Now that it's possible for the Arduino controller android application to import and export profiles, I thought it would be nice to have a place where we can exchange the profiles and the sketches.
Please add a screenshot if possible. If you don't have a place to upload the files send them to marque.l@gmail.com and I'll post them here.
If you don't want to worry about other people controlling your project use the share function in the application to export the profile, it will remove the IP before sending it with you mail editor.
Or just open the acp file with notepad and remove your IP manually.
Hi this is a work in progress. this is running on a arduino mega 2560 using transistor driven relays currently there are 5 digital light outputs and temp monitoring with min max and avg for both inside and out. there is going to be a total of 8 PWM zero crossing triac outputs for light dimmers and fan speed control, 8 digital triac outputs, 5 high current digital triac outputs, central heat and air control based on the difference in the inside and outside temps, motion detectors to count occupants entering and exiting the bedroom to automatically control lights, automatic door bell with visual image using an external ccd camera system, rfid and cellphone controlled door locks as well as entertainment center control using ir leds, digital pots, and relays. there is some code that isn't used at the moment if things look confusing. i am open to any feed back or suggestions.
Hello Marque ,
I just purchased the Pro App and I am starting to integrate some of the code functions that I had used in the original app you wrote . This is a slow process ( albiet fun ) but I truely am enjoying the results .
How do I add in the button functions when they are not defined in the Android app ? I added the function names in the settings , but can't find where the string names are associated ?
The more I look at the values you have built in for the red , green and blue , the more I would like to use them to set levels for the 3 areas that I am controlling mood lighting now.
I hope to get some time this long weekend to devote to this amazing integration project !
Thanks for all you have done thus far ; Arduino is such agreat learning platform ...especially when combined with Android !
Bob Durk
The only buttons that I am still having issues with is 11 and 12 ??
-the GET /?11 HTTP/1.1 and GET /?12 HTTP/1.1 appear on the serial monitor
-all I see is the white line on the (content_main_top) and it should be returning the button names that I have programmed in the Arduino sketch to the Android ?
Just an aside , I did have all 12 buttons working in a sketch with the original free version ( not the Pro Free ) ...but when I updated the Free I wasn't able to get 10 - 12 working .
Here is what I found that was preventing button S11 and S12 from working :
In the code where:
if (x == 10)
{client.print (content_main_top);
client.println(S10);
Serial.println(S10);
my code was in here and it had a return nested in it that should not have been and prevented any other statements below it
from being executed...my bad
I can now start making more buttons and rewrite the functions properly . This has been a great weekend of learning !
Here is where I am at now:
-I built a 2nd test node in a project box with a 2nd Ethernet Shield and Uno
-I added LEDS for testing the light levels from the 3 sliders on the tablet using Red=D5 Green=D6 Blue=D9
--Note that D10 and D11 can't be used as PWM as the Ethernet Shield requires them
--D3 I have used for IR ( to control stereo and CD player in my Node 1 " Home Control "
-I added 2 on board tactile switches D7 and D8 and set them as active LOW ( will be used to toggle lights on / off later)
-I also added a reset switch as the Ethernet shield is locking up ( or falling through ? ) with the code I am running
-I can use buttons for " Bench Lt Off " " Bench Lt On " " Curio Lt Off " " Curio Lt On " " All Off " " All On " no problem
Here is the issue ...I don't fully understand all that is going on in the test sketch for the sliders.
-I like the fact that the slider value is visible on the tablet , but I need to get the value to update when I change the value with the buttons or the corresponding slider.
-as it is now , if I turn lights on and off with the buttons for a while and then change the slider settings , eventually it will stop responding.
--the only way to get it working from that point is to reset the Ethernet Shield.
I will run the functions on the tablet for a while and see via the serial monitor where the problem occurs ...and if there is a common issue.
I will also post some of the code ( I am internet taught only , so don't expect much as i am still learning ! ) to see if it helps .
I tried to keep the functions for each button as simple as possible for testing
I shared the Work Bench profile with marque , as soon as I do a status update it locks up.
I will try to spend more time looking through code , but I think I am tripping up on the blue part ...I think it is just IB that I am supposed to be using to send for the blue slider.
I tried to attach code but it is too large ...I will send it later
Bob
BobbyD:
Bob
Please send me your sketch so i can test it.
