Hello everyone.I have a Raspberry Pi 3 (I use it as a master) , an Arduno Mega (slave) and I use i2c communication to transfer data to my Arduino.
Also,I have a led.So,using Python3 on my raspberry ,everytime I press '1' (without Enter) I increase the brightness of led (that is connected to Arduino).When I press '0' , I decrease the brightness.That works fine.
So ,what I want to do is to tranfer multiple data at the same time,for instance I want to open a led(as I did) and I also want to send another data to do other stuff on Arduino board.
So,how can I do it? I hope I'm clear.
Arduino Code:
#include <Wire.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd (22,23,24,25,26,27);
const int ledPin = 7;
// Join I2C bus as slave with address 8
//Serial.begin(9600);
Wire.begin(0x8);
// Call receiveEvent when data received
Wire.onReceive(receiveEvent);
// Setup pin 13 as output and turn LED off
pinMode(ledPin, OUTPUT);
analogWrite(ledPin, 0);
// Function that executes whenever data is received from master
void receiveEvent(int howMany)
if (Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
analogWrite(ledPin, c);
Raspberry Pi Code:
from smbus import SMBus
import curses
addr = 0x8 # bus address
bus = SMBus(1) # indicates /dev/ic2-1
numb = 1
give_move = curses.initscr()
curses.noecho()
give_move.nodelay(1) # set getch() non-blocking
#print ("Enter 1 for ON or 0 for OFF")
num = 0
while 1:
push_key = give_move.getch()#input(">>>> ")
if push_key == ord("1"):
if(num <= 250):
num += 5
#bus.write_byte(addr, 0x1) # switch it on
bus.write_byte(addr, num)
elif push_key == ord("0"):
if(num >= 5):
num -= 5
#bus.write_byte(addr, 0x0) # switch it on
Thanks a lot.
