I designed a coffee roaster and was using artisan to control. Then I decided to simplify and just use time and temperature controls. There is a fan I am using to push hot air around the beans, I need to be able to adjust the speed in arduino code. I made the physical product and wiring but had someone make the code, I haven't been able to get in touch with him so I am trying to figure it out myself (sort of). I figured the command would be in the user. h or the main code but I cant find just the fan speed. It is supposed to be controlled by IO3 (fan) and digital pin 3 on Uno. In the main code I have tried changing the IO3= to different numbers and the fan still runs at 100 percent. Below is the main code- any help would be appreciated.
Notes LMMS:
1) The libraries with Suffix LMMS in the Arduino folder libraries were modified for LMMS
2) If it is printed on the console and the encoders are used, they work badly
// aArtisanQ_PID.ino
// Written to support the Artisan roasting scope //http://code.google.com/p/artisan/
// Heater is controlled from OT1 using a zero cross SSR (integral pulse control)
// AC fan is controlled from OT2 using a random fire SSR (phase angle control)
// zero cross detector (true on logic low) is connected to I/O3
// *** BSD License ***
// Copyright (c) 2011, MLG Properties, LLC
// All rights reserved.
// Contributor: Jim Gallt
// Redistribution and use in source and binary forms, with or without modification, are
// permitted provided that the following conditions are met:
// Redistributions of source code must retain the above copyright notice, this list of
// conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright notice, this list
// of conditions and the following disclaimer in the documentation and/or other materials
// provided with the distribution.
// Neither the name of the copyright holder(s) nor the names of its contributors may be
// used to endorse or promote products derived from this software without specific prior
// written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS
// OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
// MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL
// THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
// HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
// OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
// SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Revision history:
// 20110408 Created.
// 20110409 Reversed the BT and ET values in the output stream.
// Shortened the banner display time to avoid timing issues with Artisan
// Echo all commands to the LCD
// 20110413 Added support for Artisan 0.4.1
// 20110414 Reduced filtering levels on BT, ET
// Improved robustness of checkSerial() for stops/starts by Artisan
// Revised command format to include newline character for Artisan 0.4.x
// 20110528 New command language added (major revision)
// Use READ command to poll the device for up to 4 temperature channels
// Change temperature scale using UNITS command
// Map physical channels on ADC to logical channels using the CHAN command
// Select SSR output duty cycle with OT1 and OT2 commands
// Select PWM logic level output on I/O3 using IO3 command
// Directly control digital pins using DPIN command (WARNING -- this might not be smart)
// Directly control analog pins using APIN command (WARNING -- this might not be smart)
// 20110601 Major rewrite to use cmndproc.h library
// RF2000 and RC2000 set channel mapping to 1200
// 20110602 Added ACKS_ON to control verbose output
// ----------- Version 1.10
// 20111011 Added support for type J and type T thermocouples
// Better error checking on EEPROM reads
// ----------- aArtsianQ version 0.xx
// 20111031 Created.
// ----------- aArtisanQ beta1
// 20111101 Beta 1 release
// ----------- aArtisanQ_PID (Brad Collins)
// 20120915 Created.
// Added PID Library
// Added code for analogue inputs
// 20120916 Added PID command allowing PID control to be activated and deactivated from Artisan
// Added roast clock. Can be reset with PID;TIME command
// Removed LCD ambient temp display and added roast clock display
// 20120918 Added code to read profile from EEPROM and interpolate to calculate setpoint. Time/Temp profiles
// Added code to end PID control when end of profile is reached
// Added additional PID command allowing roast profile to be selected
// Added additional PID command allowing PID tunings to be adjusted on the fly (required MAX_TOKENS 5 in cmndproc.h library)
// 20120920 Added RoR calcs
// 20120921 Updated RoR calcs to better handle first loop issue (RoR not calculated in first loop)
// Stopped ANLG1 being read during PID control
// Added code to convert PID Setpoint temps to correct units. Added temperature units data to profile format
// Serial command echo to LCD now optional
// 20120922 Added support for LCDapter buttons and LEDs (button 1 currently activates or deactivates PID control if enabled)
// Added code to allow power to OT1 to be cut if OT2 is below HTR_CUTOFF_FAN_VAL percentage as defined in user.h. For heater protection if required. Required modification to phase_ctrl.cpp
// Added code to allow OT2 to range between custom min and max percentages (defined in user.h)
// 20121007 Fixed PID tuning command so it handles doubles
// Added inital PID tuning parameters in user.h
// 20121013 Added code to allow Artisan plotting of levelOT1 and levelOT2 if PLOT_POWER is defined in user.h
// Swapped location of T1 and T2 on LCD display and renamed to ET and BT
// 20121014 Enhanced LCD display code and added support for 4x20 LCDs. Define LCD_4x20 in user.h
// 20121021 Added optional limits for Analogue1
// 20121120 Added support for pBourbon logging
// 20121213 Added UP and DOWN parameters for OT1 and OT2 commands. Increments or decrements power levels by 5%
// 20130116 Added user adjustable analogue input rounding (DUTY_STEP) in user.h
// 20130119 aArtisanQ_PID release 3_5
// Added code to allow for additional LCD display modes
// 20130120 Added ability to change roast profile using LCD and buttons
// 20130121 Tidied up button press code
// 20130203 Permits use of different TC types on individual channels as in aArtisan 2.10
// Updated temperature sample filtering to match aArtisan 2.10
// 20130406 Added GO and STOP commands to use with Artisan 'Charge' and 'End' buttons
// 20140127 aArtisanQ_PID release 4_0 created
// Added support for Roastlogger roasting software (responds to LOAD, POWER and FAN commands. Sends rorT1=, T1=, rorT2=, T2= and power levels to roastlogger)
// 20140128 Improved handling of heater and fan power limits
// 20140213 aArtisanQ_PID release 4_2
// 20140214 Added option in user.h to define software mode (Artisan, Roastlogger or pBourbon)
// Fixed? bug causing crashes when receiving READ commands
// 20140214 aArtisanQ_PID release 4_3
// 20150328 Replaced pBourbon option with Android option
// Bug fix in LCD menu code. Menu code disabled when not roasting stand alone
// Changed default PID channel to 0
// Added SV to values sent to Android app
// 20150328 aArtisanQ_PID release 5_0
// 20150403 Added PID;SV command from aArtisan
// Changed default PID roast profile to 0 when using logging software
// Reduced SRAM usage
// 20150404 Added PID;CHAN PID;CT and FILT commands
// Added Heater, Fan and SV values to Artisan Logger if PID active
// Removed PLOT_POWER option. Send power levels and SV if PID is active for Artisan. Send all by default for Android
// 20150409 Made loop time variable. Default = 1000ms (1s) but changes to 2000ms (2s) if needed for reading 4 temperature channels
// Adjusted Read command to match aArtisan. Runs logger() from command to provide immediate response to Artisan
// 20150426 Removed io3, rf2000 and rc2000 commands to save memory
// Other small compile changes to save memory
// Compile directive change to ensure output levels are displayed when analogue pots are not active
// 20160416 Added fast PWM (3.922kHz) available in Phase Angle Control Mode on IO3. Enable using IO3_HTR_PAC in user.h.
