since 4-5 years but never used the features you refer to so I'm a bit ignorant...
Sorry, I will give it a try.
Leif
Skickat frƄn min Galaxy
-------- Originalmeddelande --------
Code tags are not an IDE feature, rather they are a forum feature
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
The advice relates to posting errors as well as code
Bob, what if you did a try to compile the std sketch ā€Blinkā€ in your Arduino 2.0.0..
That could show if the problem is related to my computer or to your IDE-sw…
Leif
Here is the output I get when compiling the Blink example with the target board set to Adafruit ESP32 Feather
Using board 'featheresp32' from platform in folder: C:\Users\Bob2\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
Using core 'esp32' from platform in folder: C:\Users\Bob2\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
cmd /c if exist "C:\\Users\\Bob2\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202297-1544-13w2ucm.wn4f\\Blink\\partitions.csv" COPY /y "C:\\Users\\Bob2\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202297-1544-13w2ucm.wn4f\\Blink\\partitions.csv" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\partitions.csv"
cmd /c if not exist "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\partitions.csv" if exist "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32\\partitions.csv" COPY "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32\\partitions.csv" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\partitions.csv"
cmd /c if not exist "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\partitions.csv" COPY "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\tools\\partitions\\default.csv" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Bob2\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202297-1544-13w2ucm.wn4f\\Blink\\bootloader.bin" ( COPY /y "C:\\Users\\Bob2\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202297-1544-13w2ucm.wn4f\\Blink\\bootloader.bin" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\Blink.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32\\bootloader.bin" ( COPY "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32\\bootloader.bin" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\Blink.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\Blink.ino.bootloader.bin" "C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\tools\\sdk\\esp32\\bin\\bootloader_dio_80m.elf" ) )
esptool.py v4.2.1
Merged 1 ELF section
cmd /c if exist "C:\\Users\\Bob2\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202297-1544-13w2ucm.wn4f\\Blink\\build_opt.h" COPY /y "C:\\Users\\Bob2\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202297-1544-13w2ucm.wn4f\\Blink\\build_opt.h" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\build_opt.h"
cmd /c if not exist "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\build_opt.h" type nul > "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\build_opt.h"
Detecting libraries used...
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_FEATHER_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"FEATHER_ESP32\"" "-DARDUINO_VARIANT=\"feather_esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/build_opt.h" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_FEATHER_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"FEATHER_ESP32\"" "-DARDUINO_VARIANT=\"feather_esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/build_opt.h" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Wall -Werror=all -Wextra -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_FEATHER_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"FEATHER_ESP32\"" "-DARDUINO_VARIANT=\"feather_esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/build_opt.h" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\feather_esp32" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Bob2\AppData\Local\Temp\arduino-core-cache\core_87c4536561037f52cf8d62a9a2302f2a.a
Linking everything together...
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/Blink.ino.map" "-LC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/lib" "-LC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/ld" "-LC:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591\\sketch\\Blink.ino.cpp.o" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-core-cache\\core_87c4536561037f52cf8d62a9a2302f2a.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/Blink.ino.elf"
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/Blink.ino.bin" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/Blink.ino.elf"
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/gen_esp32part.exe" -q "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/partitions.csv" "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/Blink.ino.partitions.bin"
"C:\\Users\\Bob2\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size" -A "C:\\Users\\Bob2\\AppData\\Local\\Temp\\arduino-sketch-0679591053C81B4D99F94AD90C488591/Blink.ino.elf"
Sketch uses 219077 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16088 bytes (4%) of dynamic memory, leaving 311592 bytes for local variables. Maximum is 327680 bytes.
Note how I used code tags when posting the output
Hi Bob, in your print out there is no final error message like mine:
In file included from C:\Users\leif0\AppData\Local\Temp\arduino-sketch-7134811373AAF2EF8537517DA7D3510D\sketch\Blink.ino.cpp:1:0:
C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32/Arduino.h:184:12: error: 'std::round' has not been declared
using std::round;
cc1plus.exe: warning: unrecognized command line option '-Wno-frame-address'
exit status 1
Compilation error: exit status 1
For me this can be a proof of my laptop/installation is faulty. I got into problems two weeks ago when my application sw did compile but didn“t execute anymore.
This was of course surprising as I have had it running since about a year…..
Hw or sw? You need to find some clues to get your hands on the root cause…
Thanks for your support,
Leif
That's right. The code compiled OK for me
Which version of release IDE release 2 are you using ? Is it really a year old ?
Why do I need to do that ?
Perhaps there is a ESP32 Feather library or board driver missing?
Hi JohnRob,
I just tested again first having added all libraries via the menu but I still get an error message:
using std::round;
Using library ESP32 at version 2.0.0 in folder: C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\ESP32
exit status 1
What means ā€roundā€, what means ā€Wno-frame-Addressā€?
Leif
As I previously asked
Hi again, I also tried with my own sketch that runs nicely uploaded via IDE 1.18.19 and then I get the same error message from IDE 2.0.0:
In file included from C:\Users\leif0\AppData\Local\Temp\arduino-sketch-E0F0E07204526F4EA8A7AFB19A698C5D\sketch\sketch_oct-6_ICM40627_sensor_rev_6_4.ino.cpp:1:0:
using std::round;
Using library Wire at version 2.0.0 in folder: C:\Users\leif0\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\Wire
exit status 1
Leif
Hi @leifblundberg. I'm going to ask you to post some additional information that might help us to identify the problem.
:exclamation: NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
  1. Select File > Examples > 01.Basics > Blink from the Arduino IDE menus.
  2. Select File > Preferences from the Arduino IDE menus.
  3. Check the box next to "Show verbose output during: ☐ compilation".
  4. Click the OK button.
  5. Select Sketch > Verify/Compile from the Arduino IDE menus.
  6. Wait for the compilation to fail.
  7. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the COPY ERROR MESSAGES button on that notification.
  8. Open a forum reply here by clicking the Reply button.
  9. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  10. Press Ctrl+V.
    This will paste the compilation output into the code block.
  11. Move the cursor outside of the code tags before you add any additional text to your reply.
  12. Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the Reply button.
  5. Click the "Upload" icon (image) on the post composer toolbar:
  6. Select the .txt file you saved.
  7. Click the Open button.
  8. Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Hi again, I did as you proposed an have enclosed a textfile with the compilator output including the error message.
Leif
(Attachment Error message Arduino.docx is missing)
Hi @leifblundberg the attachment was not successful. You must come here to the forum website to make the attachment:
Don't use email.