Here is the part of your profile wich controls the sliders
else if (readString.indexOf("R") > 0){..............}
else if (readString.indexOf("Green=") > 0){..............}
else if (readString.indexOf("B") > 0){..............}
else if (readString.indexOf("Red=") > 0){..............}
else if (readString.indexOf("Blue=") > 0){..............}
Hello Marque,
I made the changes you suggested and I also removed parts of the code that I knew I would not need .
All the sliders now work and display the value stored.
Thanks for the help with that ....now to integrate the values and have the them diplayed when I select the " Update Status " button on the same layout. I had this in some other sketches but removed it to see if it was the cause of it locking up.
I would also like the slider to drop to " 0 " when I push the " Curio Off " " Bar Off " " Bench Off " or " All Off " buttons to reflect the changes .
Another nice thing would be to have the " Curio On " " Bar On " and " Bench On " buttons go green when the buttons are active.
I seen this in a sketch that was submitted for relay control ...perhaps I can incorporate that ...
How do I upload my Arduino sketch so you can look it over ?
Bob
Marque,
I went back to my profile #1 called Home Control and did the same changes for the slider names that you had suggested + removed some code that was not being used. It now operates without locking up and requiring a reset .
I shared this as well , as the IR functions work well and I am sure other can modify it to their needs .
Busy weekend ahead , but I will try to update as I make any changes.
Bob
Here is the code that I am running for the " Home Control " profile.The " Status Update " button returns the light levels for each of the 3 lighting zones . The slider levels do not respond to the changes made with the switches , but the values displayed are updated with each button or slider adjustment.
/*********************** Marque's Arduino Controller Example ***********************/
/* Controller_Pro_Home_Control port all the values and use the status update button
/* Bob_Automation_Marque_v1 this now works without locking up ....tested and shut down many times with no issues command after command
/* renamed sliders as Marque suggested + removed functions that didn't appear to be required for this application
/* Eth_2 demo box made with reset switch orange tack button pulls to ground for reset + added D7 and D8 switches as active LOW ***future use
/* in box: Red-330 ohm to pin D5 + Grn-330 ohm to pin D6 + Blu-330 ohm to pin D9 ALL common cathode connect to ground
/* use Work Bench profile in Arduino Controller Pro app
/* now reports buffer values for the status update back to android app so they match the buffer content of valuered valuegreen and valueblue
/*********************** For questions: marque.l@gmail.com ***********************/
#include <Ethernet.h>
#include <SPI.h>
#include <IRremote.h>
int RecievedString; // this is sent from android app and received by Ethernet shield
int valuered; // couple with curioLight to make object
int valuegreen; // couple with BarLight to make object
int valueblue; // couple with BenchLight to make object
int valueB; // andoid app can send this string value ...arduino will need to recognise string to decode results
int valueC; // andoid app can send this string value ...arduino will need to recognise string to decode results
int Channel; // not used at this time
int Volume; // not used at this time
int x; //
int y; //
int Y; //
int Z; //
int blue_value ; // this is used in code now
int red_value; // added / not used now
int green_value; // added / not used now
String string_x; //
long nowtime; //
long lastTime; //
String readString = String(20); // string length up to 20 characters is read and stored in readString
byte mac[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; // mac adress, change for every controller!