// Moved default zero-cross interrupt to IO2 to allow PWM out on IO3.
// Also does 3.922kHz PWM for DC fan on IO3 in PWM mode.
// Added Min and Max for IO3 output
// aArtisanQ_PID version 6_2 released for testing
// 20161214 Added some compile directives to disable the pwmio3 variable when IO3_HTR_PAC is not defined (JGG)
// This was causing the pullup on IO3 to be disabled and intefered with use of IO3 as the ZCD input
// 20161216 Changes to user.h (and others) to implement pre-defined configurations
// 20171004 Changed definition of PID_CHAN from logical channel to physical channel
// This was causing issues with Artisan Roasting Scope logic when doing background follow with TC4 PID and logical channels set using CHAN;2100
// Artisan Roasting Scope is assuming X in PID;CHAN;X command is a physical channel
// Adjusted ROR_CHAN code to match physical channel approach
// Adjusted command.txt to suit above changes
#define BANNER_ARTISAN "aArtisanQ_PID 6_3"
// this library included with the arduino distribution
#include <Wire.h>
// The user.h file contains user-definable and some other global compiler options
// It must be located in the same folder as aArtisan.pde
#include "user.h"
// command processor declarations -- must be in same folder as aArtisan
#include "cmndreader.h"
#ifdef MEMORY_CHK
// debugging memory problems
#include "MemoryFree.h"
#endif
#ifdef PHASE_ANGLE_CONTROL
// code for integral cycle control and phase angle control
#include "phase_ctrl.h"
#endif
#include <PWM16.h> // for SSR output
// these "contributed" libraries must be installed in your sketchbook's arduino/libraries folder
#include <cmndproc.h> // for command interpreter
#include <thermocouple.h> // type K, type J, and type T thermocouple support
#include <cADC.h> // MCP3424
#ifdef LCD
#include <cLCD.h> // required only if LCD is used
#endif
#if defined KORRY
// -LMMS 1Abr18-
// Libraries for Digital Display and Encoders
#include "TM1637.h"
#include <CommonBusEncoders.h>
// END LMMS
#endif
// ------------------------ other compile directives
#define MIN_DELAY 300 // ms between ADC samples (tested OK at 270)
#define DP 1 // decimal places for output on serial port
#define D_MULT 0.001 // multiplier to convert temperatures from int to float
#define DELIM "; ,=" // command line parameter delimiters
#include <mcEEPROM.h>
mcEEPROM eeprom;
calBlock caldata;
float AT; // ambient temp
float T[NC]; // final output values referenced to physical channels 0-3
int32_t ftemps[NC]; // heavily filtered temps
int32_t ftimes[NC]; // filtered sample timestamps
int32_t ftemps_old[NC]; // for calculating derivative
int32_t ftimes_old[NC]; // for calculating derivative
float RoR[NC]; // final RoR values
uint8_t actv[NC]; // identifies channel status, 0 = inactive, n = physical channel + 1
#ifdef CELSIUS // only affects startup conditions
boolean Cscale = true;
#else
boolean Cscale = false;
#endif
int levelOT1, levelOT2; // parameters to control output levels
#if !(defined PHASE_ANGLE_CONTROL && (INT_PIN == 3) )
int levelIO3;
#endif
#ifdef MEMORY_CHK
uint32_t checktime;
#endif
#ifdef ANALOGUE1
uint8_t anlg1 = 0; // analog input pins
int32_t old_reading_anlg1; // previous analogue reading
boolean analogue1_changed;
#endif
#ifdef ANALOGUE2
uint8_t anlg2 = 1; // analog input pins
int32_t old_reading_anlg2; // previous analogue reading
boolean analogue2_changed;
#endif
#ifdef PID_CONTROL
#include <PID_v1.h>
//Define PID Variables we'll be connecting to
double Setpoint, Input, Output, SV; // SV is for roasting software override of Setpoint
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
uint8_t pid_chan = PID_CHAN; // identify PV and set default value from user.h
int profile_number; // number of the profile for PID control
int profile_ptr; // EEPROM pointer for profile data
char profile_name[40];
char profile_description[80];
int profile_number_new; // used when switching between profiles
int times[2], temps[2]; // time and temp values read from EEPROM for setpoint calculation
char profile_CorF; // profile temps stored as Centigrade or Fahrenheit
#endif
uint32_t counter; // second counter
uint32_t next_loop_time; //
boolean first;
uint16_t looptime = 1000;
// class objects
cADC adc( A_ADC ); // MCP3424
ambSensor amb( A_AMB ); // MCP9800
filterRC fT[NC]; // filter for logged ET, BT
filterRC fRise[NC]; // heavily filtered for calculating RoR
filterRC fRoR[NC]; // post-filtering on RoR values
#ifndef PHASE_ANGLE_CONTROL
PWM16 ssr; // object for SSR output on OT1, OT2
#endif
// revised 14-Dec-2016 by JGG to disable constructor of pwmio3 when IO3_HTR_PAC not used
// revised 24-Sep-2017 by Brad changed from #ifdef IO3_HTR_PAC to #ifndef CONFIG_PAC3
#ifndef CONFIG_PAC3
PWM_IO3 pwmio3;
#endif
// -LMMS 1Abr18-
#if defined KORRY
// Objects and variables for Digital Displays
// Timer
#define CLK_1 A1 // Pins timer display
#define DIO_1 A0
TM1637 digitalDisplayTime(CLK_1,DIO_1); // Timer display object
#define TIME_TIMER_SET_FLASHED 5000 // Time roasting to flash preset
long timeTimerSetFlashed; // Time roasting preset flashed
// Temperature
#define CLK_2 A3 // Pins temperature display
#define DIO_2 A2
TM1637 digitalDisplayTemperature(CLK_2,DIO_2); // Temperature display object
#define TEMPERATURE_TIME_FLASHED_BT 5000 // Time the BT tmperature must be flashed
boolean flagCelsiusDegrees=false; // Temperature in celsius degrees?
// E N C O D E R S
// Objects and variables for encoders
int16_t previousValueEncoderTime;
// Both
CommonBusEncoders encoders(4, 5, 6, 2);
// Temperature
#define MAXIMUM_ROAST_TIME 30 // Maximum roasting time
#define TEMPERATURE_BUTTON_HOLD_CHANGE_UNITS 3000 // Time encoder button pressed to change units (°F, °C)
long timeTemperatureBTFlashed=millis();
boolean flagSettingRoastTemperature=false; // Is the roast temperature setting?
boolean flagTemperatureSetting = false; // Has the encoder moved?
