Arduino Counter (Laser)
Hello
I did in the video project. Circuit 1 would like to add one more LDR
Exit People code :
Serial.print(1-counting);
How do I
2 LDRinput and output ?
int ldr = 0;
int ldrValue = 0;
int ldrTemp = 0;
int ldrMin = 1023;
int ldrMax = 0;
int ldrCompare = 0;
int setldrMin = 0;
int setldrMax = 0;
float setPercentMin = 0;
float setPercentMax = 0;
int counting = 0;
int ser;
int Max = 0;
int Min = 0;
  Serial.begin(57600);
  pinMode(10, OUTPUT);
Serial.println("LDR counter by krangul");
Serial.println("To [c]alibrate laser press:                 c");
Serial.println("To [t]est min/max value press:              t");
Serial.println("To [s]et min/max value limit press:         s");
Serial.println("To start counting [m]easure press:          m");
Serial.println(".............................................");
Serial.print("Your ldrMax limit value: "); Serial.print(ldrMax); Serial.print(" - "); Serial.print(setPercentMax); Serial.print("%  =  "); Serial.print(setldrMax);
Serial.print("Your ldrMin limit value: "); Serial.print(ldrMin); Serial.print(" + "); Serial.print(setPercentMin); Serial.print("%  =  "); Serial.print(setldrMin);
while(Serial.available() == 0);
      ser = Serial.read();
        for(ser; ser == 'c' || ser < 0 ;)
            calibrate();
         for(ser; ser == 't';)
              test();
          for(ser; ser == 's';)
               set();
           for(ser; ser == 'm';)
              count();
void calibrate()
   for(int b=0; b<250; b++)
       read_ldr();
       Serial.println(ldr);
       delay(100);
void test()
      read_ldr();
      ldrCompare = ldr;
      if (ldrCompare > ldrMax)
        ldrMax = ldrCompare;
      if (ldrCompare < ldrMin)
         ldrMin = ldrCompare;
      delay(30);
void set()
  Serial.println("Set your Min percent limit 10-40%");
  for(int c=0; c<2; c++)
	 setPercentMin *=10;
	 setPercentMin += (Serial.read() - '0');
  Serial.println("Set your Max percent limit 10-40%");
  for(int d=0; d<2; d++)
	 setPercentMax *=10;
	 setPercentMax += (Serial.read() - '0');
    setldrMin = ldrMin + (ldrMin * (setPercentMin*0.01));
    setldrMax = ldrMax - (ldrMax * (setPercentMax*0.01));
void count()
 Serial.println("#####################################");
 Serial.println("##  Measurement has been started.  ##");
    for(;;)
        read_ldr();
        if(ldr>setldrMax)
           Max=1;
          if(ldr<setldrMin && Max==1)
                Max=0;
                counting++;
                Serial.print(counting);
                tone(10, 6000, 10);
void read_ldr()
  for(int a=0; a<10; a++)
    ldrValue=analogRead(0);
    ldrTemp = ldrTemp + ldrValue;
    delay(1);
      if(a==9)
        ldr=ldrTemp/10;
        ldrTemp=0;
Is not going to help ?