EthernetServer server(80); // port to listen on
IPAddress ip(192,168,1,100); // ip for fixed ip
EthernetClient client; // Ethernet Client to look for on the tcp port
char content_main_top[] = "<body bgcolor=black><font color=white><center>"; // html header to format the response webview. Black background and white text
char S1[] = "Power ON" ; //enter 01 as string 01
char S2[] = "Power OFF" ; //enter 02 as string 02
char S3[] = "FM Tuner"; //enter 03 as string 03
char S4[] = "CD Power Toggle"; //enter 04 as string 04
char S5[] = "CD Player"; //enter 05 as string 05
char S6[] = "CD Random"; //enter 06 as string 06
char S7[] = "IPod Player"; //enter 07 as string 07
char S8[] = "Bar Light Off"; //enter 08 as string 08
char S9[] = "Bar Light On"; //enter 09 as string 09
char S10[] = "Curio Lt Off"; //enter 10 as string 10
char S11[] = "Curio Lt On"; //enter 11 as string 11
char S20[] = "Bench Lt Off"; //enter 20 as string 20
char S21[] = "Bench Lt On"; //enter 21 as string 21
char S22[] = "Update Status"; //enter 22 as string 22
char S23[] = "All Off"; //enter 23 as string 23
char S24[] = "All On"; //enter 24 as string 24
char S404[] = "Not Found";
const int barLight = 6; // D6 use green slider green-value ( change to )
const int benchLight = 9; // D9 use blue slider blue_value
const int curioLight = 5; // D5 use red slider red_value ( change to )
int brightness = 0; // how bright the LED is
int fadeAmount = 10; // how many points to fade the LED by with each button push
int button2=0; // push button
int brightness2 = 0; // how bright LED2 is
int fadeAmount2 = 10; // how many points to fade LED2 by with each button push
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
;//IRrecv irrec(RECV_PIN); // no IR receiver in this design
IRsend irsend; // object to send the IR signal
decode_results results; // actual IR pulses or string
/************************** Setup **********************/
Serial.println("Getting IP......"); // serial monitor prints this 1st
//Ethernet.begin(mac); // select to use DHCP - comment out to use fixed ip
Ethernet.begin(mac,ip); // select to use fixed ip - comment out to use DHCP
server.begin(); // start the Arduino board
Serial.print("My IP address: "); // serial monitor prints this next
Ethernet.localIP().printTo(Serial); // reads IP from router
Serial.println(); // prints IP address on serial monitor
Serial.print("Gateway IP address is "); // serial monitor prints this next
Ethernet.gatewayIP().printTo(Serial); // reads gateway from router
Serial.println(); // prints gateway address on serial monitor
Serial.print("DNS IP address is "); // serial monitor prints this next
Ethernet.dnsServerIP().printTo(Serial); //reads DNS IP from router
Serial.println(); // prints DNS address on serial monitor
//irrec.enableIRin(); // IR input not used with this design
// initialize the LED as an output:
pinMode(barLight, OUTPUT); // pin D6 PWM controlled by green slider
digitalWrite(barLight, LOW); // start with pin 6 LOW
pinMode(benchLight, OUTPUT); // pin D9 PWM controlled by blue slider
digitalWrite(benchLight, LOW); // start with pin 9 LOW
pinMode(curioLight, OUTPUT); // pin D5 PWM controlled by red slider
digitalWrite(curioLight, LOW); // start with pin 5 LOW
pinMode(2, INPUT); // pin D2 is an input
digitalWrite(button2, LOW); // start with button 2 held LOW
checkEthernetClient();
// Do you stuff here like;
// digitalWrite(channel, y);
// analogWrite(ledPin, blue_value );
//------------------- Function working with X from Example layout 2 of the android app --------------//
nowtime = millis(); // store the time
if (abs(nowtime - lastTime) >= 100) // if more than 100 milliseconds elapsed sinds last time (0.1 second)
if (string_x == "up") x++; // increase the value
if (string_x == "stop") ; // stop increasing x
if (string_x == "down") x = 0; // reset value x to zero
lastTime = nowtime; // store the time to compare next cycle
void checkEthernetClient()
EthernetClient client = server.available(); // check for module connection
if (client)
boolean sentHeader = false; // header received
boolean currentLineIsBlank = true; // a command is being received
while (client.connected())
if (client.available())
if(!sentHeader){
client.println("HTTP/1.1 200 OK"); // appears on android app
client.println("Content-Type: text/html"); // eg.
client.println(); //
sentHeader = true; //
readString=""; //
Serial.println(); // command appears on serial monitor
char c = client.read();
//if (DEBUG5) Serial.write(c); // bob uncommented to see what debug is printed / needs to be defined
if(readString.indexOf('\n') < 1)
readString.concat(c); //
if (c == '\n' && currentLineIsBlank) {
//Serial.print(readString);
if (readString.indexOf("GET") >= 0){
Serial.print(readString); //
int Is = readString.indexOf("/"); //
int Iq = readString.indexOf("?"); //
int Ic = readString.indexOf("c"); //
int Ib = readString.indexOf("b"); //
int IR = readString.indexOf("R"); //
int IG = readString.indexOf("G"); //
int IB = readString.indexOf("B"); //
if(readString.indexOf("?") > 1)
/************************* Example 2 **************************/
// All functions have diferent methods to get the value from the recieved string.