// Both
#define TIME_WAIT_ENCODER_MORE_ACTIVITY 5000 // Time wait more encoder activity
boolean flagMovingEncoder=false; // Has the encoder moved?
long timeEncoderMoved;
// General variables
int temperatureET,temperatureBT;
#endif
// -END LMMS 1Abr18-
CmndInterp ci( DELIM ); // command interpreter object
// array of thermocouple types
tcBase * tcp[4];
TC_TYPE1 tc1;
TC_TYPE2 tc2;
TC_TYPE3 tc3;
TC_TYPE4 tc4;
// ---------------------------------- LCD interface definition
#ifdef LCD
// LCD output strings
char st1[6],st2[6];
int LCD_mode = 0;
#ifdef LCDAPTER
#include <cButton.h>
cButtonPE16 buttons; // class object to manage button presses
#define BACKLIGHT lcd.backlight();
cLCD lcd; // I2C LCD interface
#else // parallel interface, standard LiquidCrystal
#define BACKLIGHT ;
#define RS 2
#define ENABLE 4
#define D4 7
#define D5 8
#define D6 12
#define D7 13
LiquidCrystal lcd( RS, ENABLE, D4, D5, D6, D7 ); // standard 4-bit parallel interface
#endif
#endif
// --------------------------------------------- end LCD interface
// T1, T2 = temperatures x 1000
// t1, t2 = time marks, milliseconds
float calcRise( int32_t T1, int32_t T2, int32_t t1, int32_t t2 ) {
int32_t dt = t2 - t1;
if( dt == 0 ) return 0.0; // fixme -- throw an exception here?
float dT = ( convertUnits( T2 ) - convertUnits( T1 ) ) * D_MULT;
float dS = dt * 0.001; // convert from milli-seconds to seconds
return ( dT / dS ) * 60.0; // rise per minute
// ------------- wrapper for the command interpreter's serial line reader
void checkSerial() {
const char* result = ci.checkSerial();
if( result != NULL ) { // some things we might want to do after a command is executed
#if defined LCD && defined COMMAND_ECHO
lcd.setCursor( 0, 0 ); // echo all commands to the LCD
lcd.print( result );
#endif
#ifdef MEMORY_CHK
Serial.print(F("# freeMemory()="));
Serial.print(freeMemory());
Serial.print(F(" , "));
Serial.println( result );
#endif
void checkStatus( uint32_t ms ) { // this is an active delay loop
uint32_t tod = millis();
while( millis() < tod + ms ) {
checkSerial();
dcfan.slew_fan(); // keep the fan smoothly increasing in speed
#endif
#ifdef LCDAPTER
#if not ( defined ROASTLOGGER || defined ARTISAN || defined ANDROID )
checkButtons();
#endif
#endif
float convertUnits ( float t ) {
if( Cscale ) return F_TO_C( t );
else return t;
void logger() {
#ifdef ARTISAN
// print ambient
Serial.print( convertUnits( AT ), DP );
// print active channels
for( uint8_t jj = 0; jj < NC; ++jj ) {
uint8_t k = actv[jj];
if( k > 0 ) {
--k;
Serial.print(F(","));
Serial.print( convertUnits( T[k] ),DP );
if( FAN_DUTY < HTR_CUTOFF_FAN_VAL ) { // send 0 if OT1 has been cut off
Serial.print( 0 );
else {
Serial.print( HEATER_DUTY );
Serial.print( FAN_DUTY );
if( myPID.GetMode() != MANUAL ) { // If PID in AUTOMATIC mode
Serial.print( Setpoint );
Serial.print( 0 ); // send 0 if PID is off
#endif
#ifdef ROASTLOGGER
if( k > 0 ) {
--k;
Serial.print(F("rorT"));
Serial.print(k+1);
Serial.print(F("="));
Serial.println( RoR[k], DP );
Serial.print(F("T"));
Serial.print(k+1);
Serial.println( convertUnits( T[k] ) );
Serial.print(F("Power%="));
Serial.println( 0 );
else {
Serial.println( HEATER_DUTY );
Serial.print(F("Fan="));
#endif
#ifdef ANDROID
// print counter
//Serial.print( counter );
//Serial.print( F(",") );
// print ambient
if( k > 0 ) {
--k;
Serial.print( convertUnits( T[k] ) );
Serial.print( RoR[k], DP );
//#ifdef PLOT_POWER
Serial.print( 0 );
else {
//#endif
#ifdef PID_CONTROL
#endif
#endif
void get_samples() // this function talks to the amb sensor and ADC via I2C
int32_t v;
tcBase * tc;
float tempF;
int32_t itemp;
float rx;
uint16_t dly = amb.getConvTime(); // use delay based on slowest conversion
uint16_t dADC = adc.getConvTime();
dly = dly > dADC ? dly : dADC;
for( uint8_t jj = 0; jj < NC; jj++ ) { // one-shot conversions on both chips
// -LMMS 1Abr18-
#if defined KORRY
// Check encoders activity
checkEncoders();
if(flagMovingEncoder)
return;
#endif
// -END LMMS-
uint8_t k = actv[jj]; // map logical channels to physical ADC channels
if( k > 0 ) {
--k;
tc = tcp[k]; // each channel may have its own TC type
adc.nextConversion( k ); // start ADC conversion on physical channel k
amb.nextConversion(); // start ambient sensor conversion
checkStatus( dly ); // give the chips time to perform the conversions
if( !first ) { // on first loop dont save zero values
ftemps_old[k] = ftemps[k]; // save old filtered temps for RoR calcs
ftimes_old[k] = ftimes[k]; // save old timestamps for filtered temps for RoR calcs
ftimes[k] = millis(); // record timestamp for RoR calculations
amb.readSensor(); // retrieve value from ambient temp register
v = adc.readuV(); // retrieve microvolt sample from MCP3424
tempF = tc->Temp_F( 0.001 * v, amb.getAmbF() ); // convert uV to Celsius
// filter on direct ADC readings, not computed temperatures
v = fT[k].doFilter( v << 10 ); // multiply by 1024 to create some resolution for filter
v >>= 10;
AT = amb.getAmbF();
T[k] = tc->Temp_F( 0.001 * v, AT ); // convert uV to Fahrenheit;
ftemps[k] =fRise[k].doFilter( tempF * 1000 ); // heavier filtering for RoR
if ( !first ) { // on first loop dont calc RoR
rx = calcRise( ftemps_old[k], ftemps[k], ftimes_old[k], ftimes[k] );
RoR[k] = fRoR[k].doFilter( rx / D_MULT ) * D_MULT; // perform post-filtering on RoR values
first = false;
#ifdef LCD
void updateLCD() {
if( LCD_mode == 0 ) { // Display normal LCD screen
lcd.setCursor(0,0);
if(counter/60 < 10) lcd.print(F("0")); lcd.print(counter/60); // Prob can do this better. Check aBourbon.
