Hi all,
I'm currently designing and building a complete home automation system, and in the process of designing I figured out I'd need some parts custom built, so after a fair bit of poking around it worked out that it would be cheaper (and a lot more fun) to build my own Arduino powered CNC Router.
After looking around for quite a while for a design I liked, it became apparent that most were either too expensive, or (and no disrespect meant by this) not very Aesthetically pleasing to my eye. So, I decided to design my own from the ground up.
I'm taking it slow and designing in sections to make sure I eliminate any 'compounding errors'.
The following series of images (Click for larger versions) show the build up of the base and Y-Axis.
Steel Guide rods, Threaded Rods and Bearings.
Armature (x,z axes mount) mounts added to Threaded rods and Linear Bearings
Motors (No mounting system added as yet, but know what I'll be doing :))
Base measurements (may need to be amended to accomodate material sizes I'm planning on using.
So there is stage one.
Materials are Pine for the frame, mdf for 'extra' bits and steel rods.
I'm fairly confident in the design, but pointers/tips would be extremely appreciated
Thanks
TheMightySpud