// Choose which one suits your needs
if (readString.indexOf("Blue=") > 0) // blue seekbar send value on every change while sliding over it
char carray[5]; // build an array to store the string containing the value
readString.toCharArray( carray,5,(readString.indexOf("=")+1)); // read the string after $ and store it in the array
valueblue = atoi(carray); // convert the Array TO Int
valueblue =map( atoi(carray),0,255,0,255);
Serial.print("BenchLight is now: "); // print this on serial monitor
Serial.println(valueblue); // print the integer value to serial
analogWrite(benchLight, valueblue); // Bob added to get bar light to dim OCT 12,2013
client.print (content_main_top); // set the background an text color of the webview in the app
client.print("BenchLight is now: "); // print this on header of android app
client.print(valueblue); // print the integer value to the android application header
else if (readString.indexOf("Red=") > 0) // CURIO LIGHT now working Oct 24,2013
char carray[5];
readString.toCharArray( carray,5,(readString.indexOf("=")+1)); // not being used at this time
valuered = atoi(carray); //
valuered =map( atoi(carray),0,255,0,255);
Serial.print("CurioLight is now: "); //
Serial.println(valuered); //
analogWrite(curioLight, valuered);
client.print("CurioLight is now: "); //
client.print(valuered); //
else if (readString.indexOf("Green=") > 0) // CURIO LIGHT now working Oct 24,2013
char carray[5];
valuegreen = atoi(carray); //
valuegreen =map( atoi(carray),0,255,0,255);
Serial.print("BarLight is now: "); //
Serial.println(valuegreen); //
analogWrite(barLight, valuegreen);
client.print("BarLight is now: "); //
client.print(valuegreen); //
Here is part three of the " Home_Control " sketch:
else if (readString.indexOf("value_x=") > 0) //
if (readString.indexOf("up") > 0){ // UP button in app
string_x = "up"; // not used at this time
} // in loop() x increases every second
if (readString.indexOf("stop") > 0){ // STOP button in app
string_x = "stop"; // in loop() stop increasing x
if (readString.indexOf("down") > 0){ // Down button in app
string_x = "reset"; //
} // in loop() reset x to zero
Serial.print("x: "); // serial monitor prints this
Serial.println(string_x); // serial monitor fills in the value of the string_x
client.print (content_main_top); // app's turn to start printing value
client.print("x: "); // app prints X at header
client.print(string_x); // app prints the actual string value
;//client.print("<meta http-equiv=refresh content=1,url=/?status_refresh>"); // webview in the android app refresh after 1 second and calls url ip:port/status_refresh
else if (readString.indexOf("status_refresh") > 0){ //
Serial.print("x: "); // print the X: into the serial monitor
Serial.println(x); // print this value into the serial monitor next to X:
client.print("x: "); // print the value x to the android app
client.print(x);
;//client.print("<meta http-equiv=refresh content=1,url=/?status_refresh>"); // ask the app to refresh every second
else if (readString.indexOf("value_y") > 0) // read value from the first "$" to the second "$"
int first_S = readString.indexOf("$"); //
String string = readString.substring(first_S + 1,(readString.indexOf("$", first_S + 1)));
Serial.print(string); //
if(string == "+"){
y++; //
else if(string == "-"){
y--; //
else{
y = string.toInt(); //
Serial.print("y: "); // print on serial monitor
Serial.println(y); // print value of Y
client.print (content_main_top); // print on app header
client.print("y: "); // print the value of Y
client.print(y); //
else if (readString.indexOf("value_z=") > 0) // read values seperated by ","
int comma;
String string = readString.substring((readString.indexOf("=")+1),(comma = (readString.indexOf(","))));
int a = string.toInt();
string = readString.substring((comma + 1),(comma = (readString.indexOf(",", (comma + 1)))));
int b = string.toInt();
int c = string.toInt();
Serial.print("a, b, c: ");
Serial.print(a);
Serial.print(b);
Serial.println(c);
client.print("a, b, c: ");
client.print(a);
client.print(b);
client.print(c);
/************************* Example 1 **************************/
else if (Ib == (Iq+1))
char carray[5];
readString.toCharArray( carray,5,(Ib+1));
Serial.println(carray);
valueB = atof(carray);