lcd.print(F(":")); // make this blink?? :)
if(counter - (counter/60)*60 < 10) lcd.print(F("0")); lcd.print(counter - (counter/60)*60);
#ifdef LCD_4x20
#ifdef COMMAND_ECHO
lcd.print(F(" ")); // overwrite artisan commands
#endif
// display the first 2 active channels encountered, normally BT and ET
int it01;
uint8_t jj,j;
uint8_t k;
for( jj = 0, j = 0; jj < NC && j < 2; ++jj ) {
k = actv[jj];
if( k != 0 ) {
++j;
it01 = round( convertUnits( T[k-1] ) );
if( it01 > 999 )
it01 = 999;
if( it01 < -999 ) it01 = -999;
sprintf( st1, "%4d", it01 );
if( j == 1 ) {
lcd.setCursor( 13, 0 );
lcd.print(F("ET:"));
else {
lcd.setCursor( 13, 1 );
lcd.print( F("BT:") );
lcd.print(st1);
// AT
it01 = round( convertUnits( AT ) );
if( it01 > 999 )
it01 = 999;
sprintf( st1, "%3d", it01 );
lcd.setCursor( 6, 0 );
lcd.print(F("AT:"));
lcd.print(st1);
#ifdef PID_CONTROL
if( myPID.GetMode() != MANUAL ) { // if PID is on then display PID: nnn% instead of OT1:
lcd.setCursor( 0, 2 );
lcd.print( F("PID:") );
if( FAN_DUTY < HTR_CUTOFF_FAN_VAL ) { // display 0% if OT1 has been cut off
sprintf( st1, "%4d", (int)0 );
else {
sprintf( st1, "%4d", (int)HEATER_DUTY );
lcd.print( st1 ); lcd.print(F("%"));
lcd.setCursor( 13, 2 ); // display setpoint if PID is on
lcd.print( F("SP:") );
sprintf( st1, "%4d", (int)Setpoint );
lcd.print( st1 );
else {
//#ifdef ANALOGUE1
lcd.print(F(" ")); // blank out SP: nnn if PID is off
//#else
// lcd.setCursor( 0, 2 );
// lcd.print(F(" ")); // blank out PID: nnn% and SP: nnn if PID is off and ANALOGUE1 isn't defined
//#endif // end ifdef ANALOGUE1
#endif // end ifdef PID_CONTROL
// RoR
lcd.setCursor( 0, 1 );
lcd.print( F("RoR:"));
sprintf( st1, "%4d", (int)RoR[ROR_CHAN - 1] ); // adjust ROR_CHAN for 0-based array index
lcd.print( st1 );
//#ifdef ANALOGUE1
#ifdef PID_CONTROL
if( myPID.GetMode() == MANUAL ) { // only display OT2: nnn% if PID is off so PID display isn't overwriten
lcd.print(F("HTR:"));
else {
#else // if PID_CONTROL isn't defined then always display OT1: nnn%
else {
//#ifdef ANALOGUE2
lcd.setCursor( 0, 3 );
lcd.print(F("FAN:"));
sprintf( st1, "%4d", (int)FAN_DUTY );
//#endif
#else // if not def LCD_4x20 ie if using a standard 2x16 LCD
#ifdef COMMAND_ECHO
#endif
int it01;
uint8_t jj,j;
uint8_t k;
k = actv[jj];
if( k != 0 ) {
++j;
if( it01 > 999 )
it01 = 999;
if( j == 1 ) {
lcd.setCursor( 9, 0 );
else {
lcd.setCursor( 9, 1 );
lcd.print(st1);
#ifdef PID_CONTROL
lcd.print( F(" 0") );
else {
sprintf( st1, "%3d", (int)HEATER_DUTY );
lcd.print( st1 );
lcd.print(F("%"));
lcd.print(st1);
else {
lcd.print( st1 );
#else
lcd.print( st1 );
#ifdef ANALOGUE1
if( analogue1_changed == true ) { // overwrite RoR or PID values
lcd.print(F("OT1: "));
lcd.setCursor( 4, 1 );
sprintf( st1, "%3d", (int)0 );
else {
#endif //ifdef ANALOGUE1
#ifdef ANALOGUE2
if( analogue2_changed == true ) { // overwrite RoR or PID values
lcd.print(F("OT2: "));
sprintf( st1, "%3d", (int)FAN_DUTY );
#endif // end ifdef ANALOGUE2
#endif // end of ifdef LCD_4x20
else if( LCD_mode == 1 ) { // Display alternative 1 LCD display
#ifdef PID_CONTROL
#ifdef LCD_4x20
for( int i = 0; i < 20; i++ ) {
if( profile_name[i] != 0 ) lcd.print( profile_name[i] );
if( profile_description[i] != 0 ) lcd.print( profile_description[i] );
for( int i = 20; i < 40; i++ ) {
lcd.print(F("PID: ")); lcd.print( myPID.GetKp() ); lcd.print(F(",")); lcd.print( myPID.GetKi() ); lcd.print(F(",")); lcd.print( myPID.GetKd() );
lcd.print(F("P:")); lcd.print( myPID.GetKp() ); lcd.print(F(",")); lcd.print( myPID.GetKi() ); lcd.print(F(",")); lcd.print( myPID.GetKd() );
#endif // end ifdef LCD_4x20
} // end of updateLCD()
#if defined ANALOGUE1 || defined ANALOGUE2
// -------------------------------- reads analog value and maps it to 0 to 100
// -------------------------------- rounded to the nearest DUTY_STEP value
int32_t getAnalogValue( uint8_t port ) {
int32_t mod, trial, min_anlg1, max_anlg1, min_anlg2, max_anlg2;
#ifdef IO3_HTR_PAC
min_anlg1 = MIN_IO3;
max_anlg1 = MAX_IO3;
min_anlg2 = MIN_OT2;
max_anlg2 = MAX_OT2;
#else
min_anlg1 = MIN_OT1;
max_anlg1 = MAX_OT1;
#endif
#else // PWM Mode
min_anlg2 = MIN_IO3;
max_anlg2 = MAX_IO3;
#endif
float aval;
aval = analogRead( port );
#ifdef ANALOGUE1
if( port == anlg1 ) {
aval = min_anlg1 * 10.24 + ( aval / 1024 ) * 10.24 * ( max_anlg1 - min_anlg1 ) ; // scale analogue value to new range
if ( aval == ( min_anlg1 * 10.24 ) ) aval = 0; // still allow OT1 to be switched off at minimum value. NOT SURE IF THIS FEATURE IS GOOD???????
