Dear All
I have an Arduino circuit using WOKWI and I think the program code I created is correct. However, when I simulated it turned out that PB_LS1, PB_LS2, PB_LS3 or PB_LS4 when pressed were not implemented.
Please provide information on why this might happen.
For the following circuit circuit program code in wokwi please click:
I have also included the program code below.
Thank you for the help.
#include <Arduino.h>
#include <LiquidCrystal.h>
// Initialize pins for buttons
const int PB_EMERGENCY = 39;
const int PB_STOP_ALL = 40;
const int PB_AUTO = 41;
const int PB_DOWN = 42;
const int PB_UP = 43;
const int PB_LS1 = 44;
const int PB_LS2 = 45;
const int PB_LS3 = 46;
const int PB_LS4 = 47;
const int PB_BV_CLOSE = 48;
const int PB_BV_OPEN = 49;
const int PB_EV1_CLOSE = 50;
const int PB_EV1_OPEN = 51;
const int PB_EV2_CLOSE = 52;
const int PB_EV2_OPEN = 53;
// Initialize pins for relays
const int relay_auto = 34;
const int relay_reverse = 35;
const int relay_forward = 36;
const int relay_empty = 37;
const int relay_emergency = 30;
const int relay_stop_all = 31;
const int relay_filling = 32;
const int relay_emptying = 33;
const int relay_EV1_close = 26;
const int relay_EV1_open = 27;
const int relay_EV2_close = 28;
const int relay_EV2_open = 29;
const int relay_BV_close = 24;
const int relay_BV_open = 25;
// Initialize pins for LCD
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
// Variables to track button states
bool isAutoRunning = false;
bool isUpRunning = false;
bool isDownRunning = false;
// Enum for status
enum State {
AUTO,
AUTO1,
AUTO1_1,
AUTO1_2,
AUTO1_3,
AUTO2,
AUTO3,
AUTO4
State status = AUTO; // Initial state initialization
// Initialize the pin as input_PULLUP
pinMode(PB_AUTO, INPUT_PULLUP);
pinMode(PB_DOWN, INPUT_PULLUP);
pinMode(PB_UP, INPUT_PULLUP);
pinMode(PB_STOP_ALL, INPUT_PULLUP);
pinMode(PB_EMERGENCY, INPUT_PULLUP);
pinMode(PB_BV_CLOSE, INPUT_PULLUP);
pinMode(PB_BV_OPEN, INPUT_PULLUP);
pinMode(PB_EV1_CLOSE, INPUT_PULLUP);
pinMode(PB_EV1_OPEN, INPUT_PULLUP);
pinMode(PB_EV2_CLOSE, INPUT_PULLUP);
pinMode(PB_EV2_OPEN, INPUT_PULLUP);
pinMode(PB_LS1, INPUT_PULLUP);
pinMode(PB_LS2, INPUT_PULLUP);
pinMode(PB_LS3, INPUT_PULLUP);
pinMode(PB_LS4, INPUT_PULLUP);
// Initialize the pin as OUTPUT
pinMode(relay_auto, OUTPUT);
pinMode(relay_reverse, OUTPUT);
pinMode(relay_forward, OUTPUT);
pinMode(relay_empty, OUTPUT);
pinMode(relay_emergency, OUTPUT);
pinMode(relay_stop_all, OUTPUT);
pinMode(relay_filling, OUTPUT);
pinMode(relay_emptying, OUTPUT);
pinMode(relay_EV1_close, OUTPUT);
pinMode(relay_EV1_open, OUTPUT);
pinMode(relay_EV2_close, OUTPUT);
pinMode(relay_EV2_open, OUTPUT);
pinMode(relay_BV_close, OUTPUT);
pinMode(relay_BV_open, OUTPUT);
if (digitalRead(PB_AUTO) == LOW && !isUpRunning && !isDownRunning) {
// Process when the PB_AUTO button is pressed
isAutoRunning = true;
// Perform the necessary processes for PB_AUTO
switch (status) {
case AUTO: //0
if (digitalRead(relay_BV_close) == LOW) {
digitalWrite(relay_BV_close, LOW);
digitalWrite(relay_BV_open, HIGH);
status = AUTO1;
} else if (digitalRead(relay_BV_open) == LOW) {
status = AUTO1;