Serial.print("B is now: ");
Serial.println(valueB);
client.print("B is now: ");
client.print(valueB);
else if (Ic == (Iq+1))
char carray[5];
readString.toCharArray( carray,5,(Ic+1));
valueC = atof(carray);
Serial.print("C is now: ");
Serial.println(valueC);
client.print("C is now: ");
client.print(valueC);
char carray[2]; // Bob changed to 3
readString.toCharArray( carray,3,(Iq+1)); // change to 3 if 10th button added Bob Oct 14,2013
RecievedString = atoi(carray);
switch (RecievedString) {
case 1:
action(1, client);
case 2:
action(2, client);
case 3:
action(3, client);
case 4:
action(4, client);
case 5:
action(5, client);
case 6:
action(6, client);
case 7:
action(7, client);
case 8:
action(8, client);
case 9:
action(9, client);
case 10:
action(10, client);
case 11:
action(11, client);
case 20:
action(20, client);
case 21:
action(21, client);
case 22:
action(22, client);
case 23:
action(23, client);
case 24:
action(24, client);
default:
action(100, client);
delay(1); //
client.stop();
readString="";
client.read();
client.read();
action(404, client); //no "?" found so print a 404 error
delay(1); //
client.stop();
readString="";
client.read();
client.read();
here is the last part of the " Home_Control " sketch:
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
client.stop();
void action(int x, EthernetClient client)
if (x == 01)
client.println(S1);
Serial.println(S1);
irsend.sendNEC(0xC1A28877,32); // NEC Sherwood Receiver Power ON
if (x == 02)
client.println(S2);
Serial.println(S2);
irsend.sendNEC(0xC1A2B847,32); // NEC Power OFF
if (x == 03)
client.println(S3);
Serial.println(S3);
irsend.sendNEC(0xC1A2C03F,32); // NEC FM
if (x == 04)
client.println(S4);
Serial.println(S4);
irsend.sendNEC(0x45BA38C7,32); // NEC CD POWER toggle
if (x == 05)
client.println(S5);
Serial.println(S5);
irsend.sendNEC(0xC1A2D02F,32); // NEC cd player
if (x == 06)
client.println(S6);
Serial.println(S6);
irsend.sendNEC(0x45BA52AD,32); // NEC Random
if (x == 07)
client.println(S7);
Serial.println(S7);
irsend.sendNEC(0xC1A250AF,32); // NEC Ipod
if (x == 8)
client.println(S8);
Serial.println(S8);
valuegreen = 0;//
analogWrite(barLight, valuegreen); // Bob added to get bar light to dim OCT 12,2013
client.print(valuegreen); // print the value to the android application
if (x == 9)
client.println(S9);
Serial.println(S9);
valuegreen = 220;//
client.print(valuegreen); // print the integer value to the android application
if (x == 10)
valuered = 0; // give a value of 0 so curioLight is off
analogWrite(curioLight, valuered); // write redvalue of 0 to curioLight
client.print(valuered); // print the value to the android application
if (x == 11)
client.println(S11);
Serial.println(S11);
valuered = 160;
if (x == 20)
client.println(S20);
Serial.println(S20);
valueblue = 0;
client.print(valueblue); // print the value to the android application
if (x == 21)
client.println(S21);
Serial.println(S21);
valueblue = 100;
if (x == 22)
client.println(S22);
Serial.println(S22);
client.print("CurioLight: ");
client.print(valuered); // print the integer value to the android application
client.print("BarLight: ");
client.print("BenchLight: ");
if (x == 23)
client.println(S23);
Serial.println(S23);
valuered = 0;
valuegreen = 0;
valueblue = 0;//
if (x == 24)
client.println(S24);
Serial.println(S24);
valuered = 180;
valuegreen = 200;//
valueblue = 100;
if (x == 100) //Default action
client.print ("Default message");
Serial.println("Default");
if (x == 404)
client.println(S404);
Serial.println(S404);
x=0;
Here is the screenshot of the " Home_Control " as viewed on my Android tablet.Note the values for each light is shown at the top of the screen.
Bobby_D
redcell ,
Hello again! Keep in mind you can have up to 8 profiles ...so over 200 buttons if you look at it that way. I have 3 separate ethernet boards and have 3 profiles . There is so much expandability as well with this app that you can have several profiles with the same IP and MAC address .It is then the string you send and decode with your Arduino program that provides you the extra button functionality.
I think Marque is doing some great work with his apps and he is helping to bring Arduino and Android to the people to use in some very creative ways .
BobbyD