mod = min_anlg1;
#endif
#ifdef ANALOGUE2
if( port == anlg2 ) {
aval = min_anlg2 * 10.24 + ( aval / 1024 ) * 10.24 * ( max_anlg2 - min_anlg2 ) ; // scale analogue value to new range
if ( aval == ( min_anlg2 * 10.24 ) ) aval = 0; // still allow OT2 to be switched off at minimum value. NOT SURE IF THIS FEATURE IS GOOD???????
mod = min_anlg2;
#endif
trial = ( aval + 0.001 ) * 100; // to fix weird rounding error from previous calcs?????
trial /= 1023;
trial = ( trial / DUTY_STEP ) * DUTY_STEP; // truncate to multiple of DUTY_STEP
if( trial < mod ) trial = 0;
// mod = trial % DUTY_STEP;
// trial = ( trial / DUTY_STEP ) * DUTY_STEP; // truncate to multiple of DUTY_STEP
// if( mod >= DUTY_STEP / 2 )
// trial += DUTY_STEP;
return trial;
#endif // end if defined ANALOGUE1 || defined ANALOGUE2
#ifdef ANALOGUE1
void readAnlg1() { // read analog port 1 and adjust OT1 output
char pstr[5];
int32_t reading;
reading = getAnalogValue( anlg1 );
if( reading <= 100 && reading != old_reading_anlg1 ) { // did it change?
analogue1_changed = true;
old_reading_anlg1 = reading; // save reading for next time
#ifdef IO3_HTR_PAC
levelIO3 = reading;
outIO3();
#else
levelOT1 = reading;
outOT1();
#endif
#else // PWM Mode
levelOT1 = reading;
outOT1();
#endif
else {
analogue1_changed = false;
#ifdef ANALOGUE2
void readAnlg2() { // read analog port 2 and adjust OT2 output
char pstr[5];
int32_t reading;
reading = getAnalogValue( anlg2 );
if( reading <= 100 && reading != old_reading_anlg2 ) { // did it change?
analogue2_changed = true;
old_reading_anlg2 = reading; // save reading for next time
levelOT2 = reading;
outOT2(); // update fan output on OT2
#else // PWM Mode
levelIO3 = reading;
outIO3(); // update fan output on IO3
#endif
else {
analogue2_changed = false;
#ifdef PID_CONTROL
void updateSetpoint() { //read profile data from EEPROM and calculate new setpoint
if(profile_number > 0 ){
while( counter < times[0] || counter >= times[1] ) { // if current time outside currently loaded interval then adjust profile pointer before reading new interval data from EEPROM
if( counter < times[0] ) {
profile_ptr = profile_ptr - 2; // two bytes per int
else {
profile_ptr = profile_ptr + 2; // two bytes per int
eeprom.read( profile_ptr, (uint8_t*)×, sizeof(times) ); // read two profile times
eeprom.read( profile_ptr + 100, (uint8_t*)&temps, sizeof(temps) ); // read two profile temps. 100 = size of time data
if( times[1] == 0 ) {
Setpoint = 0;
myPID.SetMode(MANUAL); // deactivate PID control
Output = 0; // set PID output to 0
float x = (float)( counter - times[0] ) / (float)( times[1] - times[0] ); // can probably be tidied up?? Calcs proportion of time through current profile interval
Setpoint = temps[0] + x * ( temps[1] - temps[0] ); // then applies the proportion to the temps
if( profile_CorF == 'F' && Cscale ) { // make setpoint units match current units
Setpoint = convertUnits( Setpoint ); // convert F to C
else if( profile_CorF == 'C' & !Cscale) { // make setpoint units match current units
Setpoint = Setpoint * 9 / 5 + 32; // convert C to F
else {
Setpoint = SV;
void setProfile() { // set profile pointer and read initial profile data
if( profile_number > 0 ) {
profile_ptr = 1024 + ( 400 * ( profile_number - 1 ) ) + 4; // 1024 = start of profile storage in EEPROM. 400 = size of each profile. 4 = location of profile C or F data
eeprom.read( profile_ptr, (uint8_t*)&profile_CorF, sizeof(profile_CorF) ); // read profile temp type
getProfileDescription(profile_number); // read profile name and description data from eeprom for active profile number
profile_ptr = 1024 + ( 400 * ( profile_number - 1 ) ) + 125; // 1024 = start of profile storage in EEPROM. 400 = size of each profile. 125 = size of profile header data
eeprom.read( profile_ptr, (uint8_t*)×, sizeof(times) ); // read 1st two profile times
eeprom.read( profile_ptr + 100, (uint8_t*)&temps, sizeof(temps) ); // read 1st two profile temps. 100 = size of time data
// profile_ptr is left set for profile temp/time reads
//else //do something?
void getProfileDescription(int pn) { // read profile name and description data from eeprom
int pp = 1024 + ( 400 * ( pn - 1 ) ) + 5; // 1024 = start of profile storage in EEPROM. 400 = size of each profile. 5 = location of profile name
eeprom.read( pp, (uint8_t*)&profile_name, sizeof(profile_name) ); // read profile name
pp = 1024 + ( 400 * ( pn - 1 ) ) + 45; // 1024 = start of profile storage in EEPROM. 400 = size of each profile. 45 = location of profile description
eeprom.read( pp, (uint8_t*)&profile_description, sizeof(profile_description) ); // read profile name
#ifdef LCDAPTER
void checkButtons() { // take action if a button is pressed
if( buttons.readButtons() ) {
switch (LCD_mode) {
case 0: // Main LCD display
if( buttons.keyPressed( 0 ) && buttons.keyChanged( 0 ) ) { // button 1 - PID on/off - PREVIOUS PROFILE
#ifdef PID_CONTROL
myPID.SetMode( AUTOMATIC );
else {
myPID.SetMode( MANUAL );
#endif
else if( buttons.keyPressed( 1 ) && buttons.keyChanged( 1 ) ) { // button 2 - RESET TIMER - NEXT PROFILE
counter = 0;
else if( buttons.keyPressed( 2 ) && buttons.keyChanged( 2 ) ) { // button 3 - ENTER BUTTON
// do something
else if( buttons.keyPressed( 3 ) && buttons.keyChanged( 3 ) ) { // button 4 - CHANGE LCD MODE
lcd.clear();
LCD_mode++; // change mode
#ifndef PID_CONTROL
if( LCD_mode == 1 ) LCD_mode++; // deactivate LCD mode 1 if PID control is disabled
#endif
if( LCD_mode > 1 ) LCD_mode = 0; // loop at limit of modes
delay(5);
case 1: // Profile Selection and PID parameter LCD display
#ifdef PID_CONTROL
profile_number_new--;
if( profile_number_new == 0 ) profile_number_new = NUM_PROFILES; // loop profile_number to end
getProfileDescription(profile_number_new);
#endif
#ifdef PID_CONTROL
profile_number_new++;
if( profile_number_new > NUM_PROFILES ) profile_number_new = 1; // loop profile_number to start
#endif
#ifdef PID_CONTROL
profile_number = profile_number_new; // change profile_number to new selection
setProfile(); // call setProfile to load the profile selected
lcd.clear();
LCD_mode = 0; // jump back to main LCD display mode
#endif
lcd.clear();
#ifdef PID_CONTROL
profile_number_new = profile_number; // reset profile_number_new if profile wasn't changed
setProfile(); // or getProfileDescription()?????????
