Hey there,
currently I a working on a project to read distances using a ultrasonic sensor. So far it worked well and I nearly finished it.
However suddently I can't upload any sketches anymore and my pro mini isn't running anymore. It got power but for example the connected display doesn't show anything where it previously jjust worked fine.
When I try to upload my sketch I just got the infamous "avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x64"
See the full log here:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x64
So I thought maybe some fuses are not correct and I tried to burn the bootloader using a arduino nano. I uploaded the Arduino as ISP sketch to the nano, wired everything up and hooked a 25V 10µF capacitor from rst to gnd on the nano.
However when I try to burn the bootloader when selecting the pro mini as processor, I still get the error "avrdude: Device signature = 0x000000"
Here the full log:
Using Port : COM8
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 usavrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03Fehler beim Brennen des Bootloaders.
Reading | ################################################## | 100% 0.02savrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.avrdude done. Thank you.
Some strange behaviour: I use a CH340 USB chip to connect the pro mini to my pc to programm it. There is a red light for power and a blue light. Usually when the pro mini worked, the blue light was just flickering i think during uploading, now the blue light is always on. But I don't know what that means.
Also I could restart my pro mini when pushing it's button. Also a little LED flashed on the pro mini when I pushed this button. This LED is not flashing when I push the button on the pro mini.
However this LED flashes if i push the reset button on the nano. I also tried to upload a sketch to the pro mini with resetting it when pushing the button on the nano but this also didn't work.
Do you have any other idea what I could do to get the pro mini running again?
