Hello forum,
I have been wrecking my brain a bit trying to figure this issue out. I have setup and LCD screen to display what port A0 is reading, at any given time Port A0 value returns 14. I have installed a loadcell using the same steps as http://cerulean.dk/words/?page_id=42 , It works but the value stills shows 14 and rises after that. So my question is, what is causing my port A0 to return 14 value instead of 0. Also if i change the port to A1 or A2 the value returns as 15 and 16.
thanks in advance!
skater90255:
Hello forum,
thanks in advance!
Most likely it's just the 'preload' value on the strain gage or the 'offset' voltage of the op-amp. You could either verify that by measuring the voltage being presented on pin A0 with a decent digital multimeter, or disconnect the wire and ground pin A0 and see if your sketch then 'sees' a zero count.
Lefty
Thanks for the reply!
I have unplugged pin A0 completely and i still get the value of 14, an interesting thing just happened. Now it is fluctuating between 13-15 without being plugged in, could this just be a faulty board?
skater90255:
No, just reading a analog pin with nothing wired to it gives random values as you are reading a 'floating input pin condition', you must present a valid voltage to the pin before trusting the number returned, so ground it and see if you get 0 counts and then wire it to the 5V pin and see if you then get 1023 counts.
Lefty
Hi Everyone,
I just figured out the issue i was having, turned out to be a coding issue. In the code I put lcd.print(A0); What i should of written was lcd.print(analogRead(A0); I know its late but this might help someone else having this issue.