#endif
delay(5);
} //end of switch
} // end of if( buttons.readButtons() )
} // end of void checkButtons()
#endif // end ifdef LCDAPTER
void outOT1() { // update output for OT1
uint8_t new_levelot1;
#ifdef IO3_HTR_PAC // OT1 not cutoff by fan duty in IO3_HTR_PAC mode
new_levelot1 = levelOT1;
#else
if ( levelOT2 < HTR_CUTOFF_FAN_VAL ) {
new_levelot1 = 0;
else {
#endif
output_level_icc( new_levelot1 );
#else // PWM Mode
if ( levelIO3 < HTR_CUTOFF_FAN_VAL ) {
new_levelot1 = 0;
else {
ssr.Out( new_levelot1, levelOT2 );
#endif
void outOT2() { // update output for OT2
#ifdef IO3_HTR_PAC
outIO3(); // update IO3 output to cut or reinstate power to heater if required
#else
outOT1(); // update OT1 output to cut or reinstate power to heater if required
#endif
output_level_pac( levelOT2 );
#else // PWM Mode
if( levelIO3 < HTR_CUTOFF_FAN_VAL ) { // if levelIO3 < cutoff value then turn off heater
ssr.Out( 0, levelOT2 );
else { // turn OT1 and OT2 back on again if levelIO3 is above cutoff value.
ssr.Out( levelOT1, levelOT2 );
#endif
void outIO3() { // update output for IO3
float pow;
#ifdef IO3_HTR_PAC
uint8_t new_levelio3;
new_levelio3 = levelIO3;
if( levelOT2 < HTR_CUTOFF_FAN_VAL ) { // if levelIO3 < cutoff value then turn off heater on IO3
new_levelio3 = 0;
pow = 2.55 * new_levelio3;
pwmio3.Out( round(pow) );
#endif // IO3_HTR_PAC
#else // PWM Mode, fan on IO3
if( levelIO3 < HTR_CUTOFF_FAN_VAL ) { // if levelIO3 < cutoff value then turn off heater on OT1
pow = 2.55 * levelIO3;
#endif // PWM Mode, fan on IO3
// MAIN
delay(100);
Wire.begin();
//Serial.begin(BAUD);
amb.init( AMB_FILTER ); // initialize ambient temp filtering
#ifdef LCD
#ifdef LCD_4x20
lcd.begin(20, 4);
#else
lcd.begin(16, 2);
#endif // LCD_4x20
BACKLIGHT;
lcd.print( BANNER_ARTISAN ); // display version banner
#ifdef ANDROID
lcd.print( F("ANDROID") ); // display version banner
#endif // ANDROID
#ifdef ARTISAN
lcd.print( F("ARTISAN") ); // display version banner
#endif // ARTISAN
#ifdef ROASTLOGGER
lcd.print( F("ROASTLOGGER") ); // display version banner
#endif // ROASTLOGGER
#endif // LCD
#ifdef LCDAPTER
buttons.begin( 4 );
buttons.readButtons();
buttons.ledAllOff();
#endif
#ifdef MEMORY_CHK
Serial.println(freeMemory());
#endif
adc.setCal( CAL_GAIN, UV_OFFSET );
amb.setOffset( AMB_OFFSET );
// read calibration and identification data from eeprom
if( readCalBlock( eeprom, caldata ) ) {
adc.setCal( caldata.cal_gain, caldata.cal_offset );
amb.setOffset( caldata.K_offset );
else { // if there was a problem with EEPROM read, then use default values
// initialize filters on all channels
fT[0].init( ET_FILTER ); // digital filtering on ET
fT[1].init( BT_FILTER ); // digital filtering on BT
fT[2].init( ET_FILTER);
fT[3].init( ET_FILTER);
fRise[0].init( RISE_FILTER ); // digital filtering for RoR calculation
fRise[1].init( RISE_FILTER ); // digital filtering for RoR calculation
fRoR[0].init( ROR_FILTER ); // post-filtering on RoR values
fRoR[1].init( ROR_FILTER ); // post-filtering on RoR values
// set up output on OT1 and OT2 and IO3
levelOT1 = levelOT2 = 0;
levelIO3 = 0;
#endif
ssr.Setup( TIME_BASE );
#else
init_control();
#endif
// modifed 14-Dec-2016 by JGG
// revised 22-Mar-2017 by Brad changed from #ifdef IO3_HTR_PAC to #ifndef CONFIG_PAC3
#ifndef CONFIG_PAC3
pwmio3.Setup( IO3_PCORPWM, IO3_PRESCALE_8 ); // setup pmw frequency ion IO3
#endif
#ifdef ANALOGUE1
old_reading_anlg1 = getAnalogValue( anlg1 ); // initialize old_reading with initial analogue value
#endif
#ifdef ANALOGUE2
old_reading_anlg2 = getAnalogValue( anlg2 ); // initialize old_reading with initial analogue value
#endif
// initialize the active channels to default values
actv[0] = 2; // ET on TC1
actv[1] = 1; // BT on TC2
actv[2] = 0; // default inactive
actv[3] = 0; // default inactive
// assign thermocouple types
tcp[0] = &tc1;
tcp[1] = &tc2;
tcp[2] = &tc3;
tcp[3] = &tc4;
// add active commands to the linked list in the command interpreter object
ci.addCommand( &dwriter );
ci.addCommand( &awriter );
ci.addCommand( &units );
ci.addCommand( &chan );
#if ( !defined( PHASE_ANGLE_CONTROL ) ) || ( INT_PIN != 3 ) // disable when PAC active and pin 3 reads the ZCD
ci.addCommand( &io3 );
ci.addCommand( &dcfan );
#endif
ci.addCommand( &ot2 );
ci.addCommand( &ot1 );
ci.addCommand( &reader );
ci.addCommand( &pid );
ci.addCommand( &reset );
#ifdef ROASTLOGGER
ci.addCommand( &load );
ci.addCommand( &power );
ci.addCommand( &fan );
#endif
ci.addCommand( &filt );
dcfan.init(); // initialize conditions for dcfan
#endif
pinMode( LED_PIN, OUTPUT );
#ifdef LCD
delay( 500 );
lcd.clear();
#endif
#ifdef MEMORY_CHK
checktime = millis();
#endif
#ifdef PID_CONTROL
myPID.SetSampleTime(CT); // set sample time to 1 second
#ifdef IO3_HTR_PAC
myPID.SetOutputLimits(MIN_IO3, MAX_IO3); // set output limits to user defined limits
#else
myPID.SetOutputLimits(MIN_OT1, MAX_OT1); // set output limits to user defined limits
#endif
myPID.SetControllerDirection(DIRECT); // set PID to be direct acting mode. Increase in output leads to increase in input
myPID.SetTunings(PRO, INT, DER); // set initial PID tuning values
myPID.SetMode(MANUAL); // start with PID control off
// -180514 LMMS original line- profile_number = 1; // set default profile, 0 is for override by roasting software
profile_number = 0; // -180514 line added for LMMS (for avoid use profile in EEPROM)-
#else
profile_number = 0; // set default profile, 0 is for override by roasting software
#endif
setProfile(); // read profile description initial time/temp data from eeprom and set profile_pointer
#endif
first = true;
counter = 3; // start counter at 3 to match with Artisan. Probably a better way to sync with Artisan???
