I use a wifi led strip controller (image attached), which connects great with my google home devices.
I want to add a pir motion sensor with an arduino which I know how to use, but just confused how I can hook this up being there are 3 grounds in the led controller, R B G.
The led controller would connect directly to the power adapter so that it keeps it's wifi connection, then I want the motion sensor to tell my arduino to allow the +voltage through to the led strip.
I'm thinking this can be done somehow with a relay, it's just the fact the led controller uses 3 ground wires, which are the RGB wires.
Thank you so much for any help
edit: I'm thinking I can just run the +voltage pin through the relay and keep the 3 negatives RGB wires out of the relay.