case AUTO1: //1
digitalWrite(relay_reverse, HIGH);
delay(7000);
digitalWrite(relay_reverse, LOW);
digitalWrite(relay_filling, HIGH);
delay(2000);
digitalWrite(relay_forward, HIGH);
status = AUTO2;
case AUTO1_1: //2
// Code if required for AUTO1_1
status = AUTO3; // Change to next state
case AUTO1_2: //3
digitalWrite(relay_emptying, HIGH);
delay(2000);
status = AUTO4;
case AUTO1_3: //4
if (digitalRead(PB_LS4) == LOW) {
status = AUTO;
case AUTO2: //5
if (digitalRead(PB_LS2) == LOW) {
digitalWrite(relay_BV_open, LOW);
digitalWrite(relay_BV_close, HIGH);
if (digitalRead(PB_LS1) == LOW) {
digitalWrite(relay_forward, LOW);
status = AUTO1_1;
case AUTO3: //6
if (digitalRead(PB_LS3) == LOW) {
status = AUTO1_2;
case AUTO4: //7
status = AUTO1_3;
} else if (digitalRead(PB_UP) == LOW && !isAutoRunning && !isDownRunning) {
// Process when the PB_UP button is pressed
isUpRunning = true;
// Perform the necessary processes for PB_UP
digitalWrite(relay_forward, HIGH); // Turn on the forward relay
// If the PB_LS1 button is pressed, perform the following actions:
digitalWrite(relay_forward, LOW); // Mematikan relay_forward
digitalWrite(relay_BV_open, LOW); // Mematikan relay_BV_open
digitalWrite(relay_BV_close, HIGH); // Menghidupkan relay_BV_close
} else if (digitalRead(PB_DOWN) == LOW && !isAutoRunning && !isUpRunning) {
// Process when the PB_DOWN button is pressed
isDownRunning = true;
// Perform the necessary processes for PB_DOWN
if (digitalRead(PB_STOP_ALL) == LOW) {
// Process when the PB_STOP_ALL button is pressed
// Perform the necessary stop process
if (digitalRead(PB_EMERGENCY) == LOW) {
// Process when the PB EMERGENCY button is pressed
// Carry out necessary emergency processes
digitalWrite(relay_EV1_open, LOW);
digitalWrite(relay_EV1_close, HIGH);
digitalWrite(relay_EV2_open, LOW);
digitalWrite(relay_EV2_close, HIGH);
if (!isAutoRunning && !isUpRunning && !isDownRunning) {
if (digitalRead(PB_BV_CLOSE) == LOW) {
// Process when the PB_BV_CLOSE button is pressed when no other processes are running
// Perform the necessary processes for PB_BV_CLOSE
if (digitalRead(PB_BV_OPEN) == LOW) {
// Process when the PB_BV_OPEN button is pressed when no other processes are running
// Perform the necessary processes for PB_BV_OPEN
if (digitalRead(PB_EV1_CLOSE) == LOW) {
// Process when the PB_EV1_CLOSE button is pressed when no other processes are running
// Perform the necessary processes for PB_EV1_CLOSE
if (digitalRead(PB_EV1_OPEN) == LOW) {
// Process when the PB_EV1_OPEN button is pressed when no other processes are running
// Perform the necessary processes for PB_EV1_OPEN
digitalWrite(relay_EV1_close, LOW);
digitalWrite(relay_EV1_open, HIGH);
if (digitalRead(PB_EV2_CLOSE) == LOW) {
// Process when the PB_EV2_CLOSE button is pressed when no other processes are running
// Perform the necessary processes for PB_EV2_CLOSE
if (digitalRead(PB_EV2_OPEN) == LOW) {
// Process when the PB_EV2_OPEN button is pressed when no other processes are running
// Perform the necessary processes for PB_EV2_OPEN
digitalWrite(relay_EV2_close, LOW);
digitalWrite(relay_EV2_open, HIGH);