next_loop_time = millis() + looptime; // needed??
// -LMMS 1Abr18-
#if defined KORRY
// Setup Digital Displays
digitalDisplayTime.set(BRIGHT_TYPICAL);
digitalDisplayTime.init(D4056A);
digitalDisplayTemperature.set(BRIGHT_TYPICAL); // BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
digitalDisplayTemperature.init(D4056A); // D4056A is the type of the module
// Setup Encoders
encoders.setDebounce(16);
encoders.resetChronoAfter(1000);
encoders.addEncoder(1, 4, 7, 1, 11, 21); // Encoder timer
encoders.addEncoder(2, 4, 8, 1, 13, 23); // Encoder temperature
previousValueEncoderTime = -1;
timeEncoderMoved = millis();
#endif
// END LMMS
#if defined KORRY
if(flagMovingEncoder&&(millis()-timeEncoderMoved>TIME_WAIT_ENCODER_MORE_ACTIVITY))
flagMovingEncoder = false;
flagSettingRoastTemperature = false;
#endif
if( ACdetect() ) {
digitalWrite( LED_PIN, HIGH ); // illuminate the Arduino IDE if ZCD is sending a signal
else {
digitalWrite( LED_PIN, LOW );
#endif
#ifdef MEMORY_CHK
uint32_t now = millis();
if( now - checktime > 1000 ) {
checktime = now;
#endif
#if not defined KORRY
// Has a command been received?
checkSerial();
// Read temperatures
get_samples();
#else
if(!flagMovingEncoder)
checkSerial();
get_samples();
#endif
// Read analogue POT values if defined
#ifdef ANALOGUE1
#ifdef PID_CONTROL
if( myPID.GetMode() == MANUAL ) readAnlg1(); // if PID is off allow ANLG1 read
#else
readAnlg1(); // if PID_CONTROL is not defined always allow ANLG1 read
#endif // PID_CONTROL
#endif // ANALOGUE1
#ifdef ANALOGUE2
readAnlg2();
#endif
// Run PID if defined and active
#ifdef PID_CONTROL
#if defined KORRY
#endif
if( myPID.GetMode() != MANUAL ) { // If PID in AUTOMATIC mode calc new output and assign to OT1
updateSetpoint(); // read profile data from EEPROM and calculate new setpoint
uint8_t k = pid_chan; // k = physical channel
if( k != 0 ) --k; // adjust for 0-based array index
// Input is the SV for the PID algorithm
Input = convertUnits( T[k] );
myPID.Compute(); // do PID calcs
#ifdef IO3_HTR_PAC
levelIO3 = Output; // update levelOT1 based on PID optput
outIO3();
#else
levelOT1 = Output; // update levelOT1 based on PID optput
outOT1();
#endif
#ifdef ACKS_ON
Serial.print(F("# PID input = " )); Serial.print( Input ); Serial.print(F(" "));
Serial.print(F("# PID output = " )); Serial.println( levelOT1 );
#endif
#if defined KORRY
#endif
#endif
// Update LCD if defined
#ifdef LCD
updateLCD();
#endif
// Send data to Roastlogger if defined
#if defined ROASTLOGGER
logger(); // send data every second to Roastlogger every loop (looptime)
#endif
// -LMMS 1Abr18-
#if defined KORRY
#endif
// -END LMMS-
// check if temp reads has taken longer than looptime. If so add 1 to counter + increase next looptime
// Serial.println( next_loop_time - millis() ); // how much time spare in loop. approx 350ms
if ( millis() > next_loop_time ) {
counter = counter + ( looptime / 1000 ); if( counter > 3599 ) counter = 3599;
next_loop_time = next_loop_time + looptime; // add time until next loop
// wait until looptiom is expired. Check serial and buttons while waiting
while( millis() < next_loop_time ) {
// -LMMS 1Abr18-
checkEncoders();
checkSerial(); // Has a command been received?
#ifdef LCDAPTER
#if not ( defined ROASTLOGGER || defined ARTISAN || defined ANDROID ) // Stops buttons being read unless in standalone mode. Added to fix crash (due to low memory?).
