Hi, after 4 days of trying to upload a simple Blink example to my Arduino Bt ATMEGA328 board I just couldn't succed.
-> I've made my new COM serial port named rfcomm0, and also a link named ttyUSB0 so that the Arduino IDE will think it's a simple USB port (not a bluetooth connection)
-> Change the rate from 9600 to 115200
The top problem I couldn't resolve was the avrdude: stk500_recv(): programmer is not responding .
If i try to burn a new bootloader but I get avrdude: usbdev_open(): did not find any USB device "usb".
I've paired the Arduino Bt with no problem.
I just want for starters to just upload a simple code.
Is there another way to upload code to the Arduino Bt? I don't know like with an another arduino and conecting some pins between them or what ever.
Is it possible that with a iMac might work? (I have a friend that has one but i don't want to depend on him evry time I need to change the code).
Please help, I need it for my last year project that is domotic control via bluetooth (originaly was with a the Arduino Wifi Shield but I couldn't find enough documentacion).
Hola, después de 4 días de intentar subir un ejemplo sencillo de Blink mi Arduino Bt ATMEGA328 junta no podía succed.
-> He hecho mi nuevo puerto COM en serie llamado rfcomm0, y también un enlace llamado ttyUSB0 para que el IDE Arduino pensará que es un simple puerto USB (no una conexión bluetooth)
-> Cambiar el tipo 9600-115200
El principal problema que no podía resolver era avrdude: stk500_recv(): programmer is not responding.
Si trato de grabar un nuevo gestor de arranque, pero me sale avrdude: usbdev_open(): did not find any USB device "usb".
He vinculado el Bt Arduino sin ningún problema.
Sólo quiero para empezar a subir sólo un código simple.
¿Hay alguna otra forma de subir código al Bt Arduino? No sé como con un arduino y otro conecting algunos pines entre ellos o lo que sea.
¿Es posible que con un iMac podría funcionar? (Tengo un amigo que tiene uno, pero no quiero depender de él Evry tiempo tengo que cambiar el código).
Por favor ayuda, lo necesito para mi proyecto de final de grado que es el control domótico a través de bluetooth (originalmente estaba con un Arduino Wifi Shield pero no pude encontrar suficiente documentacion).