checkButtons();
#endif
#endif
// Set next loop time and increment counter
// -LMMS 1Abr18-
#if defined KORRY
#endif
// -END LMMS-
// -LMMS 1Abr18-
#if defined KORRY
// Display time and temperature and encoders activity
checkEncoders();
displayTime();
displayTemperature();
handleToasterFan();
coolToast();
#endif
// -END LMMS-
// -LMMS 1Abr18-
#if defined KORRY
int16_t indexEncoder;
int16_t valueEncoderTime=0,valueEncoderTemperature;
long timePreviousClick=millis();
#define DELAY_DOUBLE_CLICK 1500 // Delay for identify doble click
long timeButtonTemperatureStartPressed=0; // Time button encoder temperature start pressed
int16_t timeRoastSet,timeRemainingEndRoast;
long timeStartToast,timeStartCool;
int16_t temperatureToastingFahrenheitSet=100,temperatureToastingCelsiusSet=50; // Temperature preset initial values
int16_t temperatureToastingSet;
boolean flagToasting=false,flagSettingRoastTime=false,flagToastTimeSet=false,flagToasterPowerON=false,
flagFanPowerON=false,flagTemperatureRising=true,flagTimeRunning=false,flagCoolToast=false;
boolean flagRoastTemperatureSet=true;
void checkEncoders()
timeButtonTemperatureStartPressed = millis();
indexEncoder = encoders.readAll();
if(indexEncoder!=0)
if(flagToasting&&(indexEncoder==11||indexEncoder==12))
return;
flagMovingEncoder = true;
//Serial.println(indexEncoder);
switch (indexEncoder)
case 11: // Time CW
if(!flagSettingRoastTime)
return;
valueEncoderTime++;
if (valueEncoderTime>MAXIMUM_ROAST_TIME)
valueEncoderTime = MAXIMUM_ROAST_TIME;
digitalDisplayTime.display(valueEncoderTime);
case 12: // Time CCW
return;
valueEncoderTime--;
if (valueEncoderTime<0)
valueEncoderTime = 0;
case 21: // Time click
if(millis()-timePreviousClick<DELAY_DOUBLE_CLICK) // Double click
//Serial.println("Double click");
ci.setCmndStr("OT1;0");
//ci.setCmndStr("OT2;0");
levelIO3 = 0;
outIO3();
flagToastTimeSet = false;
flagSettingRoastTime = true;
digitalDisplayTime.point(false);
timeRoastSet = valueEncoderTime;
flagToastTimeSet = true;
flagSettingRoastTime = false;
timePreviousClick = millis() - DELAY_DOUBLE_CLICK;
else // Click
if(flagToastTimeSet&&flagRoastTemperatureSet)
if(!flagToasting)
ci.setCmndStr("OT1;100");
//ci.setCmndStr("OT2;87");
levelIO3 = 87;
outIO3();
digitalDisplayTime.point(true);
digitalDisplayTime.display(timeRoastSet*100);
//timeStartToast = millis() / 1000;
timeRemainingEndRoast = timeRoastSet;
flagToasterPowerON = true;
flagTemperatureRising = true;
flagTimeRunning = false;
flagToasting = true;
if(flagCelsiusDegrees)
temperatureToastingSet = temperatureToastingCelsiusSet;
temperatureToastingSet = temperatureToastingFahrenheitSet;
levelIO3 = 0;
outIO3();
timeRemainingEndRoast = 0;
flagToasterPowerON = false;
flagToasting = false;
flagCoolToast = false;
timePreviousClick = millis();
case 13: // Temperature CW
if(!flagSettingRoastTemperature)
return;
//temperatureToastingCelsiusSet++;
temperatureToastingCelsiusSet += 5;
digitalDisplayTemperature.display(temperatureToastingCelsiusSet);
//temperatureToastingFahrenheitSet++;
temperatureToastingFahrenheitSet += 5;
digitalDisplayTemperature.display(temperatureToastingFahrenheitSet);
case 14: // Temperature CCW
return;
//temperatureToastingCelsiusSet--;
temperatureToastingCelsiusSet =- 5;
if (temperatureToastingCelsiusSet<0)
temperatureToastingCelsiusSet = 0;
//temperatureToastingFahrenheitSet--;
temperatureToastingFahrenheitSet -= 5;
if (temperatureToastingFahrenheitSet<0)
temperatureToastingFahrenheitSet = 0;
case 23:
//Serial.println("Double click temperature");
flagRoastTemperatureSet = false;
flagSettingRoastTemperature = true;
// Patch
// End patch
flagRoastTemperatureSet = true;
else // Long click
if(millis()-timeButtonTemperatureStartPressed>TEMPERATURE_BUTTON_HOLD_CHANGE_UNITS)
if(!flagCelsiusDegrees)
flagCelsiusDegrees = true;
flagCelsiusDegrees = false;
//Serial.println("Long click temperature");
previousValueEncoderTime = valueEncoderTime;
int tempVariable;
void displayTime()
if(flagMovingEncoder||!flagToasting||!flagTimeRunning)
return;
tempVariable = timeRoastSet * 60 - (millis() / 1000 - timeStartToast);
timeRemainingEndRoast = tempVariable / 60 * 100 + tempVariable % 60;
if(timeRemainingEndRoast<0) { // It doesn't come out here. Come out from handleToasterFan()
return;
digitalDisplayTime.display(timeRemainingEndRoast);
if(millis()-timeTimerSetFlashed>TIME_TIMER_SET_FLASHED)
timeTimerSetFlashed = millis();
int it01;
void displayTemperature()
return;
if(millis()-timeTemperatureBTFlashed<TEMPERATURE_TIME_FLASHED_BT)
// Display ET temperature
it01 = round( convertUnits( T[1] ) );
if( it01 > 999 )
it01 = 999;
else if( it01 < -999 )
it01 = -999;
it01 = (it01 - 32) / 1.8;
temperatureET = it01;
digitalDisplayTemperature.display(temperatureET);
// Display BT temperature
it01 = round( convertUnits( T[0] ) );
if( it01 > 999 )
it01 = 999;
it01 = -999;
temperatureBT = it01;
digitalDisplayTemperature.clearDisplay();
checkEncodersFlash(150);
return;
digitalDisplayTemperature.display(temperatureBT);
checkEncodersFlash(1000);
return;
return;
timeTemperatureBTFlashed = millis();
boolean checkEncodersFlash(int flashDelay)
long timeStart=millis();
while(millis()-timeStart<flashDelay)
checkEncoders();
return true;
return false;
void handleToasterFan()
if(!flagToasting)
return;
if(!flagTimeRunning&&flagTemperatureRising&&(temperatureBT>temperatureToastingSet||temperatureET>temperatureToastingSet))
flagTimeRunning = true;
if(timeRemainingEndRoast==0)
//ci.setCmndStr("OT2;100");
levelIO3 = 100;
outIO3();
timeStartCool = millis();
flagCoolToast = true;
return;
// Roaster
if(flagTemperatureRising) // Temperature rising
//Serial.print("Rising ");
//Serial.print(temperatureBT);
//Serial.print(" ");
//Serial.print(temperatureET);
//Serial.println(temperatureToastingSet);
if(temperatureBT>temperatureToastingSet||temperatureET>temperatureToastingSet)
ci.setCmndStr("OT1;00");
flagTemperatureRising = false;
//ci.setCmndStr("OT2;00");
else // Temperature falling
int temperatureReference=temperatureToastingSet*0.97;
// int temperatureReference=temperatureToastingSet*(1-0.1*timeRemainingEndRoast/(timeRoastSet*60));
//Serial.print("Falling ");
//Serial.print(temperatureToastingSet);
//Serial.print(timeRoastSet);
//Serial.print(timeRemainingEndRoast);
//Serial.print(temperatureReference);
//Serial.println(temperatureET);
if(temperatureBT<temperatureReference&&temperatureET<temperatureReference)
char ot1Command[8],otiLevelS[4];
strcpy(ot1Command,"OT1;");
// Provisional
int ot1Level = 100;
//int ot1Level = timeRemainingEndRoast * 100 / (timeRoastSet * 60);
// End provisional
itoa(ot1Level,otiLevelS,10);
strcat(ot1Command,otiLevelS);
//Serial.println(ot1Command);
ci.setCmndStr(ot1Command);
void coolToast()
if(!flagCoolToast)
return;
if(millis()-timeStartCool<600000L) // 10 min
return;
levelIO3 = 0;
outIO3();
#endif
